Question about Sylvania G-Netbook
No internet connection - Sylvania G-Netbook
    President:
  • 556 Answers
F your modem isn't getting an answer from your ISP
  • 1 Make sure that the cable is correctly connected to both a phone line and your modem and that, if you're using an external modem, it's connected to the PC.
  • 2 Dial the access number for your Internet service provider (ISP) with a regular telephone and listen for a data tone. If you don't get one, then you have the wrong number or your ISP is down.
  • 3 If your modem is internal, skip this step. Unplug the power cord from your modem and shut down your computer. Plug the modem back in and restart your computer.
  • 4 If you have another modem cable that you can use to connect the computer to the modem, swap it with your current cable to rule out a bad cable.
  • If your connection is refused by your ISP
  • 1 Make sure your username and password are still correct. These are usually entered through a connection program that your ISP provided. You will probably have to retype your password, as you won't be able to read it on-screen.
  • 2 Locate the TCP/IP settings for your computer. In Windows, these are found in the Network and Dial-up Connection control panels. In Mac OS 9.2 and earlier, they're in the TCP/IP control panel. In Mac OS X, they're in the Network section of System Preferences.
  • 3 Check that the host name and domain name information are correctly entered in the TCP/IP settings. This information should have been supplied by your ISP.
  • If your connection is accepted but you can't load Web pages or send e-mail
  • 1 Call your ISP's support number to find out if you have been affected by a service outage.
  • 2 Unplug the power from your modem (whether it's telephone, DSL or cable) for at least 10 seconds, shut down your computer, plug the modem back in and restart your computer.
  • If your connection seems too slow
  • 1 Set your Windows computer to MS-DOS mode: Click on Start, Programs, MS-DOS Prompt.
  • 2 Type "ping" followed by an Internet domain name--for example, www.google.com or www.yahoo.com. Macintosh users with OS X can use Apple's Network Utility program to "ping." Earlier versions of Mac OS don't have it built in, but freeware programs are available on the Web.
  • 3 You should get a report saying how many milliseconds it took for your "ping" to reach the destination. A computer communicating with the Internet via a 56-KBps modem connection might typically have a 0.3-second (300-ms) or longer ping. Anything longer than 5 seconds (5,000 ms) indicates a problem with your connection that might be the fault of your ISP.
  • Read more: How to Troubleshoot an Internet Connection ' eHow.com http://www.ehow.com/how_113839_troubleshoot-internet-connection.html#ixzz15EpuN33C
    Posted on Nov 14, 2010
    Hi my mxq pro 4k box is connecting but not picking up internet connection. Why Also when connected message displayed is cannot play video
    The "connected" message applies to the TV, not the internet connection. To connect to the internet, either use an ethernet cable, or connect wirelessly using instructions provided.
    Jul 22, 2017 | Internet Computers & Internet
    Tip
    Set up and Use Internet Connection Sharing
    To enable Internet Connection Sharing on a network connection
    You must be logged on to your computer with an owner account in order to complete this procedure.
    Open Network Connections. (Click Start, click Control Panel, and then double–click Network Connections.)
    Click the dial–up, local area network, PPPoE, or VPN connection you want to share, and then, under Network Tasks, click Change settings of this connection.
    On the Advanced tab, select the Allow other network users to connect through this computer's Internet connection check box.
    If you want this connection to dial automatically when another computer on your home or small office network attempts to access external resources, select the Establish a dial–up connection whenever a computer on my network attempts to access the Internet check box.
    If you want other network users to enable or disable the shared Internet connection, select the Allow other network users to control or disable the shared Internet connection check box.
    Under Internet Connection Sharing, in Home networking connection, select any adapter that connects the computer sharing its Internet connection to the other computers on your network. The Home networking connection is only present when two or more network adapters are installed on the computer.
    To configure Internet options on your client computers for Internet Connection Sharing
    Open Internet Explorer. Click Start, point to All Programs, and then click Internet Explorer.)
    On the Tools menu, click Internet Options.
    On the Connections tab, click Never dial a connection, and then click LAN Settings.
    In Automatic configuration, clear the Automatically detect settings and Use automatic configuration script check boxes.
    In Proxy Server, clear the Use a proxy server check box.
    Bhautesh.
    on Feb 24, 2010 | Computers & Internet
    Connected wireless to router, excellent signal, but unable to connect to internet.
    connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
    Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
    good luck!!
    Oct 07, 2011 | Linksys Wireless-G WRT54G Router
    Hi, Having problems connecting the PS3 to the Internet?
