Gateway NV54 Series laptop won't connect wirelessly? Drivers and such recognize the router and its networks, but won't connect :\ I used this computer to set up the router; ipod also can't detect the networks I've set up... The computer and other devices do connect with an ethernet, however, dragging an ethernet around behind myself and being tethered to one spot can get incredibly annoying Would an external device (like an internet-detecting usb device) help? I actually don't know where the problem is, and I have done a decent amount of poking around and troubleshooting... :\ Please help :( Thanks :)
  • 162 Answers
Did you asign a security Key for the wireless network? If so, Try without setting up one If still doesn't work then get a different router (has to be B,G,N compatible). Also, when setting up the security key make sure to choose WPA personal as an encryption methode(this one works most of the time for most older and newer laptop)
Thanks
DiegoTech
Posted on Nov 14, 2010
Testimonial: "Thank you! I'll check those things out :)"
Is either an N router or AC wifi router compatible with a Gateway NV54 laptop running Windows 7? My old G router is dead & need to buy new one.
Linksys is a good router that will automatically switch based on your devices. They run about $150. Is that out of your range?
I would suggest Linksys - AC1200 Smart Wi-Fi Router
Jun 18, 2015 | Gateway Computers & Internet
I just used recovery disk to restore back to factory setting for acer aspire 7741Z. Now it won't recognize my wireless router
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 28, 2012 | Acer Aspire 7741z
Can't connect to internet the internet. My modem is working okay on another pc.Previously I could connect. I'm using GATEWAY NV54 laptop on Windows 7 Home premium
Have you received Windows 7 installed at the time of purchase? If not, check the compatibility with Windows 7. Check your Ethernet adapter with LAN for its proper functioning. Try using latest driver for Ethernet adapter from the laptop manufacturer. If the adapter is OK, restore the system to previous date on which it used to work or reinstall the operating system as a last resort.
sonsunny
Jun 14, 2011 | Microsoft Ethernet MN-120 Network Adapter
I have a Gateway T-series (Model:W350A) laptop. I just reinstalled Windows Vista and now the computer is not recognizing the built in wireless card. How do I get it to recognize it? Or how do I install the...
Plug in an ethernet cable into your ethernet card port on the left hand side of your laptop. When it connects to the internet click on the Windows update icon in the system tray. It should show you a Realtek Wireless RTL8187b wireless adapter driver update. Install it, you may need to reboot, but in any case you will have wireless networks available to you and you can pull out the ethernet cable. Good luck.
Dec 30, 2009 | Gateway M305CRV Notebook
Intel Proset wireless just drops connection
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 02, 2009 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
Unable to establish a wireless internet connection
Does your computer normally recognize other access points? Example, free wifi in some bookstores in fast food restaurants. If it does, check and make sure the wireless router is on. Also, plug the PC into the router with a network cable, determine the gateway IP address, enter that into your browser, and make sure the SSID is being broadcast. If you don't know how to do this, the following links may help:
http://wiki.answers.com/Q/How_do_you_find_the_gateway_address_and_subnet_mask
http://support.dlink.com/supportscope.asp
The d-link support will help with your specific router.
Mar 20, 2009 | Computers & Internet
Gateway 7324 laptop wireless switch
I just spent ages looking on the net for the solution on how to able and disable the wireless on my Gateway NV54 series. I finally gave up only to accidentally touch the wireless light only to find that was the switch. Its a touch switch along with the volume controls and volume mute.
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
210 people viewed this question
David Payne
David Payne
