Question about Frigidaire FDE336RE Dryer
Have a frigidaire heavy duty dryer, and the power cord black wire contact actually melted (none of the other colored wire contacts are damaged). What caused this, and what is the best way to fix this so that it will not happen again?
    President:
  • 1,891 Answers
When the cord was installed the nuts on the terminal post didn't get tightened properly . this will cause heat and will burn the wire off. to repair correctly replace the terminal block and the power cord . .. you can use a wire nut and repair the wiring . but the wires may bee too short to do this . mm hope this helped . feed back pls and thanks for using fix ya ..
Posted on Nov 14, 2010
Will the power cord on my Kenmore Washer 80series work on a Frigidaire front loader
If you are referring to the 3 pronged 110volt black electric cord, the answer is yes. If you mean an extension cord, the answer is yes if it is heavy duty. ( 15 Amp.)
Be sure to hook it up correctly, with the hot wire going to the correct connection inside the machine.
God bless your efforts.
Apr 15, 2016 | Kenmore Washing Machines
Diagram for installing 4 prong dryer cord on Frigidaire crown dryer
4 wire dryer cords usually have 4 colors to hook up. The dryer will have 3 screws usually in a straight row. White goes to the center screw. Red and Black can go to the 2 side screws on either side of the white. Doesn't matter which side or which color just so red is on 1 side and black on the other side. The 4th wire should be green. It is a secondary ground and can go to any screw in the dryer body. If you see a green screw near the terminal block use that for the green wire.
Mar 28, 2015 | Frigidaire Dryers
Frigidaire le0215es0
Hello byseltrd03 - Try resetting the dryer by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the dryer back on. Check that the power cord is not damaged. Otherwise the dryer may possibly be experiencing more serious issues such as; wiring failure, faulty control board, thermal limiter, or defective door switch. Should all troubleshooting measures fail, I strongly recommend contacting a local professional for further diagnosis. You can often locate qualified servicers by visiting the manufacturer directly.
May 10, 2013 | Frigidaire Electric Dryer
Frigidaire FRA 155MT1 melted the extension cord and surge protector
You must use a heavy duty power cord with this unit as it draws alot of amerage. Most regular extension cords csnnot handle the amperage and overheat or melt.
Jul 07, 2012 | Frigidaire 15,100 BTU Heavy Duty Window...
What is the order of the green,red,white and
Red goes with the red, usually right side. Black on left white in center and green attached to metal on frame.
Oct 23, 2009 | Dryers
Electrical wiring
The green is the safety ground, it goes to a contact that is directly connected to the body of the dryer. A dryer cord is usually a flat thing with the wires that have lugs crimped on them. Usually the power wires are black, and the neutral wire is white. It's usually difficult to put it on wrong, so if it goes easy, it's probably right.
Apr 27, 2009 | Maytag MDE308DAYW Electric Dryer
Dryers Logo
62 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
