Question about Dell Dimension 2400 PC Desktop
No Ethernet for Dell Dimension 2400
Tired of a hard drive ridden with myriads of unwanted documents, I went ahead and deleted all partitions and reinstalled a fresh copy of Windows XP.
I tried installing all the drivers with the CD that came with the computer but when I plug it to the cable modem, nothing happens. In fact, in the network places window I only see the 1394 (Firewire) but no LAN or Ethernet. The device manager clearly lists Ethernet as a disputed device, but the drivers from the cd are not working and I dont know what else to do. Any suggestions are heartily welcome.
  • ferchos13 Jun 19, 2008
    Thanks, Ill try it out but i have a auestion: im using Windows XP and this driver is for Windows 2000. Should I go ahead anyway?
  • 275 Answers
Copy and paste this below link and download the driver :-
i hope it will work. if problem persists then let me know. if solve then please tick fixya for me
Posted on Jun 19, 2008
Is wd1200jb-00gvc0 hard drive compatible with dell dimension 2400
That is a western Digital Hard drive compatible with most computers even Dell Computers
May 15, 2014 | Dell Dimension 2400 PC Desktop
Dimension 2400 freezes with new hdd
That's because the diags were located on your old hard drive on a different partition of the hard drive.
Mar 16, 2013 | Dell Dimension 2400 PC Desktop
Disk 0 seek failure
You must re-install windows or whatever OS your machine came with. If you have a windows CD, boot from that and follow the instructions given.
Sep 23, 2012 | Dell Dimension 2400 (24006YYVP31) PC...
I need directions on how to reinstall the hard drive on a dell dimension 2400. I basically need a system restore. I have the reinstallation Cd, just need directions. THanks Also, i know how to download...
Regrading restoration you need a bootable CD inserted in CD drive and boot from that Cd by changing the boot sequence "boot from CD", during installation it will ask for format/partition of Hard drive, do if you want, after installation of windows you need driver, get drivers from link below:
and install them as well,
feel free to contact for more information, good luck, do rate the solution if got help
Dec 04, 2010 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 start up super slow programs when you log off don't respond locks up how can i trash or clean it out and delete what in it tried dis clean and defrag
Run disk cleanup to delete junk from the computer. Then disable unwanted items from starting up automatically. To do this, click on start and then run, type msconfig and hit ok. System configuration utility will open up, now go to startup and disable the items you don't want to start automatically with the computer. You can run them when you want later on.
Aug 14, 2010 | Dell Dimension 2400 PC Desktop
I have a PC Dell Dimension 2400 with a hard 40 GB
Basically when you install a new boot drive you need to install Windows operating system on the new hard drive, also the device drivers (eg video, audio, modem, LAN etc), your programs and data. The reason programs has to be installed is because the installation process copied DLL files to the System folders and makes changes to the registry.
You can only copy your data onto the new hard disk.
To avoid copying your data to the new hard drive, you can set up the old hard drive as second hard drive (ie. slave drive), if you delete the redundant folders and leave only the data folders then you have an adddition 40Gb of disk space.
Aug 27, 2009 | Dell Dimension 2400 PC Desktop
I need to reinstall window xp pro on my dell dimension 2400-
If you don't need any files currently on the computer, boot from your Windows XP disc, have it delete the current partition and then format the new partition, and install windows XP.
Note: this will delete anything you currently have on the computer at this time!
Mar 22, 2009 | Dell Dimension 2400 PC Desktop
I replaced a bad 120 gb hard drive with a WD 500gb sata hard drive. Installation went fine, however I am having trouble with the reinstall of the XP system. It freezes up at the point where it asks if you...
First, I would remove the 120 from the system during installation. If possible, use a Windows XP disc w/ SP2 to speed up installation of the OS. Plus SP2 handles a maximum disk size error which limits you maximum partition size. (Under SP1 I think the largest partition can be 137 MB)
I would recommend using NTFS format for the hard drive.
Once it is installed, you can always re-connect it to simplify the installation.
If it's still freezing, check the disc for damage or defects.
Dec 31, 2008 | Dell Dimension 2400 PC Desktop
Ethernet not working after format and xp reinstall
Right-click the My Computer icon and select Manage, then go to the Device Manager in the list on the left and find the Network Adapter from the list on the right, right-click Network Adapter and select Uninstall. When you reboot, XP should find the Adapter and reinstall it automatically. Another reboot may be required.
If it still will not connect, go to the NIC Manufacturer's website and download the driver to removable media. The Driver Update option can be accessed in the Device Manager, but this time select Properties when you right-click the Network Adapter, and go to the Driver tab.
Dec 22, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Dell Dimension 2400 PC Desktop Logo
363 people viewed this question
Alun Cox
