Question about The Step2 Company Step 2 Clubhouse Climber In Box
I need to completely disassemble my clubhouse climber is that possible? I want to move it inside and in order to fit it threw the door the roof and legs and slide will need to come off. Im worried that some parts arent ment to be apart after first assembly.
3 Suggested Answers
SOURCE: Disassembly of Little Tikes Wave Slide playground
Hi there! On putting together my daughter's hide and slide (not having ordered it or seen it before) followed the instructions and managed to put the bottom step inside the frame instead of outside. Of course other half only noticed it once I had put the top step in - so to take it apart you will need the following:
Two long heavy duty flat bladed screw drivers and a lot of muscle!
First take the top platform on one side and disengage the two tabs on one side. Then insert one of the srewdrivers under the red locking tab and push up - the plastic will distort however, returns to original shape with judicious use of a heavy hammer. You will need to use the second screwdriver to disengage the clip in the tab and then twist the platform out of the frame to release the second. Repeat for the other side. The bottom platform is a just a reversal of the installation to release. I haven't moved the slide but as this is a 'gravity' fix should release with a bit of 'persuasion'. As these things are not designed to be taken apart after assembly they are frustrating to take apart - but with a little flex and muscle it can be done. Hope this helps.
Simon
Posted on Aug 02, 2009
rulds2008
  • 3866 Answers
SOURCE: climber side won't fit
Might be a manufacture flaw you need to click on the link below, create a account then file for a return autherization number.
STEP2
Not much else you can do but return it back to the retialer and see what they can do. Boxes get resealed all the time and you might have the wroung part or a defective part.
Posted on Dec 18, 2011
Testimonial: "Thank you very much for the reply! I am going to call STEP 2 tomorrow. Hope you have a nice holidays."
How do I disassemble a stairmaster
This link will take you to a service/owner's manual for the 4600PT - at the very end is the parts diagram that might help you dismantle the machine or at least let you know what type of hardware you will be coming across and how it goes together:
http://www.sportsmith.net/images/product_support%5Cstairmaster%5CManuals%5C42-44-4600PT-CL_Red-LED_Display_Freeclimber_Manual.pdf
Feb 09, 2014 | Stairmaster 4600PT Stepper
Step 2 big climber instructions
I have a big climber step 2 that might the older mode. I need to see how to assemble it
Aug 24, 2013 | The Step2 Company Step 2 Clubhouse Climber...
Parts
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This cable can be ordered from our Website. Please have your exact model and serial number ready. The following link will take you to our Tectrix stepper page.
Tectrix Cybex Stepper Parts Climbmax Personal Climber 2000 3000 Model 150...
May 07, 2013 | RTO Tectrix Personal Stair Climber
My Kitchenaid khms155lss-2 has a problem latching completely. Once finally latched the microwave would start and then stop during the cooking time because the door became unlatched. I have to stand by the...
Ok.Agreed,latch is not cracked or worn out.But check the grip of latch.Open the door.The hold the latch in your hand and see,if its loose or tight.It should be tight.Press the latch towards down and move it left/right slowly --- slowly.And inspect the latch.It will move,there will be a moment but the position of the latch in the door frame should be tight.If you feel that latch is got very loose,then the door frame needs to be disassembled and latch assembly has to be repositioned and fitted.In most of the cases this latch breaks/cracks and it needs replacement.But in your case,its different,you mentioned that if you keep your oven door pressed then latch remains closed..So if latch is broken/cracked it will not get closed properly.So as per that i think,you will have to check the opposite side of the door frame,where this latch gets into.On that side,there is a interlock type part.Which holds this latch.That part is operated by spring.If in-case that interlock type part or the spring,any of this is got loose then latch will get released after few minutes.--------------- But first as regular troubleshooting,you inspect the latch.Do you feel its loose or getting very easily moved,then open the door frame and check the latch.----------- For that you will required door disassembly diagram:--- Click the link,see part number 3 is door latch.-------- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W0505176-00002.png -------------- If the latch is properly positioned and intact then ,you will need to disassemble the opposite side cabinet to check the internal part,which hold the latch.For that you will require complete disassembly:---Click this link for complete disassembly:-- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Microwave-Parts/Model-KHMS155LSS2/0593/0123370?pathTaken=&prst=0&shdMod=KHMS155LSS2 -------------- The door latch itself or other parts holding the door latch,none of the part is costly then $10.The cost of part is under $10.---------It just require you to figure out,either is cracked /broken part or just loose misaligned part.-------- This will help.Thanks.Helpmech.
Feb 10, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
The key is that one side/side combination must be done 1st then the others are easy. On ours I think it is the yellow/orange combination. Just try all the combinations. One works pretty easily, the others do not. We struggles too until we found the right combination. good lluck
Jul 09, 2009 | Toys
Door Removal
If you don't have the manual, go to Samsung's website and download the manual. It explains how to remove and adjust the doors and bottom drawer.
Jun 23, 2009 | Samsung RF265AA Bottom Freezer French Door...
The Step2 Company Step 2 Clubhouse Climber In Box Logo
637 people viewed this question
Top The Step2 Company Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a The Step2 Company Toy Expert? Answer questions, earn points and help others
