I have an LG Intellwash WD 1018C that does everything but spin. I put it up on trestles to look underneath and noticed that there were sparks coming from the motor (when running) where the bushes contact the copper spindle/shaft? I touched the plastic bush holder and got a belt of elec. Is this normal ( Apart from my not being normal by sticking my fingers where they don't belong) and would this be the problem of not spinning.
fanny
  • 146 Answers
SOURCE: Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Posted on Oct 31, 2007
aborcass
  • 2651 Answers
SOURCE: Diagnosing Clutch/Tranny problem
the fact your leaking oil tellls me you have bad transmission, replaced entire component as its not field servicable, the cluthc also gets replaced at same time(oil get on the pads and wont ever engage properly
Posted on Feb 23, 2008
faggly
  • 74 Answers
SOURCE: zanussi aquacycle 1400 fle 1416w
Hiya Cheap6... more than likely the brushes.. which are easily checked to see if they are worn down.. otherwise its a new or RE-con motor.
Regards Faggly
Posted on Mar 21, 2008
SOURCE: indesit washer not spinning
I had exactly the same problem. All seemed ok, except no spin. I followed Shaun's advice and replaced the module board. Cost of about f£23 from ebay, but similar price on espares.co.uk. Fixed it. Thank you.
Posted on Aug 20, 2009
  • 713 Answers
SOURCE: lg intellowasher wd-8013f is very noisy
it will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
Posted on May 13, 2010
Lg WD-12235FB put water on last minet before stop
DROP IT OFF AT THE SHOP AND SEE IF THE CAN BE FIX
Jul 01, 2016 | LG Washing Machines
I have a LG WD-1018C washer that wont spin out .. it just keep starting and stopping in about 30 second intervals ... an error code has just come up ... 1E ...can you help please ? Steve
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Feb 20, 2015 | LG Washing Machines
Lg washing machine is making a squeaking sound and not spinning dry. Do I need to replace the belt? 7.5kg washer model WD-1018C
check the belt tension before replacing. there should be about 1/2" deflection (play) on the longest open side of the belt.
Mar 21, 2014 | LG WM1812C Front Load Washer
Csan I use WD-40 to lubercate the blade? My lawmower got wet in the rain and the blade is stiff. It would run for a split second to show me that it works. I filled up the gas tank. I checked the oil....
The tight spot that you are noticing is the compression stroke of the engine. The blade is hooked to the crank shaft, which also means that if you are spinning it by hand and still have the spark plug hooked up to the plug wire, you could potentially start the mower and chop your hand to bits. WD-40 will not free anything up here and the stiff spot you feel is not a problem. Be safe out there.
Sep 03, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Looking for a instruction manuel for an LG intellowasher WD1018C
  • Your instruction manual is here
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WD-1018C-_E
  • Now when you go to there link you will click on the "download the complete user guide" PDF link in the upper right hand corner of the screen. Then it will ask you to rate 4 questions about the washing machine and leave a comment about it. Once you do that click "download user guide" and it will drop the PDF into your PC. I just did it and scanned it and open it so everything is safe and it will get you your manual quick and free.
Regards, Tony
May 01, 2011 | LG Washing Machines
I have a LG WD-1018C that won't work and has PE on the screen and I can't find the manual to fix it. Can you please tell me what PE means. Thanks
The error code "PE" stands for pressure sensor error. This is typically caused by a malfunctioning water pressure sensor switch.
Mar 09, 2011 | LG Washing Machines
Need the operating manual for a lg intellowasher 7.5 wd-1018c
go to www.lg.com/au then click on product support left hand side of screen then type in wd-1018c in search box under box high lighted in red wd-1018c washing machine comes up. click on it. half way down page down load pdf for manual
Oct 10, 2010 | Washing Machines
The door on my LG WD-1018C frontloader won't open.
Unplug electrical cord, wait one minute then plug back in. Sorry this is all I can tell u as I cannot find a parts diagram anywhere on Internet, not only is LG not helping u they don't want anyone else to help either by keeping their drawings secret. You might try sears partsdirect.com and talk to tech.
Nov 20, 2017 | GE WBVH6240F Front Load Washer
I Have an LG front loader washing machine the WD 1018C and the dorr wont open i have tried everything
Have not heard back from you, so I'm guessing you have solved your problem. If not, send another comment. Please don't bother rating.
Sep 19, 2008 | Washing Machines
Karcher 2400R
You have a poor signal to the spark plug usually caused by a rusty fly wheel found underneath the pullcord casing. clean it with releasing ajent such as wd 40. common when not in use for a while.
May 16, 2008 | Karcher 2500 PSI Pressure Washer
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
