Question about Arris SURFboard SB5120 Modem
I have a MOTOROLA SURFBOARD SBV5120 CABLE MODEM and the LED FOR lINK IS ALWAYS AMBER. I'M RUNNING Windows XP AND ITS SLOW. Is this the problem?
FLASHING AMBER LINK IDICATOR LIGHT ON MY SB6121 MODEM
The SB6121 link light uses color to indicate the connection speed. Blinking means data transfer is taking place. Blue means that it's a 1000Base-T (High-speed Gigabit Ethernet). Amber means it's an older ethernet device. 100Base-T or 10Base-T Ethernet connection.
Nov 06, 2012 | Arris SB6121 SURFboard DOCSIS 3.0 eXtreme...
I have the Motorola SBV5120 SURFboard Cable Modem now because we upgraded to optimum now i do not know how to find the WEP Key on this modem please help me
The Motorola SBV5120 cable modem does not have wireless capabilities and therefore does not require WEP encryption key. There is no WEP setting available for this cable modem.
Jul 02, 2011 | Arris SURFboard SBG900 Wireless Router...
I had Windows XP and i upgraded to windows 7, and in XP my internet worked properly via cable modem Motorola Surfboard SB5101, and now with windows 7 on my bottom right side corner of the computer where...
I suspect it is a problem with your drivers,Have you installed drivers and utility CD? if not please do that.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 08, 2011 | Arris SURFboard Cable Modem
I wanted to know what is the best wireless router compatible with motorolla SBV5120 cable modem? thank you very much
The Motorola SB5120 SURFboard® is a very popular, solid and reliable cable modem compatible with most cable providers. If your modem is two years or older, upgrading to the SB5120 has been known to show speed improvements up to 3X faster than older DOCSIS 1.0 modems. Set up is simple and fast.
  • Compact design: With its attractive and compact design, this cable modem won't clutter up your work space
  • Easy to maintain: Simplify troubleshooting with the handy font-panel LEDs and built-in HTML-based diagnostics
  • Stand-by switch: Disconnect the signal without unplugging the modem with the top-mounted stand-by switch
  • DOCSIS™ 2.0: Take advantage of DOCSIS 2.0 technology for up to three times greater upstream capabilities than older modems running on DOCSIS 1.1
Linksys BEFCMU10
Quick to set up at a great price, the Linksys BEFCMU10 offers fast connections to your cable broadband provider. Connect it directly to any PC with an available USB or Ethernet port, and you're ready to surf the Internet. With the Linksys Cable Modem, you'll avoid monthly rent charges, and make the most of your high-speed cable Internet connection.
  • Compliant with all industry standards: DOCSIS™ 1.0, 1.1, and 2.0 - compatible with any cable Internet provider
  • Ports: Ethernet, USB & Cable
  • Buttons: Reset
  • LED Indicators: Power, Internet Cable, Internet Activity, Ethernet & USB
  • Easy installation: One phone call to your Internet service provider completes the setup
D-Link DCM-202
D-Link's DCM-202 Cable Modem is powered by TurboDOX™ bandwidth acceleration software increasing your download speeds up to 20 times. The DCM-202 makes your broadband connection more efficient and effective by clearing network congestion, resulting in a boost in download speeds. With the DCM-202, you will get more out of your broadband connection with increased bandwidth and enhanced performance.
  • Always On, Always Connected
  • DOCSIS™ 2.0 Certified
  • Ethernet or USB Connectivity
Netgear WGT624 Super G 108 Mbps Wireless Router Netgear's WGT624 108 Mbps Wireless Firewall Router is 10 times faster than 802.11b routers providing 4x the range of 802.11b devices, and double the range of most other 802.11g products. Your home network is secure with over 10 security and privacy features including a double firewall and wireless encryption. Netgear's Smart Wizard set up software gets you connected in 5 clicks or less!
  • Interoperable with existing 802.11b and 802.11g networks
  • Smart Wizard gets you up and running in fewer than five clicks
  • Lighted power, test, Internet, wireless and LAN status icons
  • Works with most Internet gaming applications that support Universal Plug and Play
Dec 12, 2010 | Computers & Internet
IS THERE A WINDOWS7 DRIVER FOR the sb5100
Hi
Try to install the same driver for Windows xp
in windows 7 in Compatibility Mode
For running in Compatibility Mode in windows 7
Right Click the app and select the properties
select the Compatibility Tab
select the os =windows xp sp3
and dont forget ti tick "Run ad Administrator"
Download Here th driver(xp)
Feb 10, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Solution
Here's a user guide http://broadband.motorola.com/noflash/customer_docs/user_guides/510984-001.pdf
but basically all you do is
  • screw the coax (tv cable) to the rear of the Motorola modem
  • connect the power to the modem and wall outlet
  • plug an ethernet cable into the rear of the modem (looks like a very wide telephone jack)
  • plug the other end into the WAN or Internet port of the Linksys router
  • plug the power into the router and wall
  • if wired, plug another ethernet chord into a LAN port on the router (probably numbered 1,2,3,4) and then plug the other end into your PC/Laptop
  • if wireless, an usecured network should now show up when you search for a wireless network (named LINKSYS or something)
if all is well and DHCP is enabled by default you should be online.
Jun 10, 2009 | Arris SURFboard SB5120 Modem
System can't Install the MODEM Drivers
You would need to install the USB drivers from the Motorola disk as windows does not have these USB drivers natively.
Jul 03, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Ativa wireless G router
you're welcome, lugraziano!
Thanks for leaving a rating, I'm also happy that I was able help you out. Happy browsing, and thank you for choosing FixYa!
Cheers!
Apr 26, 2008 | Computers & Internet
Installation cd
SURFboard® General Frequently Asked Questions ... your SURFboard cable modem are Ethernet and USB cables, power cord, an Installation Assistant CD ... Do Motorola SURFboard cable modems ... My SURFboard SB4220 or SB5100 cable modem
Click on the above link find the drivers you are wanting to down load or order on line.
Good Luck /Please dont for get to Vote.Thank You.
Dec 15, 2007 | Arris SURFboard SB4220 Modem
Arris SURFboard SB5120 Modem Logo
337 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
