Question about Hawking Wireless-G HWUR54G Repeater
Is there any way to setup the Hawking Repeater without the Setup Wizard Installation disk?
  • 4,281 Answers
Yes you can configure it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Nov 14, 2010
What is an installation wizard and what does it do?
An installation wizard is part of a software installation or setup. It is called a wizard because it will take care of "complicated" or "sophisticated" parts of the installation for you with just the minimum amount of information provided by you. It does all of this without showing you all the details of the process, so the whole installation or setup will appear to work like magic.
Jul 01, 2017 | Computers & Internet
Installing a hawking HOW2R1 Repeater and setup requires a security key; where do I find this?
The Setup Wizard will now prompt you to automatically
configure your IP settings (recommended) and enter a
security key if the network you are connecting to is an
encrypted network. Enter the key and click Continue.
If you do not know the security key of the network you are connecting to, consult your network administrator.
Oct 15, 2013 | Hawking Computers & Internet
Hawking HW2R1 repeater doesn't get internet
first of all bring the repeater closer to your router (after upgrade you can return it to its original location)
Mar 25, 2017 | Hawking HW2R1 Dual Radio Smart Repeater
How to setup up for repeater mode
This particular Hawking device must be configured after it is connected to your LAN and powered up.
Before you can do this, you will need the software from Hawking. If your devices Serial Number begins with HEMCHWREN1 use the link below"
http://hawkingtech.com/products/downloadfile/114.html
If you have a Revision 1 device with a Serial Number begins with HEMCREN1R1 use this link:
http://hawkingtech.com/products/downloadfile/117.html
Once you have the software, here are the steps you need to follow:
  1. Connect the A/C power adapter to an
    electrical source, and then connect it to the
    'Power' socket of the Range Extender.
  2. Connect your Range Extender to a LAN
    port on the Router or AP that you would
    like to extend (repeat) the range on.
  3. Connect your PC to any of the LAN ports
    located on the back of your router/AP.
  4. Now run the appropriate program you obtained from the instructions in the beginning of the answer.
When the auto-load page appears, click the Setup Wizard option on the right and follow the Setup directions.
Scan for your Range Extender by clicking the 'Search' button. Once found, click the device to highlight it and click 'Next".
Choose a name for your Range Extender. You will use this name to identify and connect to your extended network. Optionally, you may change your login username and password. Click 'Next'.
At this point, the Setup Wizard should automatically obtain a new IP address for your Range Extender from the Router. Please wait for this IP to generate into the IP address field. Note the new IP address and click 'Next' to continue.
In the Search box, find the Wireless Network that you would like to extend. This Range Extender works best with other wireless-N networks, but also supports wireless-B and G networks as well. Select your preferred network and then click 'Next'.
For Security Settings, you must make sure that the Range Extender's security settings are identical to that of the Router/AP that is having the signal extended. If you do not know these settings please contact your network administrator.
At this point the Setup Summary displays all configured settings of the Range Extender. If the information displayed corresponds to your desired networks settings, you can go ahead and click 'SET' to apply the settings. The HWREN1 will automatically reboot. Please be patient.
More information can be obtained on the hawking site:
http://hawkingtech.com/products/hi-gain_wireless_networking/range_extenders_&_repeaters/hwren1.html
Sep 24, 2011 | Hawking Hawkin HiGain HWREN1 Wireless300N...
How to install ms office 2010 withh windows 7
Use your MS Office 2010 installation disk and follow the installation wizard. If your CD/DVD does not setup automatically, just run the "setup" installer from the disk and folow the wizard.
Hope it helps.
Oct 10, 2010 | Microsoft Computers & Internet
Is there a compatible repeater for thie AT&T 2Wire Gateway product? I cannot get the wifi signal througout the house, and the Hawking Unit I purchased is not compatible, even though Hawking thought it...
I'm not sure why your hawking is not compatible, it probably shuold be as long as it's on the same band and supports the same security settings (key/algorithm/etc.)
I'd start off with your hawking by changing it to open with no security, then try to setup your hawking. If that doesn't work then you may be right about it not being compatible. If it doesn,then add some remedial security like shared/wep40bit, then try to move up to a wpa2personal level of security.
Sep 25, 2010 | 2wire (1000-400108-001) Router
Missing or bad msacm32.dll file attributed to many files not running, i.e., setup.exe, rundll32.exe, Explorer.exe and many more. is there any way to fix it without reformatting
The answer depends on why these files are missing.
Can you boot the computer at all or into safe mode?
If so you could run the "System Restore Wizard" and restore your system to a point before this problem happened. You can find the system restore wizard in the windows help.
This should fix the problem if has been caused by a virus or an accidental file deletion but if your disk had bad blocks or something then it might need replacing.
If this does not solve the problem tell us more about the exact error message and when it occurs.
Aug 16, 2009 | Computers & Internet
Installation intructions are what I need.
Here is a link to what you are looking for:
http://www.hawkingtech.com/support/details.php?CatID=33&FamID=102&ProdID=176
Jul 17, 2009 | Hawking Hi-Gain HSB2 Repeater
Extender reboots my Netgear router
I would start with stripping ALL security and encryption settings, see if they work with basic IP addressing setup. Verify that the subnet address ranges are the same and that that the same IP schema is used (IPv4 vs IPv6) on both devices. Then make sure that the security settings are complementary to each other and not in conflict (opposite or identical). Then add the pair to the existing network and check antenna connections.
An alternative suggestion would be to install a Yagi type antenna on the Netgear DG834GT. This will give you a very long and useful range. A Yagi antenna can be made rather inexpensively using a coffee can (Google "coffee can Yagi antenna", I suggest the entry from iHacked.com, this gives a good lesson on the antenna and basic concepts).
Nov 16, 2008 | Hawking HWREG1 Repeater
My laptop can't find the SSID
HI all, A couple months have passed since I posted this problem. I found my own answer after weeks of asking for help. The hawking Reg 1 repeater. Here's the answer. THE REG1 REPEATER ONLY WORKS WORKS WITH ROUTERS THAT OPERATE IN WDS MODE. Not all routers can. Check to seeif the router you are extending is capable of this mode. I tried 2 differnet routers, neither worked. Finally when I got one that spoke WDS. It worked like a dream. Why did the directions not say that!!!!!
Kayellynn
May 10, 2008 | Hawking HWREG1 Repeater
Hawking Wireless-G HWUR54G Repeater Logo
584 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