    There are two ways to connect to the internet there is Wireless or Wired connection here is how to do both:WIRELESS (WIFI):
    Step 1: Turn on the PS3
    Step 2: Once on main menu go to settings and under settings select "Network Settings"
    Step 3: Select "Internet Connection settings" if prompted that you will be disconnected from the internet select "Yes".
    Step4: Select "Easy" on types of installation.
    Step 5: Select "Wireless" to choose what kind of Internet connection you want.
    Step 6: Select "Scan" to search for internet access points.
    Step 7: Select your home connection when the screen comes up with all the found access points. If your home internet access point requires a password enter the password when prompted and save your settings.
    Step 8: Test the connection to check if you configured your settings right if successful you are good to go. If not go back and check your connection settings for your home internet access point. You are now connected to the internet!
    HARDLINE (Wired): Must connect ethernet cable to PS3 before turning it on!
    Goes like this: Arrows are the cable (===>)
    Internet Line ===>Router ===>PS3
    Step 3: Go to "Internet Connection" and select it to Enable it.
    Step 4: Select "Internet Connection Settings"
    Step 5: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
    Step 6: Select "Easy" on types of installation.
    Step 7: PS3 will automatically check your connection network setup and set the settings for you.
    Step 8: The settings will appear and press x to save the settings.
    Step 9: Test your connection if it was successful you will see succeeded nest to "Obtain IPAddress" and "Internet Connection" you are now connected to the internet!
    Feb 28, 2011 | Sony Playstation 3 (PS3) Console
    How to connect PS3 to the internet?
    Step 3: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
    Step 5: Select "Wireless" to choose what kind of internet connection you want.
    Step 7: Select your home connection when the screen comes up with all the found access points. If your home Internet access point requires a password enter the password when prompted and saveyour settings.
    Feb 27, 2011 | Sony Playstation 3 (PS3) Console
    I am trying to setup a internet connection using yahoo what do i do
    Sir,only using yahoo connection it will not provide to setup internet connection.
    For internet connection you have to configure all the component which provides you to connect with internet.
    These configuration requires LAN card,LAN driver,modem,NIC card,phone and internet service provider to assist the internet to activate the internet.
    Apr 12, 2010 | Computers & Internet
    I got a Dell desktop computer from a friend who bought it new. It only has a dial up connection so I got it hooked up. Problem that I have is it won't dial out to connect to the internet. Ralphie
    Hi dlwbaw
    You have to make a new connection.
    Go to "Control Panel", find "Network Connections", double click on that, here you choose file (in the menu) and choose "New Connection". Follow the Wizard (choose, new connection to the internet, connection without code/username/password, and normaly people have DSL connections).
    Try to connect the pc to the internet now, this should work, if not:
    you have to have the setup way from your internet provider, many times they have a manual on the internet. If it is a connection with user name/ code, you have to Edit your friends internet connection (icon on network connections) or make a new connection with this codes.
    The codes you get from your internet provider
    Some internet providers allow only one computer connected to the internet.
    Hope that helps
    Have a nice Sunday :O)
    Please rate my answer
    Sep 06, 2009 | Dell Computers & Internet
    I AM UNABLE TO ACCESS INTERNET THRU MY HYBRID APPLE MAC DESK TOP-
    Go into network set up a shared Internet connection using ICS (Internet Connection Sharing) You can use Internet Connection Sharing (ICS) to share an Internet connection among two or more computers on a network. First, you need one computer, called the host computer, that is connected to the Internet and that has a separate connection to the other computers on your network. You enable ICS on the Internet connection. The other computers on your network then connect to the host computer, and from there to the Internet through the host computer's shared Internet connection.
    If your computer is connected to a network, network policy settings might prevent you from completing these steps.
    On the host computer (the computer whose Internet connection you plan to share):
    1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Network Connections.
    2. Right-click the connection that you want to share, and then click Properties.getcontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=signed1 If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
    3. Click the Sharing tab, and then select the Allow other network users to connect through this computer’s Internet connection check box.
    Jul 22, 2009 | Computers & Internet
    Wireless connecting
    Regarding your message, all I have to do is click on the internet Explore icon and I am connected to the internet. The wireless service is connected all of the time. My adapter connection is a VIA Rhine II Fast Ethernet Adapter. Hope that this will help you. TKS...
    Jan 14, 2008 | Computers & Internet
    Sylvania G-Netbook Logo
    139 people viewed this question
    Top Sylvania Computers & Internet Experts
    Mike
    Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
