Question about Behringer F-CONTROL AUDIO FCA202 External Sound System
I cannot get my behringer bcd2000 to give any output from my microphone.The clip light is working but nothing is coming out of the speakers.Do I need different drivers to run mixer on windows vista and if so where can I get them?
  • Behringer Master
  • 5,603 Answers
If your microphone requires "phantom power", the unit may not supply it or require special setup. We need to know what mic you are using.
Posted on Aug 02, 2009
The Amp clip light is always ON only the left channel and the same channel is not functioning by giving sound, please help
I looked at a schematic for EP2500 which is same but has a lower buss voltage than the EP4000. Below, the drive signal to the power stage is full wave rectified to illuminate the LED, d-c is presented to the LED if R128 & R138 has an a-c return. There is a line that can push-up the a-c return. It goes off to a connector that is unknown. I suspect the push-up voltage is not there. It could mean anything. I think its coming from the main transformer, Check for blow fuses.
d9+gf5qhr0mzaaaaaelftksuqmcc
Also the speaker output is protected with a "Crowbar" circuit. It is simply a Triac device (light dimmer) or two SCRs to prevent d-c from shorted output devices being applied to the speakers. which would cook the speaker coils. This may be activated when amp is turned on. Then there is the possibility of the output power devices - one or more shorted.
h+pghp2gje82qaaaabjru5erkjggg==
The amp needs to be checked out by a repair technician.
Feb 04, 2016 | Behringer EuroPower EP4000 2Channel...
My aim is to be able to drive a sine wave generator directly from vocals through a microphone. The set up I have planned so far goes - microphone (Behringer B-1) - Power supply (Behringer PS400) - min
  1. Yes, you need the PS400 with the B-1. Alternatively, you can connect the mic to a mixer with built-in phantom power.
  2. The PS400 shouldn't go directly to to the TA2020 because the power supply is providing a mic-level signal and the amp is looking for a line-level signal. Either add a mic preamp after the power supply, or if a mixer is used, that output can be fed to the amp.
  3. Cabling will depend on what you ultimately choose to do. But, you'll at least need a mic cable to go from the B-1 to the power supply or a mixer.
Oct 30, 2014 | Behringer b-1 single-diaphragm studio...
I Purchased behringer c1 u microphone and I want to record my singing with karoke..Problem is that when I connect laptop with speakers my singing volume is coming louder but sound of background music is...
You need a mixer. Connect the microphone to the mixer and also the background music. That way you have separate control of volume for the voice and the music.
The background noise can come from different sources. One of them is from the laptop itself, if the laptop is noisy to begin with.
Mar 14, 2014 | Behringer C1U Microphone
When connect power, Clip signal On and do not Sound Why this is?
Oversimplified, "clipping" is distortion. Clipping can damage speakers. You can reduce or eliminate clipping by reducing the amplifier's OUTPUT volume; or be reducing in the amplifier's INPUT signal. Excessive amounts of either can result in clipping.
Check out this video for a more in depth discussion about clipping. I hope this was helpful!
Aug 08, 2013 | Behringer Eurolive B212A Speaker
I have a behringer pmp 1280s. I was running two speaker and two monitors through it. One of the monitors was kicked and the patch cable to it was bent. I smelled smoke and the sound coming through turned...
That's a bad sign. A dead short in the output results in a short of the audio output transistors. I believe that to be the problem and a fairly simple fix to someone good at soldering BUT, you can't get parts for behringer equipment. Most components are specially made for behringer. I've been working on an amp for 6 months and I can fix it BUT, I can't find the parts anywhere, or can even find any reference to them online. Without a reference to the specs, I can't even get a generic replacement. Check your music stores in you area, a behringer dealer may can help you.
Mar 03, 2013 | Music
My EURORACK UB2442FX-PRO has audio coming in but nothing coming out...
The outputs of these mixer needs to be connected to an active speaker.
An active speaker have an amplifier and a preamplifier.
Oct 02, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Clip light is on even when no input and when bass is plugged in input low volume and distortion at speaker output
One half of the power amp has failed. You can damage the speaker... do NOT use this until repaired.
Apr 14, 2011 | Behringer Bx4500h Ultrabass 450w Bass...
My clip light stays on behringer ep 2500
DISCONNECT ALL INPUTS(MIC CD) AND CHECK.DISCONNECT ALL OUTPUTS AND CHECK(ALL SPEAKERS ONE BY ONE)IF THE PROBLEM CLEARED WHEN YOU DISCONNECT ANY INPUT OR OUTPUT FIX IT BY CHANGING START WITH CABLES FIRST.
Dec 20, 2009 | Behringer EUROPOWER EP2500 Amplifier
I recently bought a pair of b212A behringer speakers. when i turn the volume or/and bass past the half way point the clip (red light) begins flashing. Is this a problem and what does this mean
Clipping occurs when an amplifier is pushed to create a signal with more power than its power supply can produce. The red light flashing is warning you that your are overdriving the amplifier located in your speaker cabinets. This can cause damage to your amplifier and or your speakers. You should not allow the volume level to exceed clipping.
For more information on clipping CLICK HERE
Take Care!
Nov 14, 2009 | Behringer Eurolive B212A Speaker
Clip light
It sounds like one side of the power amp has shorted. May be hazardous to the speaker so best take it to a shop for repair. If speaker stills sounds OK, probably the clip detector transistors have failed.
Nov 08, 2009 | Behringer Eurolive B212A Speaker
Behringer F-CONTROL AUDIO FCA202 External Sound System Logo
171 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Steve
Steve
Brett Duxbury
Brett Duxbury
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
