Question about Pioneer PureVision Pro-1120HD 50 in. HDTV Plasma Television
The TV was working fine and then, using the remote, I accidentally switched it off the default channel for the cable box resulting in static. No matter what we did we were unable to get it back on the default channel. We tried everything imaginable. Eventually, my husband was able to get audio, no more static, but the video is completely dark. My husband is very experienced with professional sound equipment and not dumb in checking inputs, cables, etc. We are stumped.
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from
Connecting Cable Service, Satellite Service, or Antenna ...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
Trying to connect with Comcast using comcast remote. have idetified correct code and and can turn TV on & off with remoet but can not get channels to change .... just get static no picture ??? Can...
The Comcast remote only changes channels on the cable box. not the tv itself. If you have a cable box then the tv will need to be turned to channel 3 or 4.
Apr 11, 2011 | Quasar VV-1302 13 in. TV/VCR Combo
Is there a reset default setting?
Do you recieve any channels if you run the cable directly from the wall to the TV and do a channel search? You may have to switch your TV over to a different input source if you are using a box. Please email me at tina-AT-suddenlink-DOT-com for more information. Thanks!
Oct 15, 2009 | RCA Televison & Video
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Can'y get the cable channels to show up anymore.
is it(cable) connected by the RF cable to the tv ?
or is it connected by video/audio cables ?
If by RF cable the channel on the tv should be on channel 3
If connected by video/audio cables then the tv should be set to that input on the tv
Mar 31, 2009 | Mag Innovision M572TVs LCD Television
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
No volume
Normally when you have only one channel with audio the cause is usually SAP is turned on, either on the television or the cable or Sat elite box.
If you were pushing buttons on the remote, I would suggest that the SAP button is on the remote.
On a Samsung remote, the MTS button identifies this function. It may be labeled stereo.
Make sure the remote is in the TV mode to change or check on the TV.
It may also be a button on the remote for the Cable or Sat elite box. If not then you may have to search in the menu's of the Television or the boxes.
If the set is only two weeks old (the actual set, not how long you have owned it) then it probably has an ATSC turner labeled Air that will receive local HD by using rabbit ears. If the set is over 3 years old, it will not have this feature.
It's difficult to give a full de script explanation of a solution without knowing the model or configuration of the input signal.
If this does not help, respond to this post and I will reply.
Nov 18, 2007 | Televison & Video
No channels
i had the same damn problem for 3 long hours but i found a solution i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
Sep 21, 2007 | Olevia LT32HVE 32 in. LCD Television
Pioneer PureVision Pro-1120HD 50 in. HDTV Plasma Television Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
