Question about Aube Technologies Aube 7-Day 40-500w Light Switch Timer
We have had underfloor heating installed controlled by an aube TH132 A/F/AF control module. On commissioning the heating the RCD in the consumer unit keeps tripping. The installer blames the RCD - but the RCD is otherwise stable, problem only occurs trying to start the heating. Could there be a problem with the control module or how it is connected?
2 Suggested Answers
SOURCE: Is there an easy to understand user manual for the
http://www.uheat.co.uk/aube_th132_underfloor_heating_thermostat.htm
TH132 is a thermostat for under-floor heating
Go to the website above and download on-line copy of your manual
On-line manual let you read bigger print & lets you break down the steps easier
I am sure by the time this answer reaches you, the problem will be solved
This is true because manuals are frustrating, until you tell somebody it can't be figured out >> which gives you time to rest >> after which the manual makes sense.
BUT I am frequently wrong, and you may be at a standstill
A quick look at the manual.
You can also select which part of the manual is giving you a problem and then I will help you through that specific difficulty
Wiring: I guess the instructions at bottom of manual apply to your model
Your 240Volt hot wires from breaker box connect to terminals 1 & 5
Your two wires supplying power to heat connect to 2 & 4
Pilot wire to terminal 3
Floor sensor to 6 or 7 >> wire from sensor can connect to either pole
The TH132 has two sensors, 1 located inside the TH132, the other sensor located in floor
Set up:
The first part describes 10 buttons (right away you know this is complicated)
There is a brief description of both sensors
Step 1 shows how to configure the start and temp-display switches
Step 2 covers installation of module on base
I guess you hook up power at this point because the display is supposed to light up
This implies that the bottom part of manual should be located more towards the top, and the power-up directive seems to be missing. Bad manual.
Step 2 shows what the display looks like with first power-up
Step 3 tells how to set current time and day.
Step 4 adjust temp setpoints >> floor temp is pre-programmed to 82 degrees
Step 4 shows that you press-and-hold the sunshine or moon button to have it display
The sunshine button is the upper temp setting, the moon is the lower temp setting
Step 5 is operating mode > choose automatic for programming to operate
Step 6 is programming, which carries on with about 24 steps
If this is your problem area, let me know
Now the manual suggests you make a chart of your programs
Other programmable devices don't work when there is a conflict in programming
Wow I see the TH132 is 'equipped with a proportional adaptive controller..' that carries a two year warranty. I'm sure you'll rest easy knowing that.
Reply back with the specific trouble area, and we'll get it going for you.
Posted on Oct 22, 2010
Aube th132 problems
The unit is not talking to the sensor. It is most likely the sensor.
Mar 13, 2014 | Hardware & Accessories
Aube th132 problems
You can reset the programming of the comfort setting and make sure that it did not get set at 14C. Here is the manual that shows how to do that.
http://www.aubetech.com/manuel/2/TH132-A-F-AF-230.pdf
Sep 19, 2013 | Hardware & Accessories
I have the aube TH132 underfloor heating system installed. I have programmed the temperature set points to 18c but its over heating to 43c!! I've re programmed it but with no luck!! The icon for when...
This product has 2-year warranty against defects in workmanship.
Aube technologies Inc.
Warranty does not apply to poorly installed ...
Canada 450-358-4600
Manual does not have troubleshoot section.
section 4 includes temperature setpoints by model number.
On-line manual can be word-searched for fine details that might be missed by a visual read.
http://waterheatertimer.org/pdf/TH132-A-F-AF-230-thermostat.pdf
Check that air vents are open to control, so the unit can read correct temperature.
Change temperature Display selector for F or C.
Make sure wires are connected to correct terminals to match your voltage.
15 amp max rating indicates #12 gauge wire for 120Volts. Recommend that thermostat control a contactor instead of direct-wire to heat coils.
Example contactors
http://waterheatertimer.org/H230A.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 09, 2012 | Hardware & Accessories
Etherma
I'm sure there are different types of Etherma controllers but try this website ... it worked for mewww.penguineurope.com/pdf/TH132-Fang.pdf
Nov 28, 2011 | Cars & Trucks
Is there an easy to understand user manual for the aube TH132 AF ? Even my father in law can't understadn how to operate the under floor heating on a timer...
Set up:
Oct 21, 2010 | Aube Technologies Aube 7-Day Programmable...
I do not understand the manual that came with my TH132 control unit. Can some one guide me so that I can set the heating for different times for Mon-Fri and different times for the weekend?
Aube technologies has a page with thermostat manuals
http://www.aubetech.com/products/list.php?noLangue=2&noFamille=1&app=1
Thermostat page shows 3 models for your TH132 (toward bottom of page)
Click the model number and it opens a second page
The manuals for each product are conveniently located on that second page, toward the bottom, along with a description of your product.
In my opinion, Aube (Honeywell I think) website is way ahead of the curve for customer convenience
Most other electric device websites have manuals located on a different page than the product
A lot of sites, like Leviton, have no manuals at all. Lose the manual, and you have to call their customer service like in the 1980's
Aube must want your repeat business.
Oct 17, 2010 | Aube Technologies Hardware & Accessories
Our TH132-AF keeps going blank and shutting down just as the heating element bars are due to show up on the display
Robbo,
I've had the same problem and it's due to the unit breaking down due to a 'snubber' not being fitted to the contactor (across the coil). It's a small resistor/capacitor that smooths the switching load coming from the stat. Without it, the trickle feed coming from the stat makes the contactor's coil bounce and damages the stat. Tracking one down, however, is proving to be a problem, as no-one seems to have them in stock. I have found one now, though from elementshop.co.uk here:
http://www.elementshop.co.uk/product.php?pid=1022&cat=251&nm=
Dec 03, 2009 | Intermatic FD60MH Energy Controls -...
Our controle module TH132 A/F/AF goes blank every time the heating systen is supposed to be activated
I have also had the same problem with 2 units. I have been in touch with Aube who say they have identfied a problem with the back unit which they will have fixed in " a few months time". My suggestion would be to contact them for a replacement later on this year
Oct 27, 2009 | Aube Technologies Hardware & Accessories
Aube Technologies Aube 7-Day 40-500w Light Switch Timer  Logo
167 people viewed this question
Top Aube Technologies Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you an Aube Technologies Hardware and Accessory Expert? Answer questions, earn points and help others
