Question about Sony Ericsson K320i Cellular Phone
Hi.. I am facing a problem, when I switch on the phone. the screen written "insert correct sim card". who to fix it back?
  • 186 Answers
Hi bro , Your phone is SIM-locked to a specific service provider's SIM card. You have inserted a SIM card that is not supported. This is happens when you buy the phone from an operator. SIM locked phones can be unlocked - contact your service provider for more information.They will give u the unlock code for free of cost after a few verifying question to ensure that you are so and so .You should be able to give them the details
For any quires write back to . If u are satisfied with the answer please vote for me (with atleast 3ups) .Thanks in advance
Posted on Nov 14, 2010
How can i put sim card on my cellphone
the back of your phone and under the battry and bam there it is put your sim card right in the sim card hole
Apr 14, 2012 | LG enV3 VX9200 Cell Phone
Insert sim nokia 2700c-2
Hi
Always switch the device off and disconnect the charger before removing the battery.
The SIM card and its contacts can be easily damaged by scratches or bending, so be
careful when handling, inserting, or removing the card.
1. Press and slide the back cover towards the bottom of the phone, and remove it (1).
2. Remove the battery (2).
3. Insert the SIM card into the holder with the contact surface facing down (3).
4. Insert the battery (4), and replace the back cover (5).
Remove the SIM card
Press the release spring (1), and slide out the SIM card (2).
Jun 25, 2011 | Nokia Classic 2700 Cell Phone
I have a nokia 5310. When I insert my Airtel or BSNL sim ( my old sim which i have used with this phone for the past two years ) it works fine, but when I use my vodafone or aircel sim ( which are my new...
hi
you are installed a security code when you are using your old sim cards
so if you wont to install a new sim card you have to know your security code
other wise
1) insert your old sim card
2) switch on the phone and back up all data
3) Connect your phone to pc using Nokia PC Suite and Data cable
4) make sure about your data
5) Download the Nokia Software updater
6) Update your phone software or reinstall if you have already latest software
if any doubt replay me
Link for nokia Software updater
http://www.nokia.co.in/support/product_support/phone-software-update
May 27, 2011 | Nokia 5310 Cellular Phone
I can't open my back cover...how can i change my sim
Hi there!
Let me give you the steps on how to insert the sim card on your phone.
First,kindly switch off the power and disconnect the charger and any other device before removing the covers. Avoid touching electronic components while changing the
covers. Always store and use the device with the covers attached.The SIM card and its contacts can be easily damaged by scratches or bending, so becareful when handling, inserting, or removing the card.
For you to be able to remove the back cover is that you have the press the back part of the phone gently and slide down the back plate of your phone.And after that kindly remove the cover and the battery.Please open the SIM card holder and insert the SIM card into the holder with the bevelled
corner facing down and the contact surface area facing toward the contacts of
the device. Close the SIM card holder.
Line up the battery contacts, and insert the battery. Replace the back cover.
That's it!
Thanks!
Apr 20, 2011 | Nokia X3 Cell Phone
How to remove the sim card?
Quick start guide
Your Nokia E75 is a business device that adapts to your
free time, as well.
Read these first pages to get started, then use the rest
of the guide to explore what new features Nokia E75
brings to you.
SIM card, battery,
charging, memory
card
Put the pieces together, and get started with your
Nokia E75.
Insert the SIM card and
battery
1. To open the back cover of the device, with the back
facing you, unlock the back cover release button,
and lift the back cover.
2. If the battery is inserted, lift the battery in the
direction of the arrow to remove it.
3. Insert the SIM card. Ensure the contact area on the
card is facing the connectors on the device and that
the bevelled corner is facing the top of the device.
4. Align the contacts of the battery with the
corresponding connectors on the battery
compartment, and insert the battery in the
direction of the arrow.
Jan 22, 2011 | Nokia E75 Cell Phone
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
Emergency calls only and not showing service provider
sounds like either your sim card isnt inserted correctly, or the slots arent turned on. sim card slot 2 is the slot closest to the phone, gold chip faces up, sim card slot one is slightly elevetaed off the phone, gold chip faces down. make sure it is inserted all the way down. perss fimly. then go to SETTINGS>DUAL SIM SETTINGS>DUAL SIM OPEN>CLICK OK. This opens up both sim card slots. after you find out which slot you are going to use, you can repeat these steps and only have opened the one you are using.
Jun 02, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Sony Ericsson K320i Cellular Phone Logo
44 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
