Question about Belkin (F6H350-USB) UPS System
I have just tried to use the f6h350 after keeping it in a cupboard for at least a year. I connected it to mains for a day, but it did not work when connected into the system. I have taken it out again and found that the battery back-up side does not work. I have lost the manual, where can I download a copy? Can I just use the UPS in a stand-alone mode - not connected to the comms ports? Richard Perry
    Top Expert:
  • Belkin Master
  • 40,500 Answers
Your UPS battery has failed for lack of charging/recharging.
Posted on Jul 27, 2017
2 Suggested Answers
  • 33 Answers
SOURCE: Compaq UPS R3000 XR Comms cable
Hi Jon,
so we could use this link it as a solution for your problem?
Kind regards,
Posted on Feb 25, 2009
What's a camp cupboard?
Camp cupboard will allow you to keep items safe and well organized, what should make the searching process very short. Camp cupboards are advised to be used only for trip with a car or a RV.
Sep 04, 2012 | Bass Pro Shops Camping, Backpacking &...
Hi, I am installing a stainless steel sink I have had made into a bench top which I will be filling with ice to keep beers cold. As there is a cupboard underneath I am worried that the ice will cause...
I would take a two-step approach.
1) Get one or two cans of polyurethane foam insulation (e.g. Great stuff). It would be easiest if the sink is not yet installed. If it is, get a bunch of newspapers and keep the area well covered inside your cupboard. This stuff will stick to anything (including stainless steel sink bottoms).
Spray the foam insulation onto the sink surface. It has a wand to spray into small areas, just make lines about 2 inches apart as you spray (more like caulking). You will seet the foam expand. Run another line of foam between the ones you made if you think it is not covering (expanding) well enough. Let it expand and harden for a day.
Part 2)
Here you want to prevent any air from getting under your sink. If you can limit any condensation to the air that is under the sink, you wont get too much water. If you allow air to circulate, then all the air passing by will deposit some dew onto your sink bottom.
Get some foam insulation strips like you want to insulate a window or door. The best option would be Frost King (EDPM) extruded profiles. Thes strips come in 3/16" and compress easily as your cabinet door closes. You might want to put spring hinges on the doors or a spring latch to keep it tightly closed.
Good luck and try to stay clean. You might want to practice on a board outside if you haven't worked with spray foam insulation before - be careful, it drips and runs a bit before it hardens so keep your lines thin as you spray..
The g
Jul 06, 2011 | Heating & Cooling
We bought a brand new lumix Dmc TZ4 about a year and a half ago from a reputable seller on Amazon. worked for two days, then without any accidents or incidents, it started saying low battery, even when it...
Hello there.
Since you already changed the battery and still having the same problem, let's try other things.
First, remove the SD card from your camera and try to turn it on. Make sure your battery has a charge.
If that works, then it means the problem is with the SD card.
Also make sure that the battery cover is locked firmly.
Try those first and then update me.
Jul 04, 2011 | Cameras
I have had my camcorder for about 2 years, it worked just fine and then all of a sudden the word "DEW" popped up and then it automatically turned itself off. So I turned it off and inserted a...
Doesn't matter where it is, if it detects moisture it will give that warning. Try putting it in the airing cupboard (NOT in its case) for twenty four hours.
Mar 12, 2017 | Sharp Viewcam VL-Z5U Mini DV Digital...
I have an unused 4 year old dometic rc4000 portable refridgerator that was checked to be working when purchased but on trying to run on mains electric today does not appear to be working (no sound to...
Aug 27, 2010 | Dometic RM2852 Refrigerator
I lost my samsung tocco lite, found it 24 hours later in my car. the touch screen is now not working but all the other buttons are. anyone know howw to fix it? i think it could hav something to do with...
hey the same thing is happening to my samsung tocco lite right now it happened yesterday when i put it on a shelf in my bathroom then i had a shower so i think the moisure from the steam got in the phone and stopped the screen working have you tried leaving your phone in an airing cupboard or boiler cupboard or on a radiator for a few days that might fix it
Dec 14, 2009 | Samsung Cell Phones
Belkin f6h-350-usb-dl no power out in the upper row
One set of outlets is surge protect and one row is battery backup. When you have a bad battery that row will not work. Remove the battery and test it.
Dec 13, 2009 | Belkin (F6H350-USB) UPS System
Have a 1993 Sony CCD-FX420 camcorder that I have not used for a few years. The tape deck opens and closes fine without a tape, but when I insert a tape it won't completely close. How do I fix this? Thanks....
It is more than likely that during the period of prolonged storage in less than ideal conditions, some moisture has entered the camcorder and rendered it useless. This camcorder is also some twenty-four years old, and all consumer electronic devices have a limited life, even if well looked after. I feel your only choice is to replace it, and keep the replacement in optimum storage conditions - maybe in a dry cupboard indoors.
Apr 03, 2017 | Sony Video Cameras
The Eurovox should be connected to your TV with the Virgin box tucked away in a cupboard somewhere!
A Eurovox is a cable receiver used instead of a Virgin or NTL box, usually to obtain access to unsubscribed channels.
What are you trying to do, perhaps I can assist with more information.
Good luck.
Jul 20, 2008 | Audio Players & Recorders
Not working
Some UPS have "Battery backup" and "Surge only" outlets. I don't know if it is the case for your model. The "Surge only" outlets are not connected to the battery and will go off during a power outage. Make sure that the equipement that need to keep running during the outage are connected to the "Battery backup".
Important: Never connect a laser printer to the "Battery backup" outlets because to power draw is just too high.
Have you made sure that the battery is connected inside the UPS? (If the battery is user-replacable)
You may do a simple experiment. Connect you UPS you a wall outlet and plug a conventionnal lamp to a battery backup outlet. Then, unplug the UPS from the wall. If the light goes off, then you may have a problem with your UPS.
Apr 19, 2008 | Belkin Home Office 350VA (f6h350-usb-dl)...
Belkin (F6H350-USB) UPS System Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
