Question about Canon PIXMA MP150 All-In-One InkJet Printer
I lost my manual , and i don't know what is letter B on left side ....blinking....when i start print
  • 37 Answers
MATE U CAN DOWNLOAD THE MANUAL FROM THE CANON SITE FOR FREE
Posted on Nov 14, 2010
HOLD light on dash is blinking
Flashing probably means you need to have it diagnosed or serviced. If it's on steady read this:
There's a switch just in front of the shift lever (it's an automatic transmission but with an "on the floor" lever). It's a toggle switch. On the left side is the letter P and on the right is the letter H. Pressing the P side down, the letters PWR appear on the left side of the dashboard instrument panel. Pressing the H side donw, the letters HOLD appear on the right side of the instrument panel. Evidently, those are important enough options to include in the design of the vehicle. If I can track down an owner's manual, I'll update you with the purpose of those options.
Oct 03, 2012 | 1998 Kia Sportage
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
When typing the letter don't appear
If they don't print until you hit the return key you are in the delay print mode, use the print mode key on the R. side to get out of it. If it isn't printing at all the plastic print solenoid cap is broken. We sell them with shipping and instructions for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Jun 13, 2011 | Lexmark Wheelwriter 5000 Typewriter
Model PT-1900/1910 operational manual is lost.
I assume that you need the manual for your printer.
Here you can download:
http://www.ptouchdirect.com/ptouch/manual/PT1900.pdf
On page 26-28 it explains what you need to do to change the size of letters.
Apr 09, 2010 | Brother P-Touch 1900 Label Printer
Print carrier hangs on right side and sounds like a broken plastic gear, printer will nor work
you can try to pull manually the print head in left side to see if there are any plastic parts in the right side. but be carefully and don`t force to much. Usually it have to force just a little to slide the print head in the left position. You will figure out if something is blocking the print head. If you successfully slide the print head to left side try to take a close look in the right side to see any plastic parts. Use a flash light or turn the printer upside down if is necessary.
Feb 28, 2010 | Dell 948 All-In-One InkJet Printer
Printing envelopes
Open a MS Word Document, select 'Tools' then 'Letters and mailings' then 'Envelopes and labels...'
Envelopes and Lables dialogue box opens - ensure you are on the 'envelopes' tab
Then type your recipient address in the larger white box
for standard letter envelope (DL 220m x 110mm) - Insert envelope into Brother HL-2030 manual feed, with print side up, gummed flaps down and to the left side (bring gray plastic guides in close to secure).
Then select print.
I have found that during the feed, one end of the envelope gets a little bit crumpled but overall it's still a little bit more professional looking than my handwriting.
Jan 12, 2009 | Brother HL-2030 Laser Printer
PRINTER CUTS OFF RIGHT SIDE OF PAPER
First, on your computer desktop. left click on START. Next, left click on CONTROL PANEL, and left click on PRINTERS. Find your printer on the PRINTERS window, and RIGHT CLICK on the icon. From the drop-down menu, left click on PRINTING PREFERENCES. Use the settings to set up the printer for the paper size and orientation you want to use.Click APPLY , then OK buttons to apply any changes you make. If that does not help,check the side paper guides in the paper source you are using. If they are not against the paper on both sides, the paper will not align properly with the image. Move the guides snug but not tight against the paper. If the guides are too tight, paper may not feed. If moving the guides does not solve the problem, try loosening the guides and reposition the paper until the image is properly aligned. Then see in your owners manual if there is an adjustment called SIDE-TO-SIDE REGISTRATION, and follow the proceedure to adjust the side-to side paper alignment.
Jul 16, 2008 | Dell 3100cn Laser Printer
Printer switching orientation
Make sure that manual feed is set to letter, on the printer front panel. This is a tabloid printer, so letter size sheets are fed long edge. The cassette will print okay because the media size info for the cassette is read by the printer from the cassette cams.
Dec 21, 2006 | Xante 4G Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
27 people viewed this question
old marine
old marine
