Question about Minnetonka Kilty Suede Moccasins Shoes
Got them wet and dirty on the top front area, how do i clean them?
    Scholar:
  • 103 Answers
Respected sir /madam
your problem cab be easly handled the sted you need to take is
1) buy a sponge from neary by stores
2) take a warm water in a mug , mix a soap solution in it and mix it well
3 dip the sponge in it then take it out ,get rid of excess water then apply it on your shoe where the dirt is there and rub it till the stain or dirt is gone
4) finally dry the shoes
if my solution has helped you pls vote for my answer
Posted on Nov 15, 2010
Where is the dirty water go on the bis sell preheat
The Clean Water Tank is a 2 stage tank. As the clean water leaves the Tank the flexible bladder allows the dirty water to enter. Dispose of the water in an area outside or a utility sink.
Jul 01, 2014 | Bissell 7901-1 ProHeat Scotchgard Upright...
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Bissel Pro Heat Plus and I used it once, one year ago. I may be using it wrong, as my carpets were wet and there was no return (dirty water). If I remember correctly, going forward wets and...
It has only one tank that serves two purposes. It holds the clean water and collects the dirty water, so you only have to empty/fill one tank. If you check reviews of this machine you will see that they basically stop working correctly after a very short time, if I was you I would just contact their customer service at this number 1-800-237-7691
May 16, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Do you put water in the big compartment under the solution compartment when wet washing your floor
You put water and Hoover Cleaning Solution into the top tank. Push down on the release button at the top of the tank just below and in front of the handle. The cap is also your measuring cup. Fill it with the Hoover Cleaner Concentrate. Pour that into the tank and fill it to the fill line with warm water.
The dirty water will be extracted into the bottom tank.
May 20, 2010 | Hoover H3030 FloorMate SpinScrub 500...
How do i use my bissell 7920
The 7920 is a great little carpet shampooing vacuum. Look up manual information for detailed assembly and starting/breakdown procedures. Make certain that the carpet/floor has been vacuumed previous to cleaning with the shampooer! The small nozzle opening will get clogged with as little as a toothpick or cheerio! Step on the rear release arm pedal and drop the handle down to the floor, Pull up on the resevoir bucket handle and place the handle of the resevoir back down to open the top of the tank and fill the bladder with hot water. Replace bucket top and place bucket back into vacuum. Raise the handle until it clicks into place. Fill on board soap/shampoo dispenser by lifting out of chamber on unit and fill with appropriate Bissell or upright shanpoo cleaner. Replace unit and make certain the top is tight. Plug unit in and turn on both vaccuum switch and preheat water switch and wait approx. 2 minutes to get water hot enough to proceed with cleaning. Start by rollling cleaner onto carpet and engage trigger approx 2-3' pathway away from you and then release trigger and draw vacuum /shamppoooer back over wetted area, repeat without using water again unless heavier traffic area. Do not over wet area draw unit back and forth a few times until water runs clear thru the front clear window. Proceed to make another path along side cleaned area and so on.
Once you hear the water run out or you have finished cleaning an area then shut of heater and vacuum. release handle with foot pedal release and lift out bucket and pour out dirty water and rinse area/tank /resevoir etc. You should also clean the small red filter in the resevoir of any debris by popping out and replacing. Also, there is an onboard filter under the clear window (where spinner is located) . unscrew clear top , take out spinner device and pull out small plastic screen and rinse or blowout. Clean also the front clear cover if there is debris, by rinsing off with sprayer or wiping clean. You may also find that you have to take off the clear plastic hood window, by unscrewing two screws on either side of nozzle opening (top ) and rinse out as well. Do not, get water under unit into motor area. Place unit upright and in a warm place.. Do not let freeze if in climate that is known to freeze. Good luck cleaning!!
Apr 23, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Leaving bigger dirtier wet spots after cleaning
Sounds like the vacuum motor is defective or you have a clog in the vaccum line. Basically everything is running except the vacuum "Suction" cycle. Do you hear the "Suction" phase (light indicator) during operation when it loudens like a whine? That would be the vacuum phase. Is the dirty water reservoir clean, do you rinse it thoroughly when you empty it? Have you removed the hose assy and rinsed it out? I think it is still part of the auto cycle even if you don't use the manual tool.
Feb 24, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
My floormate isn't picking up the wet water
Check the uptake tube. When you push the release button and bend the top of the unit towards you, you can see the tube coming out of the floor assembly. Mine split right there.
Jul 10, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Dirty water comes out when I stop scrubbing. Floors remain wet.
Try one thing... the filter cover must be clicked into place. I thought it just sat on top, but it has to be pushed into place.
FWIW
Mar 22, 2009 | Hoover H3030 FloorMate SpinScrub 500...
DOES NOT VACUUM NOW
Several possible problems:
1) Did you clean the blue lower pickup container (dirty water) before putting it away?
Take out the pickup container and open it up, check the filter (under the little blue piece on top) and also open up the container itself and clean under the flapper on the "screen".
2) Look inside the housing and check the vac hose that goes from the front of the unit up to the rubber grommet where it goes into the lower pickup container. Is it clogged? If yes, take off the front pickup (the part the runs along the floor in front of the rotating brushes) and run a very narrow lint pickup brush (like for cleaning dryer vents) and clean out the hose. It works great.
3) Check the front pickup for clogs and clean
4) If you are trying to pick up water, make sure the setting is set to wet. If you are trying to use it as a vacuum, set it to dry.
Hope this helps.
Nov 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
It is not sucking up all the water
I've had this happen to my SteamVac V2 and usually find that it's because I don't have the dirty water tank locked down well or I haven't pushed the hand attachment flap in tight or its gotten clogged up down in the suction area. I have a black lab and that area accumulates dog hair quickly. I use a Zip-it available at Lowe's or on the web to clean that out.
Sep 18, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Minnetonka Kilty Suede Moccasins Shoes Logo
Top Minnetonka Clothing Accessories Experts
Da Doc
Tom Chichester
Are you a Minnetonka Clothing Accessory Expert? Answer questions, earn points and help others
