Question about Hitachi Health & Beauty
How to clean the blades of hitachii trimmer CL- 5210 with video assistance
Why does cordless trimmer squeak
always make sure the equipment is unplugged from the electricity before doing any work on it.
hi I don't know why your trimmer squeeks but it could be that it needs grease in the cam housing. if you have to ask this question perhaps you should ask a friend who has experience of maintaining this equipment to give a little advice, assistance.. https://www.youtube.com/watch?v=A76t0u0pS68
Sep 07, 2014 | Sears Craftsman C3 19.2 Volt Cordless...
What is andis outliner II correct blade alignment?
Please go to youtube andis to watch instructional videos. If you are still unable to align your blades please call our customer service dept at 1-800-558-9441 for assistance.
Jul 13, 2014 | Andis Outliner II Hair Trimmer
I need to clean and sharpen a model hh2450 hedge clipper blade. How do I remove/replace it?
You do not have to remove the blades to sharpen. There is a good instructional video on sharpening hedge trimmer blades on youtube. The guy that did it is ereplacementparts i think.
I hope this is helpful for you.
Aug 30, 2011 | Black & Decker Garden
Weedeater Excaliber Gas Hedge Trimmer. Is it possible to sharpen these blades? If yes, do you know the procedure?
You should be able to sharpen your hedge trimmer blades. There is a good video on how to sharpen hedge trimmer blades on youtube by ereplacementparts. He explains how to do it with a file or a grinder.
Aug 24, 2011 | Weedeater Excalibur Gas Hedge 22" Trimmer...
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
Took trimmer apart to clean and now can`t get it together again only the blade top.?
Does the blade and cover plate for your clippers look something like the items shown at the following link:
http://www.amazon.com/dp/B001D51JW4/ref=asc_df_B001D51JW41502580?smid=A38ADCQOZZ1ZLQ&tag=dealtmp5133-20&linkCode=asn&creative=395105&creativeASIN=B001D51JW4
Sometimes you have to fit one side of the blade in first and then then force the two little holding prongs closer together in order to fit the other side of blade down too.
Here is a quick video on YouTube which shows the blade replacement procedure for a few different types of clippers:
http://www.youtube.com/watch?v=dYgN9HZDRrE
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
Apr 12, 2011 | Health & Beauty
I took it apart to clean it but, like a dummy cannot put it back together. dog trimmer model 9765
Your style came with a DVD, can you find that??? I just can not find a manual that is in print form to assist you, sorry!!! Guy
Sep 12, 2010 | Wahl 9765-301
Sideburn trimmer does not cut anymore but still makes noise. trimmer blade does not move.
It is pretty common for the trimmer to get jammed up with hair particles and skin oils which can prevent the blade from moving.
Try running the blades of the trimmer in a shallow dish of rubbing alcohol. Then clean the blades vigorously with an old toothbrush or similar. If the blades still does not move try using the tip of a small flat screwdriver or similar object to push and advance the moveable blade. Repeat running in alcohol and brush clean
If this doesnt work, you will probably need a new trimmer
Apr 15, 2010 | Braun 360° Complete 8985 Electric Shaver
Trimmer not working
the trimmer may be jammed with hair particles. clean the trimmer blades really good with an old toothbrush dipped in rubbing alcohol. you can also turn it on with the tip of the trimmer blade dipped in a shallow container of alcohol.
if your trimmer blade is sufficiently clean and still doesnt work, the rocker arm that moves the blade must be broken. Remington does not offer replacements for the trimmer part
Jan 16, 2010 | Remington Microflex R-842 Electric Shaver
My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Jul 09, 2009 | Black & Decker Black Decker 16" Hedge...
Health & Beauty Logo
134 people viewed this question
Top Hitachi Health & Beauty Experts
ray gallant
Stan Ford
Are you a Hitachi Health and Beauty Expert? Answer questions, earn points and help others
