Question about Microsoft Xbox 360 Console
Hardware problem my xbox 360 hardware is damaged
  • 3 more comments
  • Anonymous Jun 20, 2008
    hardware failure
  • Anonymous Jun 22, 2008
    I have recently been attacked with the red ring for my Xbox 360 because the hardware is damaged. Everytime i turn it on it freezez then several times it would just become the red ring in the ring of light, but now it just goes completly red when i turn it on. What can I do?
    I have recently been attcked with the red ring on my Xbox 360 console. All i know is that it is because the hardware is damage or it does not function. Sometimes when i turned it on it would work normally then it would freeze. Then other times I would turn it on then it would become red on thering of light. But now it just goes completely red. What should i do?
  • Julio Proano
    Julio Proano Jun 22, 2008
    I have been recently attacked by the red ring on my Xbox 360 console. Which is mainly because either the hardware does not function or it is damaged. Sometimes it would freeze when I would play, Then when I turn it on and off the ring would go red. But now the ring just goes pure red everytime I turn it on. Also it is wasting time on my Xbox live account. What should i do?
  • santoshallu Jul 20, 2008
    hardware failure on xbox 360
Simply you have a hardware failure with your Xbox 360. Fear not though, this is a VERY common fault and perhaps more so than Microsoft would like to admit.
The problem lies with overheating. The design of the clips that hold the equipment in place for dissipating heat away from the microchips are flawed. So when a potentially dangerous heat level is reached on this chips the console resorts to the "red rings of death" hibernating state that you're all now familiar with.
Fortunately, this problem is normally fixable. Either you can fix it yourself or if the unit is still in warranty (which is likely since the warranty was extended for exactly this fault and this fault only) you can have it fixed by Microsoft.
Solution 1 - I would avoid fixing it yourself unless it is the only option. Look up "x clamp kit" or similar on google and you should be in good hands.
Solution 2 - Provided you have not opened up your 360 and broken the warranty seal behind the faceplate you should be in luck. Go to xbox.com and sign in. Once signed in go to "Support" and then "Registration and Repair". On this page register your console by entering the serial #. Click on the now registered device for more details and you will see a summary letting you know if the device is in warranty or not. Regardless of whether it is in warranty or not select "Request a new repair" from the top right. Fill in the form making sure to select the red rings issue to yes. The next page will hopefully produce an invoice with a lovely figure of 0.00. Accept, continue and follow all steps provided. Microsoft will pay to send the device to wherever they will evaluate it and send another one back. Before sending make sure that you ONLY send the console i.e. remove hard drive, cables, controllers, memory cards.
As you can probably tell I have had to use this service and on the whole I have been very pleased. Good luck
Posted on Dec 05, 2008
Red light
Posted on Jun 19, 2008
What do i do when my ac adapter from my xbox 360 turns red
Your Power Supply has failed, you must replace you power supply. the red light mean there a hardware failure inside the power supply. try to unplug it as it can damage your system.
Thanks
www.1RepairStop.com
Sep 09, 2011 | Microsoft Xbox 360 Console
I was at a friends house and I was playing on the original Xbox 360 with my new Xbox Slim controller now my new xbox slim controller will not connect to my new Xbox? It was working fine before my friend...
Hmmm.....that's sounds weird. The controllers are passive devices. They shouldn't change as far as hardware behavior because they're just that - hardware. Unless the one you have has some sort of CMOS programmable feature? I've never heard of that before. The only recommendation I have is to check the pins on the plug - maybe the old xBox damaged a pin.
Feb 05, 2011 | Microsoft Video Game Consoles & Games
E74 problem with xbox
The e74 Xbox error's principal cause is overheating, due to excess heat causing damage to various components, and eventually major malfunctions in the hardware of your console. Why is this heat able to build up and cause damage that leads to the Xbox 360 e74 error? This is actually due to cramped case design and a lack of cooling devices such as fans and heat sinks. Although overheating is ususally a problem for all electronic devices, the Xbox 360 does seem to suffer particularly badly from this issue. unless you have a bit of technical knowledge than the best thing would be to A) fix your Xbox e74 problem by sending your Xbox 360 back to Microsoft for repair or B) buy a new one. there is no easy way to permentaly fix it without taking your xbox apart and the "towel trick" which is where you wrap your xbox in a towell power on until it overheats and shutsdown is only a temporary fix and will cause major damage to your xbox in the long run. fixing yourself consists of stabilizing the heat shields by removing the old brackets and replacing them with new heat paste and bolts so the best thing if you are dedicated to doing it yourself would be to probably buy a manual online. you shouldnt need to pay anything over $30 and make sure you get a full manual because alot of them only deal with the "red ring of death" (which is three red rings)
hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
I have a red light on xbox and e 74
hope this helps
Nov 27, 2010 | Microsoft Video Game Consoles & Games
My xbox 360 has a red light flashing on the bottom right quadrant of the circle and displaying system error on screen with E74 at the bottom of the screen. Can anyone help or does it need to go in for...
This problem occurs when the Xbox 360 console experiences a hardware failure.
If your Xbox 360 is still under warranty, which lasts for three years since the purchase date for this type of problem, then the best thing you can do is request for your Xbox to be fixed by Microsoft. Even if it is expired, it still best to send it in and pay the small fee, compared to trying to fix it yourself, which will most likely cause more damage.
To send your Xbox to Microsoft, visit www.myservice.xbox.com and select "Start a repair request", then follow the on-screen instructions.
Also see:
E74 Support Page
Extended Warranty Info
Oct 09, 2010 | Microsoft Xbox 360 Console
I have an e73 system error problem
E73: I/O Hardware Error - Couldn't calibrate HSIO Bus from edram: this error is likely caused by a problem with the Ethernet port or supporting control devices.
Here is a link to a temporary fix. I DO NOT RECCOMEND YOU DOING THIS as it may do more damage to your 360. USE AT YOUR OWN RISK!!!
http://gameolosophy.com/consoles/xbox/how-to-fix-xbox-360-e-73-error-temporary/
Jan 12, 2010 | Microsoft Xbox 360 Console
Can I use my HP2009v computer screen with the X-Box 360 Elite
In order to make this work you need the Xbox 360 VGA HD AV cable.
Following link will give you an image of the cable itself:
http://hardware.teamxbox.com/screenshots/screen-hires/42546/Xbox-360-VGA-HD-AV-Cable/
Unfortunately you wont be able to get the highest resolution with the cable.
Here you have a list of supported resolutions:
http://hardware.teamxbox.com/reviews/xbox-360/40/Xbox-360-VGA-HD-AV-Cable/p1/
Nov 20, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 not turning on
from your description i would say that you are having a problem which lies within the system itself, could possibly be faulty/broken electrical connections or your motherboard is damaged.
Due to this being a hardware issue, and the fact that all 360 systems have a 5 year microsoft warranty, i would suggest contacting Xbox customer support. their number can be found on http://www.xbox.com/support
Hope this helps
Oct 29, 2008 | Microsoft Xbox 360 Console
Xbox 360 will not send a picture signal to TV
sounds like you have a graphics card problem with the xbox 360. possibly loose/damaged electrical connections between the GPU and the motherboard which has caused the xbox to not display a picture. with this being a Hardware problem i would suggest calling the Xbox customer support, numbers can be found on http://www.xbox.com/support call up the support team and explain your problem.
I believe that microsoft will ask you to send the Xbox direct to them so they can fix the problem for you, it shouldnt take long to correct !
hope this helps
Microsoft Xbox 360 Console Logo
20 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
