Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
We get a message on the screen that says Check Fan 2 and the manual does not tell how to do that . My husband is very handy and probably can do it if we were given any instructions at all.
  • Samsung Master
  • 5,138 Answers
I think Fan 2 is the DMD fan Located behind DMd Moduel its the Board mounted in the Middle Just CK all of the Fans, Lamp Fan,Ballast Fan which is a tiny fan on the Ballast board.
When sitting behind the TV on the right hand side is the Lamp Fan Lamp and Ballast board in the Middle is the DM Aluimmium looking box and on the Left handside is the power supply board.
I hope this will help you .Encompass Parts Distribution List this Model and Parts Visit their website
Samsung Parts.com 1-800-627-4368 Let me know if you need any more help.
Posted on Nov 14, 2010
My fan on my mpv is not coming on and there is smoke coming off the radiator.
fans probably bad and the smokes probably from getting hot without the fan check the relays for the fan
Apr 12, 2013 | 2000 Mazda MPV
I AM GETTING A MESSAGE ON MY SCREEN TELLING ME TO CHECK(FAN NO.2)
New TVs have fans to help cool their circuitry. Sounds like your fan #2 is bad. Remove the back which means removeing all the screws around the perimeter as well as in the middle and don't forget the ones in the small signal area. When the back is off you should be able to see the problem, aka, lots of dirt around the fans. Move the unit to the outdoors and using an air hose blow all the dirt out of the unit.
Once this is done you should go to http://www.encompass.com and put in your model number. Do a search for a fan. If you believe that this is the part you need order it. I suspect that all the fans are the same.
Remove and replace fan number two and you should be able to reinstall the unit. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Jul 24, 2010 | Samsung 61" Slim-Depth DLP HDTV
My husband has a lock code for his cell phone text messages, how do i get lock code without bluetooth enabled ?
What a tricky question..
What do you mean bluetooth enable?
You cannot get the unlock code unless he tells you.
It is in the phone security settings. If you can manage to format your husband phone then probably the lock code will be gone as in gone, vanished.
Mar 25, 2010 | Cell Phones
Check Fan No. 2 Error Message
The DMD board you installed is bad. It senses the detection line from the fan and generates the error code. Try installing the old DMD board.
Mar 15, 2010 | Samsung HL-S5086W 50" HDTV
My Carrier Weathermaker 8000 makes a screeching sound when it first starts but quits screeching about 45 seconds later. I turned the heat down today and it quit about 2 seconds after. The blower still...
the screech is probably the condenser or exhaust fan as you guessed. And yes, a decent handi-man can fix it. Check the horsepower, RPMs,rotation,shaft size, and frame # of motor and order a new one from www.grainger.com or a local carrier dealer.
Install the new motor exactly as the old one was and wire according to the motor literature or the graphic on the side of the motor.
Use care when removming the old fan blade. a good file on the shaft and some WD-40 makes the job easier. Also a bit of patience... :-)
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 17, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
WHAT DOES THE ERROR MESSAGE F76 MEAN?
1/ check overheat stat 2/ check fan esp the little hose at the fan area for pinhole best of luck
Sep 28, 2009 | Noritz 6.9 Gallon Residential Tankless...
Recorded message plays in Spanish. Husband threw the manual away.
Way too easy :-)
When you were listening to messages you probably pressed the SKIP button for longer than 2 seconds. Try pressing it and holding it again and see what happens.
Here's the manual link: http://www.home-electronics.net/ge/pc/IB/25942GE3_IB.pdf
Carl
Mar 13, 2009 | General Electric 25942EE4 Quad Cordless...
1997 dodge caravan coolant fan does not come on
check relays in fuse/relay box (in engine comaprtment in black box probably) usually 2 or 3.
check engine cooant temp sensor that sends siganl to computer to turn fans on.
Check owner manual for fuse & relay chart and location.
report back please
Feb 27, 2009 | 1997 Dodge Caravan
Error message on LG Refrigerator
The message is ERROR ICE FAN. You can order a new one from LG for around $65 and if you know someone handy they can probably put it in by just eyeballing the old one. WARNING>>>>this must be someone with common sense and some degree of problem solving skills as it does not come with the fan blades and that must be switched. This is a common problem with this model and usually the ice fan goes out in about 12-20 months. Use your owners manual to figure out how to get the door off and access the fan. Also, Lg employees are confused and may try to tell you there is just one fan......they did tell me that!
The ER IF is part # 46811B1029E---The ER FF (freezer fan) is part # 4681JK1004E and only a skilled repairman can modify them to be interchanged.
Dec 07, 2008 | LG LFX25960 Bottom Freezer French Door...
Samsung HL56186W Fan question
It's been a while since I had to clean the fans, from memory, there was a small fan close to the base of the removable lamp assembly, and the larger one with a shroud directing the airflow round the lamp.
Hope that helps.
Sep 15, 2008 | Televison & Video
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
113 people viewed this question
Henry  Thomas
Henry Thomas
