Question about HP Pavilion Slimline s3500f Desktop Computer
When i trun on my computer the monitor will not work. it says Check Signal Cable
  • 162 Answers
1. try to see works using a different monitor
2. If it doesn't work then you may need to replace the video card
Thanks
DiegoTech
Posted on Nov 14, 2010
    President:
  • 556 Answers
This issue can be caused by any of the below possibilities.
  1. Monitor is not on
  2. Computer is asleep
  3. Connections not connected properly.
  4. Monitor settings are not correct.
  5. No Post.
  6. Hardware issue.
Solution:The following is monitor troubleshooting. If your monitor receives a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please refer to document CH000192.
Monitor is not on
Make sure the monitor is on. If no power light (green or orange light) is seen on the monitor display try pressing the power button until it comes on. If no light comes on after several attempts continue to below connections not connected properly.
Computer is asleep
If your computer monitor was on and you stepped away from the computer and upon returning it was black it's likely that the computer is asleep. Try moving your mouse, clicking the mouse buttons, and/or pressing any key (space bar) on the keyboard to wake it up.
when i trun on my - vga.jpgMake sure that you are connecting the monitor to the back of the computer in the 15-pin connector as shown to the right or older computer 9-pin connection.
If the computer is properly plugged in, make sure it's getting getting power.
If you are not receiving power from a known working wall outlet and if the power cord is removable, replace it with the one connected to the computer and attempt to power on the monitor again. If the monitor still does not get power or it is not removable, it is recommended that the monitor be replaced or serviced at a local TV / Computer repair shop.
If the monitor is receiving power, check the status light.
If the light is orange or flashing ensure that the monitor is not in a suspend mode by moving the mouse or pressing a key on the keyboard. If the computer does not get a display by moving the mouse or touching the keyboard, turn off the computer and monitor and reconnect the data cable from the back of the computer, and if removable, the back of the monitor. Turn the computer back on; if you still encounter the same issue, continue reading through the other possibilities.
Ensure that the brightness and contrast is turned up or attempt to adjust the brightness and contrast. If adjusting the brightness or contrast has no affect on the monitor continue reading through the other possibilities.
No Post
Does the computer beep when it is powered on and/or does it appear that the computer has activity? If the computer does not beep or beeps abnormally it is possible that the computer itself is experiencing a hardware issue or is exhibiting a No Post.
Steps on troubleshooting an irregular POST or no beeps can be found on document CH000607.
Hardware Issue
If you have followed the above recommendations and are still encountering the same issue, it is likely that the computer may have either a bad video card or monitor. The best method of determining this is to do one or both of the following:
  • Disconnect your monitor and attempt to connect it to another computer. This can be a friend or family's computer and/or it can be taken to a service center.
  • Borrow a computer monitor and connect it to your computer. This will not harm the other computer monitor in any way.
If your monitor works on another computer it is safe to assume that the video card or potentially the motherboard within the computer is bad. Steps in troubleshooting a video card can be found on document CH001028.
If another monitor works on your computer it is safe to assume that your monitor is bad.
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
When my computer says check signal cable what does it mean?
Your monitor is telling you that it thinks it is not receiving a video signal from the computer. You need to verify which of three components is not working, the computer, the cable, or the monitor.
The first thing to do, obviously, is to check that the cable connecting the computer to monitor is good. You will need some extra components to do the checking. I'm going to assume that the cable is detachable at both ends.
First you can try replacing the cable with different one. If the replacement cable works, then it's the cable.
Secondly, you can try different monitor. If you connect this in place of the first monitor, and it works, it's a faulty monitor (needs repairing or replacing).
Third try a different computer with the original cable and monitor, if it all works it looks like the video on your PC has malfunctioned. (This might also be your conclusion if a system comprising a different cable and monitor fails to work with the original PC)
You might just be able to verify the cable by testing the connectivity of all the wires in the cable with a meter, if you knew the pin out of the cable at both ends.
If you find out the computer is getting a signal out, there could be many causes for that, each having its own solution (or not as the case may be)
12.April.2014
Aug 08, 2012 | HP Computers & Internet
Every time I trun on my LCD it shows signal, but I can barely see my computer, it is very dark. I think it's the inverter, but I opened it up, and I didn't know which one was the inverter.
Have you tried an other VGA/DVI cable??? did you tryed an other monitor??? the inverter board is usually a slim board near the cable connector input with two ballast (wire windings with ferrite cases) depending on the price you paied and the year of the monitor it could be cheaper to buy a new one... try pressing the MENU button on the monitor if the menu is dark as well than it's devinitively the inverter...
Aug 02, 2011 | NEC LCD19WV Monitor
I have bought a mew computer with a Sansung screem type LS19A300. It was working normaly and then a message "check signal cable" appeared. I checked all cables and nothing. So we changed the new...
Hi, what was the LCD displaying is that he is not sensing any signal from the computer video port that is why it is prompting "check signal cable". Have you tried checking the pins of your video cable from your LCD? if OK please plug in the cable again when your PC is already open to check that signal will pass thru and lets see what happen. If still the same, try to isolate it with laptop as external video if you have to check the LCD will work with other PC. If the same, replace the signal cable of your LCD if it is removable to further check the problem.
Jun 23, 2011 | Samsung SyncMaster 910T 19" LCD Monitor
Check signal cable
Check if the monitor is not working by connecting this monitor to another computer.
If the monitor woks on another pc, then the pc is the issue and not the monitor.
If monitor doesnt work on the other pc, then it's the monitor that needs replacing.
I hope this helps you :)
Jul 13, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Monitor does not come on right away, it makes a clicking noise then say no signal analog. after i trun off and on several times it comes on but the screen is wavy for a while
when you say the screen comes on wavy for awhile, im supposing you have a CRT monitor, not the flat panel type. That seems to be the degauss feature when you turn on the monitor which is normal. The no video issue may be a bad video cable or connection the the PC.
Nov 09, 2009 | Computers & Internet
I show on monitor "no signal" Check Signal Cable
Check that the "data" cable between your computer and your monitor is tightly connected at each end.
Connect the VGA-output port from a laptop computer to the monitor, to see if the monitor works when connected to a different computer.
Connect a different monitor to the VGA-output port on your computer, to see if that monitor works.
Failing all the above, the video-card on your computer is the problem, and needs to be replaced.
Nov 05, 2009 | E-Machines (T3104) PC Desktop
My Samsung 913t says "Check Signal Cable." HELP PLEASE!!!
Cheap CRT monitors can be picked up at Thrift Stores, quick and cheap way to test your computer output.
Sep 22, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
No signal detected
Check all of your cables - VGA / DVI mainly in the back of the monitor and the back of the PC.
Jun 09, 2009 | BenQ FP737S-D 17" LCD Monitor
HP Pavilion Slimline s3500f Desktop Computer Logo
300 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
