Question about Watches
Hello I have a hitachi 50v500 and the repair shop says it needs a power supply circuit where can I buy one of those they just put in a light engine 11 months ago which Hitachi covered the part but I paid the labor which was around 400.00 I do not want to spend anymore money like that to fix this tv they want now 552.00 for this repair and Hitachi will not help this time, this set is about 4 years old please can you help me
  • 2 more comments
  • coryg38 Jun 18, 2008
    hello I have a hitachi 50v500 tv the light engine was just replaced 11 months ago and hitachi covered the part and I paid the labor of about 400.00 now the tv broke again and the repair shop says it needs a power supply circuit which will cost about 552.00 and hitachi will not cover anything this time I do not want to pay this much again on this tv I want to try to fix it myself where do I get the power supply circuit from
    Comment by coryg38, posted on Jun 18, 2008
  • coryg38 Jun 19, 2008
    Sergeant:
  • 243 Answers
If you can identify the capacitor on the power circuit that is bad you can identify the part number and purchase it right here.
on that website you will find all the capacitors and IC's that are in your tv. there a few dollars a piece. You can use a capacitance meter to test the capacitors. and ic's. you can do that as i will describe below.
A Capacitor is Low R when discharged and becomes High R after fully charging, and can be checked conveniently in the Ohms range. It is possible to check a capacitor in-circuit ( and we do it all the time...) with a capacitance meter (DMM or VOM) in the resistance range. The charge current through the Ohm-meter probes will charge the Capacitor. This will show increasing "R" until it dissappears with an over load or out of range indication. Changing the range to a higher "R" setting may show the maximum resistance of the capacitor. The discharge can now be measured by setting the Ohm-meter to the V range. Leakage is a function of the time taken for the Voltage to drop down to Zero. ( a good capacitor will not allow V to drop to zero).
i hope this helps you so you can fix your tv for probably 30 bucks. as long as you can identify the capacitor or ic that is blown as i described above. Let me know if you need any other information as i am glad to be of assistance.
thanks,
Nathan
Posted on Jun 19, 2008
  • Nathan Ayers
    Nathan Ayers Jun 19, 2008
    then when you find the ic or capacitor broken. and if you can get a circuit guide either online. Or by purchasing the repair manual on the unit. You can identify the broken part. You can also use the marking on the broken ic or capacitor as they always have identifying marks. wether they be lines, numbers or letters. hope this helps.
    Thanks,
    Nate
  • Nathan Ayers
    heres the repair manual it is in 2 parts
    click here for part 1.
    click here for part 2
    here is the power board on ebay for 25 dollars and the guide will walk you through it.
    click here for powerboard.
    hope this helps.
    Nathan
    President:
  • 2,712 Answers
Simple solution? Get rid of it and buy a new TV..A light engine problem generally would indicate a problem with the
power board.you can try to fix it,, but it will cost you a lot, whereas you can get a new piece for a good rate with a warranty. I
f you wish, I can give you a suggestion to fix it, but it wouldn't be worth your while...
  • Swilin Sampson
    Swilin Sampson Jun 19, 2008
    Well, you can get the circuit board from HERE.
    If you buy their manual, then you get free online service, but once again, I dont recommend a temporary fix. Better you buy a new TV..Cheaper option, and well worth it..
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 77 Answers
You can find all the parts you need here:
http://www.partstore.com/Model/Hitachi+Ltd/Hitachi/50V500.aspx
and here are manuals for the hitachi so you can fix it yourself without payig high costs:
http://www.eserviceinfo.com/index.php?what=search2
Posted on Jun 18, 2008
    Master:
  • 788 Answers
The power supply board for your TV is part # JK08574-A, Google it and you will find multiple sources for it. Ebay would probably be your best source.
    Guru:
  • 859 Answers
I wouldn't spend another dime on what is clearly a lemon. My best advice to you is to cut your losses now and get a better TV.
It's not a fix but a very strong suggestion. This TV of yours is already a money pit and that will only get worse. The board you need to replace is not cheap.
Take your issue to the BBBOnline.org and fight until you get a full refund for everything. Now, that... will be worth your time and effort.
BTW, anyone who has to ask you for a fixed rating before working the problem through with you is never any help to anyone and they get kicked off the board eventually. So, beware of those types.
Should you want to continue to pursue this I suggest you look up Robotek or BestDarnGood through out find expert link on our home page. Both of these tech are board fixers and not just board replacers
Regards,
Worldvet
    Master:
  • 638 Answers
Http://servicemanuals.vstore.ca/
www.tv.manuals.com
above links provide affordable service technician and parts.also if u hve a tecnical knowledge n want to repair it urself the second link will provide u with repair guide in a very easy way with diagrams n step by step instructions.
feel free 4 further assistance n keep sending more question n comments or doubts that arise in ur mind regarding this to me.rate the solution as fixya if it helps u understand n solve ur problem
    Genius:
  • 3,422 Answers
Please CLICK HERE and browse the sub components.
