Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Hi, only have first light (pre wesh?) flashing, pump runs but nothing else happens??? Any ideas on the fault?
  • Indesit Master
  • 3,247 Answers
Looks like the flood switch is activated. The dishwasher has detected a leak in the motor compartment and it shut down and tries to pump water out. Turn the power off and pull the dishwasher out. Tilt it to one side and then put it back in. This should move the water out if there are any leaks. Turn the power back on and check operation.
Also try the Rapid 25' cycle and see if the behaviour is any different.
Posted on Nov 14, 2010
Hi we have a Hotpoint Aquarius FDAL28 dishwasher. Machine turns on, drains and fills but then 3 lights keep flashing and washer stops programme. Any ideas what problem could be?
Depending on which lights are flashing, there is either a problem with the electronic control module, or the pump is stuck or has a motor failure. You can see which by comparing which lights are flashing with the pattern on this page of error codes:
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3293-hotpoint-fdl-series-dishwasher-fault-codes
Jul 15, 2017 | Hotpoint Washing Machines
When I turn on my unit the cooling light flashes but nothing happens
Your unit may have a wall control which can set the Evap cooler to a pre fill mode time which fills the base with water then there is a pre wet mode which starts the pump to wet the pads. After both these functions have completed the fan will start. This could take up to 4 minutes before the fan starts and can be programmed out if not required.
Nov 25, 2014 | Heating & Cooling
Why didn't the diagnostic test work?
Sounds like one of the sensors is giving a false indication. If you don't get help here try getting advice at RepairClinic.com
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 14, 2014 | Kenmore HE2 Plus Front Load Washer
Brew switch not responding
your not far,
test your switch with a test light
or you could always jumps the wire direct to your pump
if nothing works check for parts on ebay.
Jan 06, 2014 | Gaggia 102534 Espresso-Color...
Flashing pre-wash approx 1 hour into wash cycle instead of moving onto rinse and wash. Whats causing this? This is happening on the WMA50.
Hi! If the pre-wash light flashes it means you are not getting enough water in the machine, check the pressure chamber, pressure switch, fill hoses and valves. For a workshop manual on the WMA50 which includes fault finding, visit www.selfix-uk.co.uk
Feb 17, 2011 | Hotpoint WMA50 Front Load Washer
Hotpoint aquarius fdw20 fault lights
take base plate off and check for debris in the wash pump
Jan 11, 2009 | Dishwashers
Flashes 8 times ADP 5340
Again Pressed the main button for about 15 sec that did reset the fault
larf
Apr 20, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
420EX Flash and Preflash Shooting all power
I have exactly the same problem with my 580EX flash, can you let me know if you find a solution?
Thanks!
Joelle
Jan 05, 2008 | Canon SPEEDLITE 580EX TTL Flash
IDL705 dishwasher showing error code
Indesit IDL700 first two green lights flashing and cycle stops with dirty water left in the machine. CAUSE - blocked or jammed drain pump. SOLUTION - First remove all the filters inside the machine, syphon or sponge up all the water in the sump and check for any obstruction over the fine grill at the very bottom. (we had a pistachio shell covering the hole!). If this doesn't cue it you will need to gain access to the pump. First, turn off the power. Gently lift the machine onto it's side (be ready for some water to spill out!). Remove the bottom plate (6 screws) and disconnect the sump float switch. Remove the single screw retaining the pump to the bottom of the machine and rotate to remove. You should be able to see the rotor blades. With your finger check to see if the pump rotates freely. To dismantle the pump, remove the 3 screws and separate the two halves. Our pump was jammed with an apple stalk!. Reassemble and connect any cables. Apparently this is a known problem with these machines and can be prevented by assembling the filter system correctly and pre-rinsing plates etc. before placing in the dishwasher.
Sep 19, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
99 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
