Question about Sylvania LC320SS8 32 in. LCD Television
It turns on and then turns right off - Sylvania LC320SS8 32 in. LCD Television
    Genius:
  • 1,126 Answers
The power supply is weak and needs changed, or replace the bad electrolytic caps on the power supply.
Posted on Nov 14, 2010
06 H3 Hummer right turn signal goes on by itself can't turn off
Turn Signal Lamps
The FRT/TRN/HAZ/CRTSY/MIRR and REAR/TRN/HAZ fuses in the underhood fuse block supplies battery positive voltage to the body control module (BCM). When the turn signal switch is placed in either the left or right position, a signal is sent to the BCM to illuminate the desired turn signal lamps. The BCM has an internal flasher that sends an ON-OFF voltage signal to either the left or right turn signals and their instrument panel cluster (IPC) indicator. When the hazard switch is pressed, a separate ground signal is sent to the BCM to activate and flash all turn signal lamps including both IPC turn indicators. The front and rear turn signals are grounded at G105, G350 and G340. The sound for the turn signal indicators is produced by the IPC.
DTC B0525 Left Turn Signal Circuit
• DTC B0527 Right Turn Signal Circuit Low
• DTC B0528 Right Turn Signal Circuit High
• DTC B0529 Right Turn Signal Circuit Open
DTC B0530 Right Turn Signal Circuit
• DTC B0532 Left Turn Signal Circuit Low
• DTC B0533 Left Turn Signal Circuit High
• DTC B0534 Left Turn Signal Circuit Open
Could be a switch problem , short to ground on the signal circuit to the BCM , BCM seeing a input that shouldn't be there etc....
I would have it checked for DTC'S diagnostic trouble codes .
Jun 10, 2017 | 2006 Hummer H3
Turn signal light right flash
flasher/blinker is busted. this is located under your dash board. remove steering column cover, turn on LEFT turn signal (yes, the one that is working), then you will hear a clicking sound. locate the relay that causes the sound. there you can see 2 relays (one for LEFT, other one for RIGHT turn),replace busted one.
Jun 11, 2013 | 2002 Toyota Tundra
How can i reset the service warning on a 2000 tdi golf?
  • Turn on ignition.
  • Hold down Right trip button and continue to do so whilst turning off ignition.
  • Still with Right trip button held down turn ignition back on.
  • Release Right trip button.
  • With ignition still on turn Left trip button to the Right and release.
  • Turn off ignition.
Nov 27, 2009 | 2001 Volkswagen Golf
Sylvania LC320SS8 32 in. LCD Television Logo
85 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
