Question about RCA 27F530T 27" TV
The straped Capacitor from D1878 collector to graund,immedaitly blow out or burn out.
    Genius:
  • 1,126 Answers
The first to do is to check and see if D1878, is shorted, or any other semiconductors shorted in that circuity, taht are related to the Driver (D1878), and or the Cap. Replace the bad components and cap.
Posted on Nov 14, 2010
I replaced HOT then LOT.but HOT blow yet. B+ voltage also ok.what the reason.please help me.
Check the freewheeling capacitor used. It can be located at very near to HOT; will be connected to its collector lead to ground. If this capacitor is open / have loose solder terminals, this might happen. Check it. Usually it will be of the capacitance value from 3500PF2000VDC. to 9700PF 2000VDC.
Refer any circuit diagram to CRT CTV. You'll get an idea.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 09, 2015 | Televison & Video
Tv blows 2sc4429 transistor
Check the freewheeling capacitor, connected between its collector terminal to ground for loose solder, or damage. Repalce this capacitor, before replacing the horizontal output transistor. If this capacitor is open, the horizontal output transistor will blow off, at the time of switch-on itself. Normally, its value will be grater than 3900pF & lesser than 9800pF[2500V]
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 09, 2014 | Televison & Video
Samsung tv keep blowing out the horizantal transistor when i replace it whats the problem?
Check and replace the freewheeling capacitor; which connected to the horizontal output transistor's collector terminal to ground. Replace an other transistor after replacing the capacitor. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 29, 2014 | Televison & Video
Lg 29'' flatron tv circut diagram
Check the LOT. If it is faulty, horizontal output transistor will blow out. Check the capacitor connected across the collector of the horizontal output transistor to Gnd. If it is bad, or have any loose solder terminals, H-Out transistor will blow out. If you wish to get more http://electronicshelponline.blogspot.com/ check this link. Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 22, 2013 | LG 29" Stretch LCD 17:6 aspect Mo TV
LG 17" 700E CRT MONITOR MOSFET 2N10 IS Immediately BURN OR SHORT WHEN SWITH ON THE MONITOR..
this might be the problem of the disk capacitor of value 2kv, which is located at the horizontal section, i.e from the collector of horizontal output transistor.
Aug 04, 2010 | LG 700M 17" CRT Monitor
Transistor d1878 get over heat
i have a sony kv-2197m3 i replaced tr D1878 tv turn on,but image it's bad in horizontal seize and tr D1878 was shorted again what's the matter? chek68@gmx.fr Post Solution
Oct 11, 2009 | RCA 27F530T 27" TV
HORIZONTAL OUTPUT TRNSISTOR SHORTS WHEN POWER ON TV
ALL the next is with the tv unplugged (NO NO power)
  • resold the jungle (video processor) all around
  • following the horizontal drive pulse path and arriving to the horizontal area just after the horizontal transformer and in the base of the horizontal DRIVER there is a electrolytic capacitor (if this chassis uses this one,) Change it (maybe is dry)
  • solder all components i just told you in the last step. horizontal driver, transformer, etc
  • remember:
  • if a transistor is blowing with no reason (there is a reason: the collector receives 130 volts but cannot hold it forever, It has to be in some place. if the switching pulse doesn't arrive to it the transistor throws this 130 volts and burning itself. i hope it is help full.
Apr 15, 2009 | Televison & Video
RCA 27F530T 27" TV Logo
150 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
