Hi, I have just had my hard-drive put onto another motherboard and now have no sound. The motherboard is GA-8SMLNF and I was told that I just needed to download sound drivers for that motherboard and it would work... Cant seem to find any at all that match. Please help!
  • 162 Answers
Get it from Here: http://driverzone.com/device.php?id=1370141
Download and install
Thanks
DiegoTech
Posted on Nov 14, 2010
Testimonial: "Thanks for that:) it's great when someone gives advice that helps! Had sound as soon as I went to restart."
Gigabyte GA-965GM-S2 motherboard keyboard, mouse, monitor won't work.
You need all the drivers, each peripheral has it's own driver that needs to be loaded.
Nov 28, 2011 | Gigabyte GA-965GM-S2 Motherboard
I have a GA-81PE775-G motherboard, will a WD5002AALX (sata-3) be compatable with this
Hi, I have reviewed the Gigabyte Motherboard that you have mentioned. It has SATA (Serial Advanced Technology Attachment) supporting 150 MB per second. Which means that the Hard Drive of Western Digital (SATA 3) which you want to connect is compatible with the SATA port of your Motherboard.
However, the SATA 3 of your Hard Drive supports 3 Gb per second. Hence it will be working in 150 MB per second when you connect to your Motherboard.
Aug 09, 2011 | Gigabyte GA-8IPE775-G (818313002198)...
Gigabyte GA-6OMM7E (GA-60MM7E) Motherboard have not display, please solution to me.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 07, 2011 | Gigabyte GA-6OMM7E (GA-60MM7E) Motherboard
Hi my friend: please help me for select HDD. 945GCM-S2L Max HDD Support? 945GCM-S2L <- this mainboard supported 2TR Byte?
This motherboard suports SATA (Serial ATA 3Gbps) meaning that it is compatible with any SATA hard drive. A 2TB (Tera Byte) hard drive is the highest capacity available on the market. This motherboard has 4 SATA connections so you can put up to 4 SATA hard drives into it.
Mar 15, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
GA-K8VM800M MOTHERBOARD The problem with the board is that, initially it got the message that disk boot failure, after checking bios settings, still it got same message. I have changed the IDE cables...
Try making your hard drive as the first boot in the bios and just connect your hard drive only on the motherboard ( remove cd/dvd drive, etc..). Make sure your hard drive is detected in the bios. Then restart your computer again.
Oct 11, 2010 | Gigabyte GA-K8VM800M Motherboard
Need max memory and hard drive size for Gigabyte GA-5AA motherbrd
Max Supported of your motherboard memory is 768 MB SDRAM DIMM(100,133,166,200 MHZ). You can find the full specifications here:
http://latam.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1439
Thanks for using Fixya
Jul 28, 2010 | Gigabyte GA-5AA Motherboard
I have no sound from my ga-k8nsc-939 motherboard after installing windows 2003 server.
Hi friend,
You need to install sound card drivers for sound.you will find out mother board CD so update your sound card drives then you can hear sound....
With Regards
Jan 01, 2010 | Gigabyte GA-K8NSC-939 Motherboard
Setting up gigabyte ga-686lx3 verion motherboard
Here's a link to where you can get the manual free and it will show you the jumper options and all. Hope this helps.
http://www.motherboards.org/mobot/manuals/Gigabyte/GA-686LX3/
Mar 29, 2009 | Gigabyte 440LX (GA-686LX3) Motherboard
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
