Question about Quasar Heating & Cooling
Dripping inside We have thru the wall air condition started dripping inside
    Champion:
  • 254 Answers
You need to check the condensate drain plug. It will be on the backside of the unit either in the left or right corner of the unit.
Hope this helps Ya please rate me.
Posted on Jun 22, 2008
Wall air conditioning unit is dripping water into my condo
I have a 20 year old one that drips after a while on a hot day. I put a small bowl to collect it. It could be old or the ac unit ins't tilted enough to go outside.
Sep 07, 2012 | Kenmore Heating & Cooling
Air condition wather in the interior car
Could be the drain tube is partially clogged. It is usually located on the fire-wall or down towards the floor pan under the car. It is usually close to where the A/C lines go thru the fire-wall. About 1/2 inch diameter sticking straight out but may have a 90 degree elbow pointing down.
Also, it's been extra hot and humid all over and moisture could be freezing inside the unit when on MAX A/C, then suddenly melting when switched to normal. This opens the outside air door and allows warm/hot air into the unit instead of recirculating the cold air inside the car. The drain may not be able to handle a large, sudden quantity of water.
Perform a "driveway" test. Open the hood, start engine and run the A/C on normal with the windows or doors open. Locate the drain tube by looking for water dripping. Once located twist 2 or 3 pipe cleaners together and verify the tube is clean. Then close the doors/windows and switch to MAX A/C. Check for water dripping. If it stops dripping, water is freezing inside and now you know why!
Aug 28, 2011 | 1998 Jeep Grand Cherokee
Just had the idle air control motor replaced and within 1 day, the a/c stopped working and a lot of fluid saturated the front passenger side floor board. Can this recent repair be related to this issue as...
You might take it back to who ever changed the idle air control motor and ask them about it. They could have knocked the drain tube out, or plugged it to stop it from dripping on them or the floor.
You can try this...
Aug 28, 2011 | 2001 Mitsubishi Montero Sport 4WD
Can't find the drain line for ac. water is leaking in side on pass side
Aug 22, 2011 | 2001 Daewoo Lanos
Plugged ac evaporator drain hose 2004 mitsibishi endever
I take it that condensate from the evaporator is leaking inside on the floor. Could be the drain tube is partially clogged. It is usually located on the fire-wall or down towards the floor pan under the car. It is usually close to where the A/C lines go thru the fire-wall. About 1/2 inch diameter sticking straight out but may have a 90 degree elbow pointing down.
Aug 17, 2011 | 2004 Mitsubishi Endeavor
Air conditioner leaking in passanger floor boards how do i fix it
Also, its been extra hot and humid all over and moisture could be freezing inside the unit when on MAX A/C, then suddenly melting when switched to normal. This opens the outside air door and allows warm/hot air into the unit instead of recirculating the cold air inside the car. The drain may not be able to handle a large, sudden quantity of water.
Aug 12, 2011 | 2003 Pontiac Vibe
The unit starts to drip water inside the house down the wall of the window that it is in
What you will need to do is reposition the window unit to where it is slightly tilted downwards in the rear so that the water flows out the backside.
Jul 06, 2011 | LG Goldstar GWHD5000 wall/window Air...
Dripping inside! The unit is also dripping outside (as I guess it should) but now has started dripping inside after about a half hour's use. The angle of the unit has not changed. Could there be a clog...
The base of the unit is like a tray which collects all the condensation water. At the back of the unit (the part that normally sticks out the wall/window) there is a small tube where the water comes out. It is possible that this hole is blocked up with dust that the unit has drawn in and once it gets wet will block the water run off tube or pipe that can be fitted to it. If this tube is not cleared the tray will fill up and over flow everywhere. Hope this helps you.
Aug 02, 2010 | Friedrich QuietMaster KS15L10...
Air conditioning
Run the A/C, and look under the vehicle for water to be seen dripping out on the road. If no water is dripping, you have a blocked A/C condensate drain tube. This drains the water that the A/C removes from the air in the pass compartment (humidity), and drains it outside of the vehicle. Look under the dasjh, pass side, towards the center. The tube runs thru the body. It must be clean or water will back up and eventually leak inside your vehicle.
Jul 30, 2008 | 2007 Toyota Yaris
Heating & Cooling Logo
138 people viewed this question
Top Quasar Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