If you need anymore help let me know.
    Brigadier General:
  • 3,614 Answers
It seems that the TAG was on problem on watches...
anyway may i know the exact model of the unit.. and please add more info on this...
micro
Put new battery in pulsa chronograph 100m watch how do I get it working Plz help
You might need a jump start the watch, or cleaning. I usually try using a air dust blower ball to get all the particles that is invisible to the eye, you can do this on the movement and around the battery area. Aftwards try inserting the battery again then pull out the stem and move it clockwise at least 10 times passing the 12'o clock marker. If the watch is not brough back to life you can try one last thing before buying a new movement or taking it to the watch repair shop. If you take it to watch repair shop they might charge you a few bucks to jump start the movement. I hope this helps. Marcelo
Oct 22, 2013 | Pulsar Chronograph Watch
Need a coil & circuit for a cartier 90
Cartier watches are NOT DIY projects. If you open that watch yourself or take it to a 'regular' non-Cartier repair shop, you may as well throw it in the trash because you'll have destroyed it's value AND Cartier will not touch it after it's been opened by anyone other than their shops. That would also void any warranty protection you may have. You can Google Cartier to find a shop nearest you, call them, they'll advise you further.
Sep 25, 2012 | Cartier Pasha, 38mm, 18kt, 2 Timezones,...
Needs battery. do we get one and put it in or have a specialty repair shop put one in?
Thank you for contacting FixYa.
You will need to find a local repair shop that can reseal after putting in new battery, or send to :
http://www.luminoxshop.com/luminox-repairs.html
Best regards. Jewel
Sep 08, 2010 | Luminox Navy SEAL Dive 3901 Wrist Watch
Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
Aug 18, 2010 | Timex 2J611 Watch
Hello. I want buy watchband with Fossil JR-9641
mcdevito75 here, best bet, look mfor a small watch repair shop in your area for a new band. You can also shop Ebay for that new watch band.
Aug 10, 2010 | Watches
The light in my watch stopped working. How do I get it fixed? It is a Timex Indiglo(ladies) I don't have any other info.
Most watches of this type have 2 batteries - 1 for the light and 1 for timekeeping. If you use the light a lot, you may have flattened the battery but the watch keeps going because it's running on the other battery. Take it to your local jewellers/watchmakers/watch repair shop and get them to test the battery and replace if flat. If the battery isn't flat and the light doesn't work then you have a faulty watch - if it's still under guarantee fine, if not buy yourself another watch if you can't put up with the fault.
Jul 29, 2010 | Timex 27191 Wristwatch
Ca i put new clockworks in an old clock face - i have a vintage coffee pot clock with a light up perculator that i love- the clock no longer works-the light does- can i just buy a clock mechanism from a...
mcdevito75 here, If the old clock works are Quartz, you may not be able to get a new Quartz movement as it may not be made anymore, BEST BET, look for a small watch repair shop in your area, I'm sure they can do something.
Jul 11, 2010 | Watches
I have a Ebal watch 1187141 and I am looking to buy links for it. Any suggestions. I emailed Ebel and they never responded. Garth
mcdevito75 here, hello garth, keep trying Ebel on line, Check on Ebay, or a small watch repair shop in your area for the links and to save on cost.
Jun 15, 2010 | Ebel Classic 1187141/1225 Wrist Watch
Winder is lost
You need a replacement stem and crown. I would replace the stem just to be sure you arent putting a new crown on a damaged stem.
Sakgen is very good about repairing their watches. Unfortunately this doesnt fall under their warranty but the repair directly through them is an average price for this part.
Generic after market crowns are also available at local watch repair shops. Make sure that if you go this route that you select a shop that can reseal the watch to is water resistance rating so you do not void your lifetime limited warranty on the movement. This mean they must have a pressure testing chamber and be able to supply printed proof of resealing.
Sep 23, 2009 | Skagen 355LGSC Wrist Watch
Mens bueche girod 9k gold watch the gold band is 1 inch short
You have two options and for both you need to find yewellery repair shop.
Option1) Some jewellers sell NOS (New Old Stock) gold watch bands. If your vallet is thick enough for this option- shop around and buy one.
Same jewellery repair shop will be able replace the old band with the new one, even if the band is soldered to watch case.
Option2) In the same shop ask if they can built up (lengthen) the clasp. In this case you will spend less money, but you will loose on looks.
Note: As mostly all gold watch bands are maschine made, it is allmost impossible to repair or lengthen them in a good looking way. Anyway- consult the jeweller first and see what he says. He may have some NOS witch is exactly matching your old watch band pattern.
Good luck.
Jan 01, 2009 | Watches
Watches Logo
459 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
