Question about Cell Phones
My sanyo 8500 wont charge i have a brand new battery but it still wont charge, the charger works in other phones normally so I assume it must be the phone, who can fix it and is it worth fixing?
  • Cell Phones Expert
  • 2,973 Answers
Yes it is worth fixing. Most likely the charging socket has gone or the charging circuit of the phone has gone. Please have these two checked by the Sanyo Service Center
Posted on Nov 14, 2010
Why wont my sanyo vc-e760 hold a charge
Since you've already tried different batteries, you have a couple of other options...
  • Instead of plugging the USB cable into the camera's wall charger, plug it into the USB port of a computer, or even into a USB phone charger.
  • Try another wall charger.
  • Try another USB cable.
Here's the PDF manual for your camera, if you need it: http://us.sanyo.com/dynamic/extranet/servicers/VPCT1495.pdf
(Page 16 contains info about charging the camera)
Aug 04, 2014 | Sanyo Cameras
When ever i try to charge my phone it wont charge. I brought a new charger and new battery still wont charge
Hello there,
Have a nice day.
You have mentioned the you have bought a new charger and a new battery but still your handset wont charge.
The problem is from the charging port on your phone. You will need to change or replace the charging port on your phone to fix the problem.
Try to take your phone to any Sanyo service center or any local phone repairer to help you replace the charging port, it has a minimum charge only.
Hope it helps,
Thank you for using the fixya.
Adieh
Sep 12, 2011 | Sanyo Incognito 6760
My LG-VX9200 wont turn on and the battery wont charge. I assume is the battery, its a practically new phone. It hasnt get wet either. What can it be? Thanks in advance
Before you conclude that the battery is the problem, i suggest, you get a similar charger to charge your phone first, if the similar charger charges the phone, then, ii means you are having charger problem, but if it does not charge the phone, you should be considering the idea of getting another battery to see if it will charge on your phone.
The problem can also be that, the charging port of your phone is bad, you can use your charger to charge a similar phone and see if it charges, if it does, then, the problem is either th battery or the charging port.
Check the following one after the other to detect what the problem is,
1. Try use a similar charger to charge your phone to see if it will charge.
2 Get a battery from someone that as a similar phone to test your phone to see if it will power up.
If it works with your phone, get a new battery for your phone, the one you have on it is dead and will need to be replace.
Take care.
Jul 18, 2010 | LG enV3 VX9200 Cell Phone
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Apr 14, 2010 | Sanyo PM-8200
BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
May 27, 2009 | LG VX9400 Cellular Phone
Battery won't charge.
hello,
normally many cell phones requires 6-10hrs for its batter to fully charge up. also i have seen it where battery can be brand new but doesn't have enough juice to hold the charge.
now as far as red light on charger, remember even if you have 99% charged batter and you plug in the charger it will show you red light on phone/cradle.
FYI- all brand new phones are covered with 30 days of warranty replacement with new phone. after 30 days it covers upto 1 year from the date of purchase with refurbished phones.
In your case i think it is just the battery, try having your provider replacing new battery if no luck again then my suggestion will be to replace your phone with new battery with in 30 days.
TY
Dec 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
SANYO MM-5600
If you use a car charger, use a wall plug instead and replace the battery; because a lot of car chargers can harm battery life…especially if that is all you’ve ever used. Also check the settings on the phone, if you have disabled power saving features that dim the screen after so many seconds then the back light will drain the battery very quickly. Use name brand batteries and not the ones that come with the phone, Sometimes the ones that come with the phone can ****. Finally, make sure that you do not have a short in your wall charger and that the first time you use a new battery you charge it fully to begin with and don’t charge it again until it is completely depleted. Supposedly newer batteries do not have to be primed, but I find it is a good practice anyway. Use the charger that came with your phone, the voltage/amps are not always just right if using a radio shack special.
Nov 29, 2007 | Sanyo MM-5600
Sanyo cell phone
Have you tried putting it on a normal charger. I would do that if it still isn't holding a charge time for a new battery but if it does then it is the car charger. Hope that helps :)
Nov 05, 2007 | Sanyo VI-2300
Recharging doesnt work
OK Try to replace a new one battery then observe if can charge!? if not charging u have defective charging pin! or charging IC.
Sep 14, 2007 | Panasonic X700 Cellular Phone
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
