Question about Mmats D210005 Car Amp
I have a mmats d2000.05, I need to know how to wire up three 4 ohm dvc subwoofers and get the full power out of this??
2 Suggested Answers
zzedly
  • 300 Answers
SOURCE: mmats d500.2
  • It is capable of driving a 2 ohm load.
  • It is a single channel amp, so bridging is not applicable. There are two speaker connections, true, but they are tied together internally.
  • It's rated at 500W @ 2 ohms
  • The issue you're going to have hooking up the subs you own is that you're not going to be able to optimize the output of the amp. If you hooked all of them up in parallel (both 15w0 as well as the dual voice coils of the 15w6), you'd be putting a 1.7 ohm load on the amp, which it may not like. In my mind, your best bet is to either put both 15w0's in parallel (125W per sub) and not use the 15w6.....OR.......use only the 15w6 with the dual voice coils in parallel (350W to the sub).
Posted on Mar 12, 2008
I have an old school autotec xs 1500.1 and need to know how to hook up the outs to make it 1 ohm
Since it is a mono block amp, it depends on your subwoofer (s), and how you wire them to the amp.
Single 4 ohm sub would be just that, 4 ohms.
Single dvc 4 ohm sub, with both voice coils wired parallel would be 2 ohms.
2 dvc 4 ohm subs wired parallel would be a 1 ohm load.
Feb 20, 2015 | Ohm Car Audio & Video
I have 2 15" dvc 4 ohm kickers 1000 watt / 500 rms &a1000 watt avionixx 4 channel amp what would be the right wiring scheme?
need to know the ohms on the amplifiers then might can tell you best solution for system
Mar 05, 2013 | Car Audio & Video
I have a rockford fosgate 1001d and 2 audiopipe dvc 12s need 2 know how wire speakers
Check to determine if your sub woofers are DVC 4OHM or DVC 2OHM SOLUTION 1 If your sub woofers are DVC 4OHM then, from the positive (+) of the amplifier run your cable to the positive terminal of voice coil 1 on sub woofer 1 then continue to connect all the positive voice coils together on both sub woofers. Do the same for the negative from amplifier to all the negative voice coils of both the sub woofers. RECAP: all positives together on the positives and all the negatives together on the negatives. This will give you a 1 OHM load to the amplifier making it deliver all its power but will also run hot. So if you are living in a hot climate take care. SOLUTION 2: Connect the negative on voice coil 1 to the positive of voice coil 2 on sub woofer 1 Do the same for subwoofer 2 now you should have a free negative and a free positive on each of the sub woofers. connect the free positives together and follow through to the positive on the amplifier. do the same for the free negatives sending them to the amplifiers negative. This will give you a 4 OHM load to the amplifier. Not full power in this mode but the most stable working condition for your amplifier. SOLUTION 3 If your sub woofers are DVC 2 OHM then you only have one reasonable wiring solution. Connect like solution 2. This time because of the DVC 2 OHM sub woofers you would have a 2 OHM load to the amplifier. This is also a stable load for the amplifier and does not generate to much heat and still deliver over 50% to 70% of the amplifiers power. good luck and drop me a line if you still have doubts. dreamsystems
Feb 10, 2011 | Car Audio & Video
I want to know the best subwoofer wiring diagram for three kicker cvr 10 inch subs, 2 of them are dvc 4 ohm and 1 is dvc 2 ohm, the amp that i am using is jl audio 500.1 1.5-4ohms stable. can anyone help...
if the amp has a 2 outputs then i would wire the two 4ohms together, and the 2ohm by itself. and if its a 4 channel output then wire them all sepretly, if its a 1 channel output then wire the two 4ohms together and leave the 2ohm sub out
Nov 29, 2009 | Kicker CVR10 Car Subwoofer
Wiring options
Hello chino2g,
For 3 DVC 4 ohm subs wired to a 2 ohm stable amp, your best option would be to wire all of the sub voice coils in series (individual 8 ohm loads) and then parallel the three subs for a final load of 2.67 ohms. There's really no other configuration. Here's the wiring diagram:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4
Hope this helps.
Sep 07, 2009 | Hifonics HFi HFI12D4 Car Subwoofer
Need to wire two dvc 15 in kicer l7 to 1 ohm
Hello goldy6569,
To wire the L72's at 1ohm, simply connect both +'s and -"s on each sub together. Then connect to your amp terminals.
With 2ohm DVC's, you can have either a 1ohm load or a 4ohm load. The diagrams are here (I know it's the website of a Kicker competitor, but their "wiring wizard" is simply the best).
Hope this helps.
Jul 16, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I need to know how to wire my 2 12' kenwood w3514 dvc sub woofers parellel
For parallel connections, simply wire posotive to positive and negative to negative. But beware! this lowers the impedence (ohms) by half. In other words if you have 4 ohm woofers, in parallel they would be two ohms. Make sure your amp can handle that. Otherwise connect them in series.
Apr 04, 2009 | Kenwood KFC-W3514DVC Car Subwoofer
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wiring Diagram
i HAVE 2 12 KICKERS L7 RUNNING ON A PERFORMANCE TECHNIQUE AMP 2000 WATS THE ampl its a mono //and i want to know how to wire the speakers
Jul 26, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Mmats D210005 Car Amp Logo
60 people viewed this question
Top Mmats Car Audio & Video Experts
Tygh Duval
Tygh Duval
Tariq Waheed
Tariq Waheed
Level 1 Expert
Are you a Mmats Car Audio and Video Expert? Answer questions, earn points and help others
