Sharp R-230 Microwave Oven Logo
Posted on Nov 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After I switch on the oven, the turn table rotates but no heat generated.
Anonymous
Level 3:
  • Sharp Master 43,501 Answers
  • Posted on Nov 15, 2010
Anonymous
Sharp Master
Level 3:
Answers
43501
Questions
0
Helped
10844261
Points
101584
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Why
The table motor belt may have detached which stops table from rotating and the magnetron control shuts off the heating if table does not move. Need model number etc for the microwave. It is not recommended to open the units unless you are qualified technician or understand the operation of the microwave oven. The voltages and waves can harm human body.
Turn table won't turn on ewave microwave oven
Almost certain if microwave still heats a bad motor or gear issue inside the unit--if unit will not heat the safety switch in the side that the door engages is the cause of the wheel or platter not turning--prevents unit from use if door open.
UNIT DOES NOT HEAT, SLIGHT HUM, BUT TURN TABLE ROTATES, ALL OTHER FUNCTIONS OK
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
When I press the start the button the turn table inside microwave is not turning and there is not heat on the food. But the light is on and the clock is working. What do you think is the problem? and what...
The turn table motor of your microwave is defective already and also the magnetron - the source of generated heat of the microwave is also defective. But before assuming that magnetron is dead, check the high voltage fuse it may be blown and replace the fuse (if it is blown) it with similar rating. I hope I help you with your microwave problem.
Hi there, unit worked fine this morning heating coffee, now has a different tone, and not heating. Timer works, interior light comes on, turn table rotating. Unit is a KEMC308KSS01
Basic Microwave Oven Troubleshooting Tips
heatman101
On switching Microwave oven turn table rotates and light in the chamber also lights. Heating of of food do not take place. What is possible reason?
Basic Microwave Oven TroubleshootingTips
heatman101=--=
The microwave does not heat and the turn table does not turn
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
2answers
Goldstar MV-1501 1000 Watts... Problem:
if micro. new then its defective
if micro. old then you need replacement or service the heating element and turn table motor
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
