Question about Mmats Pro 12 Car Subwoofer
JUST INSTALLD 2 - 12inch mmats 2.5 subwoofers on a mmats 2000.2 and it sounds like it is not putting out no more than 400 is there a easy way to test or find out
Air space in a ported box
a sealed box will alow more, deaper base however what you are askin a ported box is port specs min. 4" dia.x12"L- MAX. 20sqx16"L (THIS IS EQUIVELNT TO .09 cu ft min. not to excied .19 cu.ft. for better sound, this will put you at 38.2Hz. or 34.7Hz
hope this helps.
Nov 24, 2013 | Mmats Pro 12 Car Subwoofer
I have a pair of 15" procast mmats and need to replace the rubber seal around the cone. Where can i get a repair kit ?
Well i havent had just the rubber problem, I've complete recoils. Contact MMATS. They should do it. http://www.mmatsproaudio.com/ Click contact then email
Jul 06, 2010 | Mmats Procast 15 Car Subwoofer
Does mmats sell the rubber surround for a 12 inch procast? one of my procast needs a new rubber. Do i have to sent it in or can i fix it at home/
You can do it yourself if your handy. Lots of places out there selling them. Not too bad a job. Takes some patience gettiog the old one off.. If its really rubber and not foam, it'll come off in one peice. Have to be carefull the get the cone centered when ya glue the new one in. If you decide to tackle it get one with instructions and/or a good web search on the surround replacement.
Apr 06, 2010 | Mmats Juggernaut 15'' Car Subwoofer
I need the corrects specs for my 15
Heres all the specs you could ever need: http://www.shopping.com/xPO-Mmats-Juggernaut-15
Nov 18, 2009 | Mmats Juggernaut 15'' Car Subwoofer
What is the cubic feet of air space
it's a measurement used to describe the empty air inside an enclosure. When you build a speaker enclosure, such as for two subs, u build it to fit the componets air space recomendations. keep in mind anything inside the enclosure like braces or the magnet part of the speaker will deduct from the measurment.
Sep 15, 2009 | Mmats Pro 12 Car Subwoofer
Subwoofers are not hitting as they should.
you need to reseal the speaker in the box, its loosing the compressed air inside.
Hope this helps
alex
May 01, 2009 | Mmats 12 Car Subwoofer
PowerAmp for Mmats 2.0 12" SubWoofer
what model speaker. i recommend matching your MMATS speaker with a MMATS amp. Match the RMS
May 19, 2008 | Mmats 12 Car Subwoofer
Mmats Pro 12 Car Subwoofer Logo
79 people viewed this question
Top Mmats Car Audio & Video Experts
Tygh Duval
Tygh Duval
Tariq Waheed
Tariq Waheed
Level 1 Expert
Are you a Mmats Car Audio and Video Expert? Answer questions, earn points and help others
