Question about Cycling
I need the main suspension pivot bolt for a club roost dh8 mountain bike or at least the diagram of the suspension, do you where i can get either of these?
  • Kris Thomas
    Kris Thomas Jul 18, 2012
    Hi, i have the same problem, i really need a diagram as i'm going to a engineering company hoping they can fabricate me one, there is a company called BETD that can help you but it's 40quid just for the pivot.
Kree8iv
  • 192 Answers
SOURCE: front suspension to soft on mongoose xr-75
The front forks aren't adjustable, as you probably figured out. You can, however, get harder springs if the springs can be accessed at the top of the fork tube. If not, do what I did on my mountain bike. I bought a better pair of adjustable forks that I found on eBay. It will take a bit of investigation on your part regarding the dimensions of the forks, so you get the correct length and width where the forks fit onto the frame (and the overall desired fork length), but you'll be a lot happier with adjustables.
Posted on Jun 14, 2009
  • 1138 Answers
SOURCE: Suspension adjustment for a 2007 Shogun Hydra
Have a look at this site:http://www.bikeforums.net/archive/index.php/t-15120.html and this site might help http://www.bikewebsite.com/suspension.htm You will have to either search for the manufacturers site and look for the adjustment info there( you should be able to download the manual for the forks ) or mention the specifics here so we can find them. According to my info your bike should have a Suntour SF-M3010db fork on it.
Posted on Aug 29, 2009
  • 484 Answers
SOURCE: How to stop the creaking sound in a new full
Well that's a hard problem to solve without having the bike here, not hearing the noise. Make sure your chain is lubricated (with bike chain oil, not WD40), because this is the foremost cause of weird bike noises in my experience. The other thing, is it a Target/Wal-Mart/CostCo/Etc bike? these bikes have REALLY inferior parts and they will indeed squeak and squeal.
Regards,
matt
Posted on Sep 14, 2009
dunnbiker
  • 8546 Answers
SOURCE: Need to know where to
Any Bike Shop.
Posted on Mar 15, 2011
Coachphil
  • 347 Answers
SOURCE: I stripped the bike down
Does you shock have side to side play, if so then the washers or at least some of them go there. Without seeing and knowing what frame, parts and in general what you are referencing it is rather difficult to be precise.
The shock should be the easiest to determine as it should be mounted so that all the space is taken up along the mounting bolt. if there are gaps the washers go there.
Posted on Mar 29, 2011
Why dose my rear shock on my 250 dirt bike make a cracking noise
try each suspension bolt in turn just so they are loose and move suspension up and down , as i think that one of the bushes could be dry of grease! when was the last time the rear suspension system and the swing arm pivot spindle was removed and greased up ?? some pivot points mite have a grease nipple , but i suggest if this is the problem to remove and clean bolts and the holes then grease up so to last ! depends how much you use the bike in wet or sandy conditions as when to repeat this also !!
Feb 18, 2014 | 1988 Honda XR 250 R
Mongoose mozo m30 forks are sponggy
Change the spring to your load.
Adjust Mozo M30 Fork Suspension - Beckman Du-70 Forum
efratoium.xyz/Adjust-Mozo-m30-fork-suspension/
Results 1 - 15 of 15 - Mongoose XR 150 mozo m30 front forks rebuild. A quick ...Mongoose mozo m30 forks are sponggy on my XR150 mongoose mountain bike.
mozo??- Mtbr.com
forums.mtbr.com/shocks-suspension/mozo-167281.html
Feb 20, 2006 - 15 posts - ‎6 authors
... of a mozo m30? is it the junk im assuming came on my mongoose? ... into a halfway decent bike. and all i can get off the fork is mozo m30 ...
Mongoose XR250 Suspension Upgrades ' Bicycling Magazine Forums
forums.bicycling.com/topic/54635607127666779
Sep 30, 2012 | Mongoose Exile 26 Men's Full-Suspension...
What type of mountain bike are they?
There are six main types of mountain bikes. These include: comfort, hybrid, hardtail, single speed, full suspension and freeride. One of these types of bikes will fit your style and riding needs. Talk with a bike salesperson to determine which one will work best for you.
Dec 16, 2010 | Cycling
How much should I spend for a mountain bikes?
As much as you can stand. For the first-time mountain bike buyer, the cost of mountain bikes may be a bit shocking. As a general rule, you'll pay the following: Junk hardtail < $300
Light-use hardtail $300-500
Intermediate hardtail $500-800
Race-ready hardtail $800-2,000
Boutique hardtail $2,000+
Junk full-suspension < $800
Light-use full-suspension $800-1,500
Intermediate full-suspension $1,500-2,000
High-end full-suspension $2,000+
My sram x-7 derailleur hanger broke and i bent the derailleur. I've replaced the hanger and re alligned the derailleur but i went to bolt the derailleur back onto the hanger but the bolt doesnt seem to be...
You need to replace the main pivot bolt, something (most likely a tab) is broken. This one is best taken to your local bike shop for inspection. There may be something your missing like a crack in the body or another broken part. Link to Manual.
You can also contact the SRAM customer service for support, but they will refer you to a shop to take care of the problem and order any parts on this type of problem.
Dec 14, 2010 | Sram X7 Mountain Bike Rear Derailleur
Polaris rmk mtn bike or victory vegas low mtn bike. Which is a better buy found them both for around the same price
The Polaris RMK and Victory Vegas Low are the exact same bike with different colors and names.
They are made by Ming Cycle in Taiwan and are distributed by an American company-----Cycle Force Group.
The Polaris and Victory are Ming's top of the line dual suspension mountain bike, they have upgraded wheels, front disk brakes and 19" frame. If color doesn't matter to you, then the Victory Vegas Low is usually the better deal.-------Can be found on Amazon, Wall mart, Miejer.
The Polaris and Victory generally have the best reviews and ratings of any dual suspension mountain bikes priced below $250
May 13, 2010 | Victory VegasLow 26 Men's Dual-Suspension...
Dont know how to put the rear shock back onto bike
Diagrams are available in the website under the support tab. Just note the you have to remove the crank on the right side to get to the nut that holds the lower eyelet into the frame (torque nut (not the bolt) to 120in/lbs with a torque wrench.... yes you have to use the torque wrench.... Push the bottm bolt in first then the top one then tighten both to 120in/lbs. The brain hose should bend under the main pivot nut and then inside the rear triangle and brake hose. Torque the bolts to 70in/lbs. Go ride!
Sep 23, 2009 | Specialized Bicycle Components Specialized...
I need a new bash guard for my mongoose sector bike. how do I find a matched replacement?
The bolt hole diameter and number of teeth on your chainring is all you need to know. These parts are universal to match the aftermarket standards foe cranks. 104mm (x4 holes) is the most common in newer bikes. You can look on eBay or any online bike store.
Regards,
matt
Sep 14, 2009 | Mongoose Sector 26 Men's Full Suspension...
Cycling Logo
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
