Question about Whirlwind FH-778 Air Conditioner
Air conditioner leaking water from the unit inside
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 251 Answers
System Inspection
Although the A/C system should not be serviced by the do-it-yourselfer, preventive maintenance can be practiced and A/C system inspections can be performed to help maintain the efficiency of the vehicle's A/C system. For A/C system inspection, perform the following: The easiest and often most important check for the air conditioning system consists of a visual inspection of the system components. Visually inspect the air conditioning system for refrigerant leaks, damaged compressor clutch, abnormal compressor drive belt tension and/or condition, plugged evaporator drain tube, blocked condenser fins, disconnected or broken wires, blown fuses, corroded connections and poor insulation.
CHECKING FOR OIL LEAKS Refrigerant leaks show up as oily areas on the various components because the compressor oil is transported around the entire system along with the refrigerant. Look for oily spots on all the hoses and lines, and especially on the hose and tubing connections. If there are oily deposits, the system may have a leak, and you should have it checked by a certified air conditioning specialist.
Fig. 1: Run your hand along the underside of all hose connections and check for leaks. If you find a leak, have it fixed by a certified air conditioning specialist.
Air conditioner leaking water from the unit inside - check%20ac%20leak.jpg KEEPING THE CONDENSER CLEAR Periodically inspect the front of the condenser for bent fins or foreign material (dirt, bugs, leaves, etc.). If any cooling fins are bent, straighten them carefully. You can remove any debris with a stiff bristle brush.
Fig. 1: The position of the condenser in front of the radiator makes it particularly susceptible to collecting debris. Periodically, remove the accumulated bugs, leaves and other trash from the condenser. ac%202.gif
CHECKING THE REFRIGERANT LEVEL There are two ways to check refrigerant level. On vehicles equipped with sight glasses, checking the refrigerant level is a simple matter. Many late model vehicles, however, do not have a sight glass, and you have to check the temperature of the lines to determine the refrigerant level.
With Sight Glass The sight glass is normally located in the head of the receiver/drier. The receiver/drier is not hard to locate. It's a large metal cylinder that looks something like a fire extinguisher. Sometimes the sight glass is located in one of the metal lines leading from the top of the receiver/drier. Once you've found it, wipe it clean and proceed as follows:
  1. With the engine and the air conditioning system running, look for the flow of refrigerant through the sight glass. If the air conditioner is working properly, you'll be able to see a continuous flow of clear refrigerant through the sight glass, with perhaps an occasional bubble at very high temperatures.
  2. Cycle the air conditioner on and off to make sure what you are seeing is clear refrigerant. Since the refrigerant is clear, it is possible to mistake a completely discharged system for one that is fully charged. Turn the system off and watch the sight glass. If there is refrigerant in the system, you'll see bubbles during the off cycle. If you observe no bubbles when the system is running, and the airflow from the unit in the vehicle is delivering cold air, everything is OK.
  3. If you observe bubbles in the sight glass while the system is operating, the system is low on refrigerant. Have it checked by a professional.
  4. Oil streaks in the sight glass are an indication of trouble. Most of the time, if you see oil in the sight glass, it will appear as a series of streaks, although occasionally it may be a solid stream of oil. In either case, it means that part of the charge has been lost.
  1. Fig. 1: Oils streaks (A), constant bubbles (B) or foam (C) indicate there is not enough refrigerant in the system. Occasional bubbles during the initial operation are normal. A clear sight glass indicates a proper charge of refrigerant or no refrigerant at all, which can be determined by the presence of cold air at the outlets in the vehicle. If the glass is clouded with a milky white substance, have the receiver/dryer checked by a certified air conditionAir conditioner leaking water from the unit inside - ac%203.jpglist. ac%203.jpg
Without Sight Glass On vehicles that are not equipped with sight glasses, it is necessary to feel the temperature difference in the inlet and outlet lines at the receiver/drier to gauge the refrigerant level. Use the following procedure:
  1. Locate the receiver/drier. It will generally be up front near the condenser. It is shaped like a small fire extinguisher and will always have two lines connected to it. One line goes to the expansion valve and the other goes to the condenser.
  2. With the engine and the air conditioner running, hold a line in each hand and gauge their relative temperatures. If they are the same approximate temperatures, the system is correctly charged.
  3. If the line from the expansion valve to the receiver/drier is a lot colder than the line from the receiver/drier to the condenser, then the system is overcharged. It should be noted that this is an extremely rare condition.
  4. If the line that leads from the receiver/drier to the condenser is a lot colder than the other line, the system is undercharged.
  5. If the system is undercharged or overcharged, have it checked by a professional air conditioning mechanic.
Fig. 3: Checking the refrigerant charge if the system Air conditioner leaking water from the unit inside - ac%204.jpgight glass. ac%204.jpg
Posted on Jun 07, 2011
I have 2 Samsung AW0700/XAA air conditioners that leak water all over floor. We've tried tipping them to get water out but didn't work. How do we stop leak?
inside the unit on the left side of the evaporator coil there should be a channel that allows the water to drain to the outside of the unit and cool the condenser coil use compressed air to clean this channel (a.k.a. keyboard cleaner) were safty glasses and make sure unit is unplugged then check drain to make sure it is clear before running the unit.
Jul 22, 2011 | Samsung AW1893L Air Conditioner
Why does the air conditioner leak water from behind the unit. My air conditioner is placed in a wall and the back end of the conditioning unit sticks out inside the garage. I have ventilation by...
It is normal for an air conditioner to leak water out the back. This water is actually the humidity being taken out of your house. Being vented out in to the garage is always an issue with condensate water. I have seen some people take a funnel and run a hose outside the garage somewhere. Keep the vent closed. It will be harder to cool the house with the vent open because it lets outside air in to the house.
Jul 04, 2011 | Friedrich Heating & Cooling
The inside unit is leaking water
Water leaking in split unit common, due to air filter & evaporator coil dust blocked- Clean it.
Drain pan and drain hose dust blocked-clean it. And also due to less rpm of indoor motor, there will be forming ice over the coil result to water leaking while defrosting.Replace motor capacitor.
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
Leaks water inside
Water leak is the common problem in split air conditioners.. It happens due to:
1. Air filter block 2. Evaporator coil Block. 3. Less rpm of blower motor. 4. Drain line blocked.
To rectify, service the unit completely. If blower motor less rpm, replace motor capacitor.
Dec 18, 2010 | Sanyo Split System Air Conditioner
Water leaks from the roof unit
This is condensate (which of course is water) that is coming from your unit. This is very normal ... Is it leaking inside or running across the roof and down the side of your unit? If it is going inside, there is a drain in your roof unit that is clogged. You must clear the clog. Remove the cover and inspect the base. Turn the unit off first.
Sep 19, 2010 | Dometic Rooftop RV Air Conditioner
What would cause a rooftop a/c unit to leak water inside the trailer only when the unit is running?
There is a drain to run the water outside and it is plugged...this units produces water when running as it dehumidifies the air...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 07, 2010 | Dometic Rooftop RV Air Conditioner
Frigidare air conditioner thru wall unit Model FAH146Q2T2 leaking water inside?
Always make sure that your unit is tipped back towards the outside os it does not leak inside...
heatman101
Jun 02, 2010 | Heating & Cooling
Samsung split systim leaks water from inside unite
when ambient air goes across your evaporater it causes it to condense check your drain hose it may be clogged up not allowing the water to drain properly
Feb 06, 2010 | LG LSC121PMA Split System Air Conditioner
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Heating & Cooling Logo
65 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
