Question about Dryers
I have a 6 year old GE Profile DPSB620GC1CC which seems to be running fine except that it has become noisey when the drum is turning. It is like the normal sound of rotation only much louder. It is more a rumble than a squeak. Would could be the source? What component should I consider replacing
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Nov 14, 2010
Have GE profile refrigerator. It is 3 years old.
OK check the Thermistor, the actual temperature sensor element, and or thermostat if it uses a separate feed.
Sep 10, 2011 | GE Refrigerators
GE Profile Perf high pitched sound coming from back
First check the simple: may just be dust and pet fur clogging up the airway making it hard for the condenser fan to draw ... or condenser fan bearing is wearing out.
Jun 28, 2010 | GE Profile Performance 23.5 cu. ft....
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
My GE Profile is about 10 years old. Everything
cheapest attempt would be replacing temp. sensor....other component if still not functioning,would be the main computer board,which can be very pricey
Nov 27, 2009 | GE Ovens
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
GE dryer does not run and just hums
Yes, open it. You'll probably find a broken or loose belt.
More help?, let me know.
May 09, 2009 | GE Profile DPSB619ED Electric Dryer
How do I get to the drum to check the belt
Doc,
It sounds like you have either a worn out rear drum bearing and or front drum slides. Has the problem gotten worse over the last few months of use?
Mary,
It is impossible for your dryer to produce heat without the drum turning becaue there is a "belt switch" that will prevent the heater or gas valve to power up if the belt breaks. One exception is if your dryer is very old and doesn't have the belt switch on it. It would then have to be circa 1982 or older before UL required all dryers to have a belt switch. One exception to this would be two fold- Your heating element would have to be shorted against the steel heater frame AND the belt broken at the same time. Very unlikely for these two things to happen at the same time. 30 years expierence talking... Brian
Dec 12, 2008 | GE Profile Harmony DPGT750EC Electric...
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Dryers Logo
102 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
