Question about Curtis Televison & Video
My Curtis DVD1098B player will not read a camera SD card. It keeps telling me "bad card". I have tried a couple different cards that function fine in the cameras. How do I fix this?
    Problem Solver:
  • 7 Answers
Use a USB card reader (they only cost $10 if you can find them at biglots or something). I happen to have had one and the SD card is read from that. But the direct slot, the player will say "bad card" also. Cheap player.
Posted on Jan 07, 2011
My memory card is not working in my Nikon S4100 camera. It keeps giving me the message "this card cannot be read". I What can I do about this?
1) Make sure that the write protect slider on the edge of the SD card is not in the protected position.
2) Make sure that the SD card has been formatted in the camera; not on your computer. The format function is in your camera's menu functions.
3) Try a different SD card that has been formatted in your camera. That will tell you if you have a bad card.
Jan 09, 2016 | Nikon Cameras
Card reading error
Have you tried a different SD card, or a newer SD card? If the card isn't the issue you may have damaged/dirty pins in the camera memory slot. If so, there are "cleaning" cards available that MIGHT work but otherwise, it will need to go in for repair.
Apr 12, 2013 | Canon EOS 1100D / Rebel T3 Digital Camera
What video format does a curtis dvd1098b play by usb
I've had so many issues with trying to figure out what format this thing takes via the USB or SD card ports. I mean, for goodness sake's whatever you do don't give that information in the manual lol
After hours and hours I found that it not only depends on the format but the software. I still don't know exactly what the formats are that this things supports but I did finally find a program that produces avi files that play flawlessly on this thing. It's called "FairUse Wizard"
I just keep most everything to default as I'm clicking through the process. The things I did find that needed to be changed were:
1. Choose "Native Mode"
2. Check the "Use TV Display Mode" box
3. Choose 720x480 (others may work as well but this one always turns out with good quality and the file size is quite resonable)
Hope this saves somebody else the hours I spent pulling my hair out on this thing....
Jan 14, 2012 | Curtis DVD1098 Player
I am trying to access the SD card in my Hitachi DVD Cam and it keeps telling me "Card Error"
Try inserting a different card in your camera and if the problem persists, its a fault on your camera. A technician should fix it. On the other hand, if the new SD card is accessible, then the former card is corrupt. You should replace it.
Aug 28, 2011 | Hitachi Cameras
New Jazz DV150. Installed new batteries (tested) and SD card (tried switch in both locations). Powers on, says "Read card....", "Goodbye", powers off.
HI, I just got off the phone with a very nice man in NJ at Digitac. He walked me through a few fixes: Try a different SD card, clear SD card, put SD card in and then start camera, start camera and then put SD card in. None worked, so he said something is wrong with the camera computer and I will have to send the camera in for warranty work.
Feb 28, 2011 | Jazz DV150 Camcorder
My Lumix DMC ZS7 reads "insert sd card again" when I have a full sd card inserted. The sd card is "verbatim sdhc 4gb" any idea? Thanks in advance
SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
If your manual doesn't specifically mention SDHC cards or memory card size bigger than 2GB, then the camera almost certainly won't work with SDHC. My Lumix won't work with anything larger than 1GB SD.
Jan 18, 2011 | Panasonic LUMIX DMCZS7 DMCTZ10 Digital...
We have a PowerShot SD600 camera that is having trouble reading memory cards. It comes up with "Memory Card Error" and "Memory Card Locked" even when the card is not locked. ...
This camera can use only cards with the SD mark on it. An identically physically sized SDHC card may be in the camera and could be causing the issue. Generally, SD cards have capacities up to 2 GB and the SDHC (the HC stands for High Capacity) are those 4GB and larger in capacity.
If the card you're trying to use is an SD card, the card may have become corrupted and need to be replaced. Try with a different SD card to be sure. Hopefully, it's a card problem - not a camera problem.
Please rate this reply - good luck!
Dec 03, 2010 | Canon Cameras
My f10 keeps reading "card not initialized"
Is it a new card? You could try to initialize or format it with the function in the camera setup menus. If it won't format, then maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 04, 2010 | Fuji Cameras
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
Curtis DVD1098B will not open usb videos from jump drive?
My problem with the USB is that I can see the videos, but there is no sound.
Anyone knows how to fix it?
Nov 10, 2009 | Televison & Video
Televison & Video Logo
265 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
