Question about Casio FX-9860G Graphic Calculator
How to use stat option in GDC - Casio FX-9860G Graphic Calculator
MAIN MENU [RUN] -----> press [OPTN] ---------> F5 (STAT)
Hope it helps! =)
Posted on Nov 22, 2010
RESID option in (STATS) (LIST) disappeared!!!!
Clearing the memory erased the RESID list. You can recreate the list by calculating a simple regression.
Apr 18, 2013 | Texas Instruments TI-84 Plus Silver...
Everytime i try to graph something it says "err:invalid dim" and only gives the option to quit....how do i fix that?
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Sep 24, 2010 | Texas Instruments TI-84 Plus Calculator
HOW TO USE LINREG(AX +B)
The post addresses several questions
  1. 1-Var statistics and standard variations
  2. 2-Var stats (calculating the statistical values)
  3. Regressions (linear or otherwise)
I assume you know the theory. I will show you the key strokes for 1-Var statistics and 2-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to Referable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
- To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
REGRESSIONS
To use the regression a+bx,
1. Select STAT mode : [MODE][3:STat] [ENTER][2:a+bx]
2. Fill the X and Y values in the template.
3. Press [SHIFT][STAT][7:Reg]
You have several options 1:A to get coefficient A, 2: B to get coefficient B, 3:r etc.
To access each one, you have to press [SHIFT][STAT][7:Reg] anew.
To access the various sums, you press [SHIFT]{STAT][4:Sum] and you can select Signa_x, Sigma_x^2, etc..
Jul 15, 2010 | Casio FX-115ES Scientific Calculator
My calc doesn't graph. Once I click graph it says ERR: Invalid Dim, and my only option is Quit. What do I do??
If this isn't the problem, try posting the function(s) you're trying to graph, as well as the window settings.
Feb 07, 2010 | Texas Instruments TI-84 Plus Silver...
Dose the Goodman GPD075-3 have a fan oni have a red and white wire going to the thermastat, and a green one in the unit not hook up
depends on your stat, red goes to R on stat white goes to W on stat and if your stat has a G terminal that is so you enable the fan only without heat if not then this option won't be available to you.
Jan 24, 2010 | Humidifiers
Error 23 stat
Quoting from page B-7 of the Guidebook:
You are attempting a stat calculation with lists that are not appropriate; for example, you are requesting a statistical analysis with fewer than two statistical data points. The frequency (y value) for a 1-VAR analysis must be an integer >= 0.
If you simply want 1-variable statistics for two sets of data, you'll have to calculate them separately.
Oct 20, 2009 | Texas Instruments TI-85 Calculator
How can i use the a+bx on a Casio FX-300ES to find the LSRL
It would not cost you much effort to spell out the LSRL abbreviation, and it makes things easier for the reader. I believe I finally guessed what you wanted, but I would not bet my life in it.
Hope it helps.
Oct 18, 2009 | Casio fx-300ES Calculator
Standard Deviation
If you want to do statistics with this calculator you press [MODE][3:STAT]. You have then 8 options 1:1-var, 2:A+BX, etc.
For one variable statistics you press 1. Enter the values for the X variable in the template. Once finished you press [SHIFT][1](STAT) then select the value you want ( n, x bar , and the standard deviations (X sigma n) and (X sigma n-1).
Hope it helps.
Jul 30, 2009 | Casio fx-300ES Calculator
Stat plot giving 'quit' error
Simple, just check that the lists on the Stat Plot are the same as the ones that you are using.
Apr 29, 2009 | Texas Instruments TI-84 Plus Calculator
A contractor cut the wires from my Coleman forced air furnace, It was hooked up to a stat that ran my evap cooler and heat. I am trying to put in a new straight heat stat but I can't get the stat to...
Does the new stat have a pin labled (G)? Connect your fan wire (usually green) to that pin, and then call for fan on your therm. Straight heat stat means it has only heat and cool pins, there is no option for fan. If your not getting the fan to come on including heat, make sure you have the white wire and red wire connecting to your new stat.
Dec 06, 2008 | Heating & Cooling
Casio FX-9860G Graphic Calculator Logo
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
