Question about Haier Washing Machines
HWM60- 10 Mdel washing machine, giving E-2 error message. what to do?
futureloginn
  • 734 Answers
SOURCE: I have an Indesit washing
hi there,
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
* If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt.
To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it
doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn,
replace it--but be sure to check the pump pulley before you change the belt.
* If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin
and may not function at all. The switch is inside the washing machine main housing near the
door frame. Often you have to raise or open the top or front of the washing machine to get to the
switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside
the washing machine main housing near the door frame. Often you have to raise or open the top
or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the
motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or
badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing
machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper
spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the
clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance
repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation
the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to
burn out in one direction and continue to operate in the other. If this happens, you need to replace
the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool® have a
transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the
unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem,
you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized. These components allow the inner tub
to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during
the spin cycle. Call a qualified appliance repair technician.
For safety, washing machines are made so that they spin only with the lid closed. The lid switch
prevents the spinning action when the lid is up.
* Is there hot water coming through the proper hose? If not, check to see if the screen inside the
water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the
fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so,
completely replace it.
Posted on Dec 12, 2008
  • 380 Answers
SOURCE: Samsung washing machine gives Low Water pressure
You get these messages turned off by fixing the problem.
Low water pressure is basically one of the valves is not letting water pass through.
1. Do as you already did and clean the inlet filters. Any kinked hoses?
2. Adjust the water pressure in the house. Is it too high or too low?
3. Replace the valves in the unit.
4. Main board.
Posted on Dec 30, 2009
Daniel S
  • 4323 Answers
SOURCE: Error message F-10
Hi
Error Code F10 means Pressure switch not sensing correctly. Plesae check for the inlet water pressure. If water pressure is OK then there is an issue with the water inlet valve or pressure switch. Make sure the pipes aren't kinked or clogged. Please post back for any further assistance.
Daniel
Posted on Aug 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: Error code 105
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: EFO, E10 error Message
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Posted on Sep 16, 2010
My machine will not complete cycles
timer or control panel fault
if the water wont fill that is one error message
faulty water inlet solenoid
Jul 19, 2016 | Simpson Esprit 750 Top Load 7.5kg
Miele W 1712 is giving a waterproof fault. I tried to switch the machine of and on but the alarm is still going - I am also not able to open the door. Regards Peter
I just received this error message on my Miele W 1712 (Waterproof Fault). Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
1. Turn off the machine
2. Unplug it
3. Open the drain outlet and take out the plug.
4. Dry all the visible water with a cotton cloth.
5. Tilt the machine FORWARD and hold it until you see water gushing from underneath the machine.
6. Repeat this until you see no more water.
7. Plug the machine back inn.
8 VOILA no error message! I hope in your case :)
Jan 04, 2011 | Washing Machines
Machine stops near end of washing cycle and gives a -60 error message.
Sep 22, 2010 | Dishwashers
Samsung washing machine gives Low Water pressure error message and interrupts cycle. Checked inlet filters. Sometimes gives leak/flood warning message. How can I turn off these messages?
4. Main board.
Dec 29, 2009 | Samsung WF448AAP Front Load Washer
My LTF6700FS0 washing machine is giving me a "EF1" error message.
you could try to help it with a water vac hi hi thumbs up
Aug 11, 2009 | Washing Machines
Feb 09, 2009 | Frigidaire GLTF2940E Front Load Washer
Error code 105
Jan 29, 2009 | Washing Machines
Duet GHW9160PW0 F11 Issue
not related to shake, issue, but hte f111 and dl issue def sounds as if the connection between the 2 has been compromisdd, in my experience it has been a faulty CCU, losing communitcationsd with the door latch thus the f11
Dec 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
My Bosch WFK 2401 keeps giving me the 03 error message, the pump looks fine when I drain it manually (which takes 1/2 and hour!, now I don't bother draining it completely, I just drain a bit of water from...
hi there,
the 03 error message is the machine not sensing the water level. since you can drain using the pump manually, check the water level switch, as it may be faulty.
Oct 05, 2008 | Bosch Washing Machines
Washing Machines Logo
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
