Question about Radio Shack Pro-94 Scanner
Scanning Hello! My Radio Shack Pro-94 scanner scans all the frequencies in all 4 banks but I am unable to hear anyone talk! I entered all the frequencies in last night around 8pm. It is now 3pm the next day. It has been on 24-7 and so far I have heard NOTHING! What is the problem?!
    President:
  • 2,761 Answers
The problem could be your location, altitude, antenna, or wrong frequencies for your area. Here's a link to Radio Reference where you can check their database for active frequencies in your area.
http://www.radioreference.com/apps/db/
Posted on Aug 09, 2009
My scanner will only scan bank 1 and 2
When your scanner is scanning normally (in only banks 1 and 2 at this point) just hit the number for the banks you want to scan. To remove a bank push that number again. Make sure it the scanner is actually scanning when you do this.
Regards, Tony
Apr 22, 2011 | Radio Shack Pro-82 Scanner
Hi - I don't know any frequencies to enter on my PRO-94. Is there a way that I can just scan all local channels?
You can run service searches as described in your manual to locate active frequencies, but those won't help with trunked systems. You can find a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, by visiting:
www.RadioReference.com
Bill B.
Listening in since the 60's
Mar 06, 2011 | Radio Shack Pro-94 Scanner
800 MHz frequency Mode problem
You have to program it TRUNKING mode when you enter the control channel frequencies. It is decoding okay as the MO shows motorola control channel and +DG means digital decoded and an OPEN group. You need to press the 'trunk' button everytime a talkgroup comes up that you want it to remember for future 'closed' group (-DG) talk groups. I suggest you go to 'RadioReference DOT com" and there are many forums there for your radio, as well as one or two YAHOO GROUPS specifically for your scanner. 73's
Jul 03, 2010 | Radio Shack Pro-2096 Base Scanner
Pro 96 scanner only scans bank 3 and 4. i am sure
While it's scanning, press any keyboard number (0 thru 9) to activate/deactivate scanning on the corresponding bank.
Need the full manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc71/71778.pdf
For a comprehensive database of active frequencies and systems in your are,visit:
BillB
Jan 09, 2010 | Radio Shack Pro-96 Scanner
No freqency numbers showing when scanning
this is normal ....thats the banks its scanning freq. or tags only show when it stops try reading the manual or downloading one....
Nov 01, 2008 | Radio Shack Pro-97 Handheld Scanner
Trunking frequencies
Did you initialize your scanner? If you did, then you also deleted your trunking banks (1-9). These are the banks that store the channels that were inputted by you. The scanner will display "All channels locked out," when all of these banks are empty. You may have to put the frequencies in again. I suggest using win97. There is a 30day trial. This is the only program that I know of that will work with this scanner.
The pre-programmed channels should still be there. If you press and hold the scan button for a couple of seconds you should see the signal stalker running.
Good luck.
May 02, 2008 | Radio Shack Pro-97 Handheld Scanner
Scanning Freq
According to the manual the Pro 94 should cover that frequency.
Please note, certain frequencies are blocked in some countries. I see no reason why 217.031 should fall into this category although the closest may be 217.030 which should be close enough
Take a look at the manual >HERE< which should help you to program your scanner.
Best wishes...:-)
Mar 17, 2008 | Radio Shack Pro-94 Scanner
Scanner not working
Did you use a software program or have radio shack program the scanner for you? If so, check to make sure the banks were selected in the software to be enabled. I assume the your scanner shows 0123****** Now to manually select banks, simply press the number for the selected bank to both select and de-select as warrented. When you press 4, bank 4 will now be scanned. Also, should you press 1, bank 1 will not be scanned.
Feb 08, 2008 | Radio Shack Pro-96 Scanner
162.550 NOAA weather frequency
If your still having the problem, it could be that the transmitter for that freq lost some of it's power, so your scanner cannot pick up a clear signal. If everything else is working ok, that's my guess. Hope this helps,,, Mechanic
Nov 15, 2007 | Radio Shack Pro-94 Scanner
Radio Shack Pro-94 Scanner Logo
63 people viewed this question
Top Radio Shack Radio Communications Experts
Iron
Iron
Robert McClure
John
John
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
