Question about Car Audio & Video
1995 dodge ram 1500 had the radio removed. Does that have anything to do with instrument panel gauges and cruise control functionality? Can an after market stereo be put ih its place without using the existing dodge connectors.
  • 2,973 Answers
The radio has no connection what so ever with the functioning of the instruments panel or cruise control. You can install another radio/stereo in your truck without a worry.
Posted on Nov 14, 2010
Where is the signal light relay that makes signal lights flash located on 2000 ols intrigue 3.5 liter
Important: The hazard warning switch includes the turn signal and hazard warning flashers.
Removal Procedure
Remove the center air deflector. Refer to Instrument Panel Center Air Outlet Deflector Replacement .
Squeeze the retainer on the backside of hazard warning and cruise control switch.
Pull the hazard warning and cruise control switch from the retainer in the instrument panel.
Disconnect the electrical connectors from the hazard warning and cruise control switch.
Remove the hazard warning and cruise control switch from instrument panel.
Remove the hazard warning and cruise control switch bezel from the instrument panel trim pad by using a small flat-bladed tool to the release retainers.
Remove the radio. Refer to Radio Replacement in Entertainment.
Reach through the radio opening and push the retainers up towards the roof of the vehicle. When the retainers release, slide the instrument panel (I/P) center air outlet deflector out of the I/P opening
Remove the air outlet deflector
Remove the instrument panel accessory trim plate. Refer to Instrument Panel Accessory Trim Plate Replacement in Instrument Panel, Gauges, and Console.
Remove the bolts from the radio.
Pull the radio toward you.
Remove the front floor console trim plate. Refer to Front Floor Console Trim Plate Replacement .
Pull the instrument panel (IP) accessory trim plate away from the IP trim pad.
Disconnect the IP harness seat heater leads, if equipped.
Remove the seat heater switches from the IP accessory trim plate, if equipped.
Remove the IP accessory trim plate.
Nov 09, 2016 | Cars & Trucks
Dodge ram 1500 5.7 4x4 Cruise control shut off
have the cel checked need to know what the code is to diognose
Oct 09, 2013 | Dodge Ram 1500 Cars & Trucks
Climate control panel lighting is dim and sometimes does not turn on unless i knock on the instrument panel
There are tiny 12 volt DC bulbs that are soldered to the circuit board inside the climate control head, you must remove the module, take it apart and replace those bulbs. You can buy the bulbs at Radio Shack Part #7219
Feb 15, 2012 | 2008 Dodge Ram 1500
Need to replace instrument cluster/AC bulbs
Hello, You can obtain a 2004 Ram Factory Service Manual with all of that information available from Promanuals.net. The reason why it may be so important is because right before the removal instructions the service manual has diagnostic instructions to try. There are numerous pages on removing the instrument cluster, and cluster bezel.
(1) Disconnect and isolate the battery negative
cable. (For Airbag)
(2) Remove the cluster bezel from the instrument
panel. (Refer to 23 - BODY/INSTRUMENT PANEL/
CLUSTER BEZEL - REMOVAL).
(3) Remove the four screws that secure the instrument
cluster to the instrument panel structural support
(Fig. 5).
(4) Pull the instrument cluster rearward far
enough to access and disconnect the instrument
panel wire harness connectors for the cluster from
the connector receptacles on the back of the cluster
housing.
(5) Remove the instrument cluster from the instrument
panel.
Oct 01, 2009 | 2004 Dodge Ram 1500
How do I do it to get to the radio?
Here is a link with a factory service manual showing step by step procedures with pictures and diagrams. 2006 Dodge Ram Service Manual
1. Disconnect and isolate the negative battery cable.
2. Using a trim stick C-4755 or equivalent (plastic trim removal tool from auto parts store),
disengage the retainer clips that secure the instrument panel
center bezel to the instrument panel.
3. Disconnect the wire harness connectors and
remove the center bezel from the vehicle.
Sep 26, 2009 | 2006 Dodge Ram 1500
1998 dodge ram 1500 Cruise control , speed
Look under the hood to check and make sure there is two steel wire cables connected to the throttle body. i had the same problem on my 02 dodge ram, turns out that just one of the cables came loose
Sep 08, 2009 | 1998 Dodge Ram 1500 4WD
2002 dodge 1500 sport speedometer or cruise control
The brake and ABS light both come on when you are receiving no speed signal. Most likely the speed sensor in the top of the rearend is bad.
Feb 16, 2009 | 2007 Dodge Ram 1500 Quad Cab Sport
All dash panel instruments fail
Speed control sensor,located on the rear axle.If it goes out,it takes instrument panel with it.
Jan 03, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Cruise Control
in the fuse panel right up under the instrumental panel.
Jun 02, 2008 | 2001 Dodge Ram 1500 Truck 2WD
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
