Question about Volkswagen Car Audio & Video
Does my factory radio in my 1996 Jetta have preouts for an afermarket amplifier hook Up?
  • 48 Answers
NO,CHANGE YOUR RADIO OR GET SOME ADAPTERS FROM RADIO SHACK
Posted on Nov 14, 2010
Hogar - No sound from Boss Radio after initial installation test.
If you are hooked up to the factory wiring harness i would think there may be a factory amplifier that is not getting power or is bad.
Test the stereo by hooking a speaker up to the speaker out wires from head unit. if it has sound try to find out if there is a factory amplifier.
Good Luck
May 24, 2016 | Cars & Trucks
I have a 1996 jetta 1.8 with a factory alarm and i put in a new radio when i put battery back on after radio was installed the alarm kept on going off and i cant disarm it with remote button or when i try...
You alarm system monitor the radio. You basically disabled the vehicle when you removed the radio. You will need the original radio with the radio code and install it back. Your driver door lock is what turns it off and what turns it on. You have a 1996 Jetta find a electrical auto repair who is willing to do this (I do this all the time) Disable the alarm first get rid of the horn there is only on on the outer drivers side the alarm horn will have to be cut. From there acces the fuse box under the driver dash find the starter relay and bypass it. There your done no alarm and you can put any radio on .
Sep 20, 2011 | 1996 Volkswagen Jetta
IM TRYING TO WIRE A PIONEER DEH-5 TO MY STOCK WIRES IN MY 1996 VOLKS JETTA. I CHECKED OUT THE WIRING DIAGRAM ON THE JETTA AND SOME OF THE WIRES DID NOT MATCH UP,LIKE FOR INSTANCE THE SWITCHED WIRE ON THE...
Hi, the plain orange wire is the power wire. The constant wire is only for maintaining the station presets--it does not power the unit on. The other orange wires are for speakers. See the full color code below, and let me know if you have any more questions.
1996 Volkswagen Jetta Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/White
Car Radio Switched 12v+ Wire: Orange
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Gray/Blue
Car Stereo Amplifier Location: If equipped, each speaker has an individual amplifier located at the speaker.
Left Front Speaker Positive Wire (+): Blue/Black
Left Front Speaker Negative Wire (-): Orange/Black
Right Front Speaker Positive Wire (+): Red/White
Right Front Speaker Negative Wire (-): Orange/White
Left Rear Speaker Positive Wire (+): Red/Light Green
Left Rear Speaker Negative Wire (-): Orange/Black
Right Rear Speaker Positive Wire (+): Blue/Light Green
Right Rear Speaker Negative Wire (-): Orange/Red
May 07, 2011 | Alpine CDM-7874 CD Player
What kind of wire do I need to install Infinity reference series 605cs with a JL Audio 10" sub and a Alpine Flex 2 amp? Can I use my factory head unit?
You can use the factory speaker wiring for the Infinity speakers you should purchase a amp kit which will give you everything to install the amp. See site below
http://www.sonicelectronix.com/item_18428_Raptor+ISPKBL4-BG+by+Metra.html
Well that all depends on the current audio system you have now is it just a basic or a premium factory system with a factory amp. Honestly you would get a better and cleaner sound if you change the factory head unit to a after market one which has preamp feeds and the higher the preout volt the better. Just make sure it is compatible with the amp volts input (Example 4v to 250mv) If you use the factory headunit you would have to by a high to preout adapter it connects to the exsiting radios speaker leads, but like I said before change the head unit you won't be sorry. Do not forget if you change the radio you need a radio install kit and the wiring harrness which converts the two radio plugs so you don't cut them so down the road you can remove the after market radio and just replug the factory right back in.
Apr 16, 2010 | Infinity Reference REF 605CS Car Component...
Were do i plug in the RCA cables from the amp to a factory radio? do i need any sort of adapters if my stereo dose not have inn or outputs? and where do i hook up the remote from the amp?
Most factory radios do not have RCA outs, but most will have a remote wire. Usually used for a power antenna option. Your remote wire from the amp could be hooked to the power antenna wire on the factory radio and it would work great for turning on the amp. As for the RCA inputs on your amp, you will not be able to use them without RCA outs on your factory deck. Although most amps offer a high level input alternative and will use the standard speaker level out on your factory deck. This means the rear channel speaker wires from your factory deck will be used to feed the signal to the amp. You will have to check the instructions and manufactorer recomendations for the amp you are trying to hook up. Have fun and good luck!
Mar 09, 2010 | Stingpro ST444 1850 Watts Complete...
Shuts off with preouts hooked up.
I your amp new or used and can you send me pics of how you have it in your car. I can help you with this.
Jul 07, 2009 | Car Audio & Video
Radio comes on but i cant hear any music
You may be connecting this stereo into an amplified system. If the original factory stereo worked with the factory amplifier, your stereo is not turning the amplifier on. If you purchased the aftermarket wire harness that mates to the factory stereo connector, hook up the "Amplifier Trigger" wire, this wire is usually blue.
Oct 16, 2008 | Pioneer DEH-P3500 CD Player
How to hook up an amp to a reciever without preouts, can it be done?
yes, you can have output signal at tape monitor output terminal and can be hooked to any amp.
Sep 04, 2008 | Audio Players & Recorders
Car Audio & Video Logo
32 people viewed this question
Top Volkswagen Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
David Payne
David Payne
Are you a Volkswagen Car Audio and Video Expert? Answer questions, earn points and help others
