Question about Intel D101GGC Motherboard
Hay, i just wanted to know wheather intel d101GGC supports ddr2 ram.and also needs to know wheather the board supports the sata harddisk
  • 442 Answers
This motherboard does not support DDR2 RAM but this motherboard supports SATA hard disk
Reference: http://downloadmirror.intel.com/15113/eng/D101GGC_TechProdSpec.pdf
You need to have adobe reader installed in your computer to read the pdf file from the link above
Posted on Nov 14, 2010
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
Do dg101ggc support ddr2 ram
yes it supporst DDR2 ram u can use DDR2 ram with that
Dec 19, 2009 | Intel D101GGC Motherboard
Ddr 2 ram connecting to intel d101 motherboard
Well first of all, there is no "adapter".  You have to use the specified RAM that you motherboard supports.  Secondly, even if there was an adapter so to speak, it would not be beneficial.  The only difference performance wise between DDR and DDR2 is speed.  So if your motherboard supports DDR, and you had an "adapter", your motherboard would only read the DDR2 at DDR speed.  In my opinion, DDR2 is not really worth the upgrade to another motherboard just for DDR2.  If you want the biggest bang for your buck, upgrade the CPU, or put more memory in the motherboard you already have.  Hope this helps, and please don't forget to rate.  Thanks.
May 30, 2009 | Intel D101GGC Motherboard
RAM
check your previous memory if its dd1, ddr2 or dd3 and check also your motherboard's manual for this. be sure that you add the same specs of memory otherwise remove your previous memory.
thank you for using fixya
CHARCOIS
Feb 24, 2009 | Intel D101GGC Motherboard
Memory Upgrade
ask for ddr1 ram of 1 gb.also take your old ram which is at present in your pc to match the locks with the new ram.
it will cost u near to 50$.
thanks.
Sep 18, 2008 | Intel D101GGC Motherboard
Intel D101GGC Motherboard PCI Express compatibility issues........
i'm using NVIDIA GEFORCE 8600 GT on my d101ggc board and its working fine
Jun 30, 2008 | Intel D101GGC Motherboard
Maximum HARDDISK CAPACITY FOR Intel 865GV motherboard
Yes, your board will support 320gb. I am not aware of a limit to how many gigabytes you can have per computer. I currently have 1.5 terabytes. 1500gb.
Apr 22, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel D101GGC Motherboard Logo
80 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
