Question about Samsung HL-R6167W 61" HDTV
I have a SAMSUNG DLP model HLR6167w with a problem.
I just changed the light hoping this would fix the problem. When the problem first occurred, I could barely make out the picture, and it was very green and jumpy (but I could still see spider man on TV with the 5 big vertical lines). I called tech supportand they said unplug the TV and plug it in after about 5 minutes. I did that and now it went from bad to worse. No picture at all. I have whiteand black static on the screen that also has a green tint. I have 5vertical evenly spaced lines. The big 3 inch lines consist of about 10skinny lines. I can put the TV on air-antenna, Satelite, DVD, NindendoWii, and the greenish static follows all components. When I hit "menu"on the TV remote, all menu options are crystal clear. Set-up, channel,sound, etc...all perfect picture...Just a problem with the actualpicture on all components. Please help if possible.
I have a 60" Samsung DLP HLR6167w
I turned it on again last night and I found more details.
The attached picture is what it looks like when it's on. It looks like that for 15 seconds then freezes. When it freezes I can't turn the TV off/on nor navigate through the TV's menu (it freezes also) Then the screen goes black like it's turned off. I look at the back of the TV and the light bulb seems to still be on.
  • 3 more comments
  • ghaz5 Jul 17, 2008
    I have the same problem but my screen is purple & green. Turning the tv only works temporarily but lines will reappear without warning.
  • Anonymous Sep 04, 2008
    How do I replace the Digital Board on the HL5067WX
  • ssutton1989 Mar 15, 2009
    i have the same green screen if i unplug the tv at night it someti me will work for about 2 hours on component but on tv mold green screen and when it starts it gets worse and have to inplug it wont even shut off from front we are 2 hours from a repair man if there is one its been this way 2 months and tv is 3 years old
  • clos119 Apr 02, 2009
    I have white and green lines going across my picture. I can't turn it off with the remote once turned on. My menu page comes up clear. It's just the cable and dvd plays. The picture also goes plank every once in a while. the comes back with white and green lines.
  • Anonymous May 10, 2009
    I have the same proplem and it is getting worse my screen looks just like the picture .
    Problem Solver:
You need to do an aggressive reset on the TV. This solved problem completely for me. You must unplug the TV when it is on. Repeat this several times until the TV is jolted back into the factory default settings. The issue is actually with the programming I believe. The clue was that the display worked 100% perfect in HDMI mode, and the problem only existed in the cable setting, no matter if wires were attached or not.
Again, do an aggressive reset to the TV by unplugging it several times while it is on. It may not register the reset at first because after all, the actual problem is a programming issue and it's having trouble recognizing commands in the first place.
Good luck!!
Posted on May 31, 2009
  • Biker Brian Aug 29, 2011
    Our power went out and solution # 2 worked after about 5 resets. Thanks so much for your help!!!
I just read solution number 2 to unplug it several times when it was on and problem solved. Oh my god!!........... and I thought I had to by a dmd board. Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jul 12, 2009
My Samsung TV HLR6156WX/XAA keeps going off, you can turn it back on and it does off again, the screen goes black first u can still hear the volume then it goes off, after it goes off the timer and lamp buttoms are flashing
Posted on Mar 13, 2011
  • David W Feb 25, 2012
    lmooney, I am having this problem too. Did you find solution?
I had the same problem. So i opened my TV being that its 3 years old and no longer covered under warranty and found the color wheel was broken. I replaced it for $136 and problem was fixed. Try this= http://www.partstore.com/Part/Samsung/Samsung/BP9600674A/New.aspx?ModelMfgName=Samsung&ModelBrandName=Samsung&ModelNumber=HLR6167W
Posted on Jun 19, 2009
2 Suggested Answers
  • 1030 Answers
SOURCE: Help me willtab guru man...Please.
What is the make and model of your television.. green tint and vertical lines indicat a problem with the light engine..although the clear menu says otherwise..im not sure what type tv you have. lcd plasma change the light im guessing you mean bulb .. this indicates to me you have a dlp. but green tint to me indicates a tube projection type tv... so im just guessing hear. vertical lines also indicate a bad buffer board on a plasma or lcd. so let me know what you have
Posted on Jun 17, 2008
Samsung tv shuts off and lights blink on off
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 25, 2016 | Samsung Hlr6167w 61-inch Widescreen Hdtv...
White spots on samsung DLP tv
DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.
Apr 27, 2010 | Samsung HL-R4264W 42" DLP HDTV
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
Problem with HL-R6167W green vertical lines
Good luck!!
May 29, 2009 | Samsung HL-R6167W 61" HDTV
Just changed color wheel on the DLand red temp light is blinking
For technical help from samsung just plug this web address in to your address bar. http://www.samsung.com/us/info/contactus.html# Pick the DLP television section and put in your model number and fill out the form for technical assistance. Or you can call this number for telephone assistance 1-800-726-7864. Hope this helps you with your problem.
May 14, 2009 | Samsung DLP HL-P5663W 56" TV
I have a Samsung HLR6167w DLP TV. When i turned it on the image slowly brightened and then heard a noise like a bulb exploding and lost image. We pulled out lamp and its burned out, but now I have a doubt...
After reading up on all possible solutions i found a local shop and bought the lamp. I asked the tech there and he told me that he was 99% positive that it was the lamp .So i installed it and its working thks
Mar 28, 2009 | Samsung Televison & Video
Samsung Model HLR6167W
Does the TV appear to be cycling on and off, like its attempting to boot up? Or, does it just not come on at all? Don't miss the lamp door interlock switch. Many Samsung DLPs have tempermental door switches. Try re-installing the door or manually hold the switch in the closed postion and try to power it up. If the lamp comes on and stays lit, you've found your problem.
michtech
Feb 19, 2009 | Samsung HL-R6167W 61" HDTV
I have a DLP Samsung HL-R6167w and it's not working
I had a bad digital board also. I went to parts.com to order a new part way cheaper than from repair service. the only problem I had was that after installation which is super easy 4 cables to unplug and replug. when I turned on the TV the picture came in upside down, not good. no one would give me the code to flip the screen as it is in a hidden menu, well after months of searching the web I found it!! It works for most all newer Samsung TV's. turn the TV off, hit mute then 182 and then power on button on the remote. the "hidden" menu will pop up and you scrool down to h-flip and flip the screen. I don't recommend messing with any of the other setting as you could likely really jack up the TV but at least you can fix it for a 3rd of the cost you would spend otherwise.
Jun 18, 2008 | Samsung HL-R6167W 61" HDTV
Samsung HL-R6167W 61" HDTV Logo
1,468 people viewed this question
Henry  Thomas
Henry Thomas
