Question about HP DeskJet 3940 InkJet Photo Printer
Printer error or busy
Any ideas to how to resolve this? Happens when printer is attached to wireless print server. Ok when in usb port
  • anggitiarahm Nov 18, 2008
    my printe error ( busy problem ) can,t run
  • 435 Answers
Could you please explain what kind of error are you getting?
Posted on Oct 25, 2008
2490MF
Check that you do not have a firewall working. Set the printer by inputting the Ip or printer name when installing, do not browse for printer.
Aug 21, 2008 | Konica Minolta magicolor 2490MF Laser...
My print server is working with a Epson DX4400. It is all setup correctly (according to Netgear) but when I print wirelessly, it only prints half the test page and then the printer stops with an error...
U need to manually add the Printer ports ..
Install the printer driver to the computer first and make sure that we are able to print directly. Follow the steps below after putting the printer and computer back to your network.
  1. Click on Start, then Control Panel, then Printers and Faxes. Right click on the Printer and select Properties.
  2. On the printer properties window, select Ports tab and click on Add Port.
  3. Select Standard TCP/IP Port and click on New Port
  4. This will bring the Add Standard TCP/IP Printer Port Wizard, click Next
  5. In the field for Printer Name or IP Address, type the IP address of the print server and click Next
  6. Select Custom and click Settings button
  7. Under Protocol field, select LPR. For Queue Name, type P1 depending on what print server port is the printer connected to.
  8. Click Ok, then Next, and Finish.
And this will resolve the issue
Feb 06, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
Using D-link dp-300 Printer Canon ImargeClass MF4350d (Multifunction printer) Problem. I can not use scanner fanction. (no problem for printer) Without printer server, I able to use the scanner.
The problem you are having is pretty standard, the IP based printing works for most printers but the scanner require direct(or well faked, direct) connectivity with a USB port which most routers do not provide.
Several companies including Startech and Io Gear make Virtual USB devices which would resolve the issue.
How they work differs as instead of creating an IP printer, the usb device installs on an ip and then a driver you install on your PC(s) connect to the unit over the router and sets up a virtual USB port on your machine so you can re-install the printer as a local printer attached to what it thinks is a local USB port.
Doing this will allow you all functionality the printer offers but will slow down printing and scanning a bit
Hope this Helps,
Chris
Armor-IT
Apr 24, 2009 | D-Link DP 300U (DP-300U) Print Server
2nd printer on print server
Hello Kawena66,
There may be an ip conflict as the error suggest.
what is the ip address on your XP system?
Sep 16, 2008 | D-Link DP-G321 Print Server
HP LaserJet 1018 & DP-G310
Does your network have a dedicated computer server and the printer is attached to this server or is the printer attached to a dedicated print server device?
OR
Does a computer on your network shares its printer with other computers on your network?
There is insufficient information on how you configured your printer setup for me to give you a proper answer to your problem.
Jun 10, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
Converting to a wireless printer
hi,
if you hav a usb port on the printer you can make it wireless by using "wireless upgrade kit"....
u have t connect this device to the usb port on the printer and you can make it wireless. and if you dont have a usb port on the printer, you cannot make it wireless
thanks and regards
agnel
Mar 05, 2008 | HP PSC 1610v All-in-One Printer
HP DeskJet 3940 InkJet Photo Printer Logo
59 people viewed this question
Seeker5211
Seeker5211
