Question about GE JE2160 Microwave Oven
GE JE2160 - 3 years old. Here's a "test" I ran
  • vincentes Nov 18, 2010
    I finally was able to fix the problem. The primary door switch (interlock) had a burned contact inside the switch body, as well as burned surrounding plastic. It would no longer "click" and tended to stay in "closed" position. [The switch is a "normally open" design (NO).] When this occurs and the door is opened, the "monitor" switch causes the fuse to blow out. GE wants $50 for this part. However, I was able to find a universal design of microswitch at Fry's Electronics. It had the same rating (15 amp at 250 volts), same body size, both NO and NC terminals, but with a lever arm which I had to remove by opening the case. Cost was $2.47 + tax. (PRICELESS!). So far so good. I also had to buy a set of Torx driver bits for tamperproof screws to be able to remove the oven cover. (The hole in the end of the bit goes over the tamperproof pin of the screw).
    I also viewed a YouTube video which was helpful at http://www.youtube.com/watch?v=YsWTCnACq...
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: GE JVM1440 doesn't work, appears to be the primary interlock
I would refer you back to my solution here. It has links for ordering parts, and it talks about securing your door switch to its mount, etc. You may need to realign things, too.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
You can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Mar 02, 2009
How do I fix my microwave oven?
At auctions microwave ovens sell for about $10. Can;t repair much for $10 so why bother. Just go to auction or garage sale..
Jul 11, 2015 | Emerson Microwave Ovens
WHAT WILL MAKE MY GE MICROWAVE WES1384SM2SS FUSE KEEP BLOWING I REPLACED IT ONCE AND AS SOON AS I OPEN THE DOOR IT BLEW AGAIN
The fuse is there to protect your home in case something has gone wrong inside your microwave. Since the fuse has blown twice, you can safely assume that there is something wrong inside. It may be fixable, it may not be economic to fix it. Impossible to troubleshoot electronics without the unit and test equipment.
Jun 04, 2015 | GE Microwave Ovens
Why is my GE Advantium SCA2001 blowing the main fuse?
Yeah pal, you've not gone deep enough yet. You'll find a power wire bare inside the unit, pull it apart and tape that wire up to stop it from grounding out and blowing the fuse.
Aug 31, 2014 | GE Microwave Ovens
Mw oven totally dead. 2 year old panasonic
No sorry there is none... look what usually happens is the magnetron, or high power diode, or Oower Supply goes faulty, a magnetron can cost between $95 - $150, or more...and usually that is NOT the only part that will/would need replacing. Cut your losses, and get a firm "Quote" from a repair center, or get a new one, with a 5 year Warranty.
Mar 03, 2010 | Microwave Ovens
GE JVM1650WB008 Microwave. Daughter used left
probably blew the magnetron or high voltage transformer DONT test either unless u discharge the capacitor possible shock risk that unit is still live even unplugged.... i wanna telll you these days that micros are disposable items because the parts are gonna cost more than just to buy a new one plus if any arching occured that same problem is gonna occur again if it did work so basicallly that miro is kapout... hope this helped
Jan 31, 2010 | GE JVM1650 1000 Watts Microwave Oven
GE SpacemakerXL Microwave Model JVM1450 It's been working great. Then put somethingin,turn it on. It ran 30sec. made a growling sound,like it was straning or slowing down,then Blew the fuse.I replace the...
SOUNDS LIKE MAYBE HIGH VOLTAGE RECTAFIER SHORTED MIC ARE VERY DANGEROUS THEY HOLD VOLTAGE EVEN WHEN UNPLUGED YOU MAY CONSIDER PRO ON THIS SORRY
Nov 06, 2009 | GE Microwave Ovens
Ge spacesaver microwave ...it is 5 years old and stopped heating
I have an over the oven microwave that blew a magnetron after 4 years. Could be the same thing. It was out of warranty for the free labor, so I took it apart (I'm kind of a geek) and found out the magnetron was gone. Shortening the story: I bought a new magnetron from an online place and replaced it and it works fine. If you have someone replace your magnetron, see if you can get it for free-they have a long warranty on the magnetron ($150 part) and at 5 years, you probably qualify. Rich
Mar 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool microwave oven
The magnetron are short need to replace / look for the old or in junk shop magnetron same serial # and etc
Jan 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
2 year old ge profile spacemaker Microwave lost all power
Inside unit is a cylinder fuse which can blow for a number of reasons. External cover needs to be removed to access. If you are confident in doing this and can find & check the fuse then it would be my first guess. If fuse is OK then you will need to have repaired. If fuse isblown & you replace then it blows again,you will need to have repaired. regards
Jul 25, 2007 | GE JVM2070 Microwave Oven
GE JE2160 Microwave Oven Logo
104 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
