My Electrolux EWF1090 is having problems, on the tiny screen it keeps comming up with "E20" i dont know what that means and how to i get it to work?
  • 6 Answers
Go to www. Electrolux.com.my/files/malaysia_singapore/manuals/fabriccare/ EWF1090.pdf this will give you the manual with all the information to solve this drainage problem
Posted on Dec 05, 2010
  • rojimac Jun 11, 2011
    IF ANYONE OUT THERE IS SUFFERING THE PAIN OF HAVING THEIR WASHING MACHINE PLAYING UP DUE TO THE E20 CODE ERROR.. I HAVE A SOLUTION FOR YOU YAY!!!!!!!!
    WE JUST FIXED OURS YESTERDAY $AVING HUNDREDS OF DOLLARS IN CALL OUT AND REPAIR FEES. ( SMART HUBBY OF MINE) XX
    All you have to do is disconnect the power.. lift onto 2 saw horses. Remove the rubber sealed plate at the base( the odd shaped one) and unscrew the drain hose where it meets the front of the washer. the coins will drop out (50c yes) we had four in there .... Reattach the hose.. Replace bottom panel.. then put back on floor.. switch on and presto FIXED 2 people to lift! Hope this helps some people out there!
Belt snapped ..motor shaft turns freely
could be bearings or a brake for the drum energized
Call in a technician and get a repair quote
Jan 10, 2016 | Electrolux Washing Machines
Model ewf1090 electrolux.displays E90 and flashing green lights
its an electrolux fault code.that means .bad connection on communications wire.this is a blue loom of about 5 wires that come off the main pcb and connect to the display board in fascia panel. clean pcb terminals and tighten loom connection pins and this should solve problem"
wd 40 or another type spray should do it........
cheers
Mar 26, 2011 | Washing Machines
Service manual for ewf1090 8kg front load washing machine
have you tried downloading it from the electrolux website? I have found the manual just d/l it from the below link
http://www.electrolux.com.au/Files/australia_english/Brochures/Laundry/EWF1090_installation_guide.pdf
Nov 21, 2010 | Washing Machines
My frontloader EWF1090 will not spin / drum doesn't move around
if its not spinning and the drum is siezed there is a coin or a forighn object jamming it, it can be removed but would have to go into an electrolux repair shop, if its in warranty no probs if its 2 years or less outta warranty they will repair it under a endemic failure, which in english means the bill would go to the manufacture hope it helps
Jun 19, 2010 | Electrolux Washing Machines
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Electrolux EWF 1470 Error code E20
could be the element at fault or pressure chamber
Jan 12, 2010 | Washing Machines
ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Dec 19, 2008 | Zanussi FJD1666W Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
478 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
