Question about Samsung Televison & Video
My samsung tv model le23r86wd keeps turning its self of after bout 5 sec. do u have any ideas.
    Genius:
  • 1,126 Answers
The power supply is what is causing it to shutdown, and if you replace the bad electrolytic caps, or the power supply it will fix the problem.
Posted on Nov 14, 2010
Hi I have a THORN hd smart tv 55' turns on but then just black screen sound is fine can change the channel but can't see a thing tried unplugging it holding power button down for 60 sec
I have a 55inch thorn TV not a smart TV Tho n it keeps randomly turning off day and night n once it flicked from hdmi channel to normal TV channel, no set some or anything I'm worried a fault or boogidy, it's bout 5 or 6 years old n only been doing it the last week ??
Mar 31, 2017 | Televison & Video
Samsung le23r86wd wont turn on after capacitor changed
Did you change all the capacitors on the power supply section? There are usually 4 or 5 caps that are used in this section.
Dec 04, 2014 | Samsung Televison & Video
Mitsubishi 65733
CONTACT MITSUBISHI TECH SUPPORT, THEY SHOULD BE ABLE TO GIVE YOU AN IDEA OF WHERE THE PROBLEM IS WHEN YOU TELL THEM THE ERROR CODE, THEN LOCATE A HONEST TV TECH FOR A ESTIMATE.
Feb 02, 2014 | Mitsubishi Televison & Video
Dynex tv powers on and than goes off
I would start with a look at the power supply for puffed up caps.
Dec 13, 2012 | Dynex Televison & Video
Have a Samsung LNS4695 DX LCD about 3 1/2 years old. When powers on will take about 5 secs and then picture but has thin, multicolored vertical lines. After turning off and on a few times, picture is...
yes this is due to bad caps I have replace dozens of caps for samsung tv's you can do it your self or have some body do it for you or ship the power board to me
Sep 04, 2010 | Samsung LN-S4695D 46 in. LCD HDTV
I have a completely black screen on my tv, but i am hearing sound
Ur tv have convergence problems,it dead.U must know how to solders,have soldering tools,and solders to fix convergence problems.U must replaced 2 STK Convergence ICS,and some or all it resistors.Tries wesites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 08, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Turns on and turns off.
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. OR your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV. Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
PROBLEM WITH SAMSUNG DLP TV
disconnect the power and hold in the power button for 30 seconds to reset it.
Feb 20, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
645 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
