Question about Zenith ZEN450 Remote Control
How/Where can I get a replacement remote for my Sylvania TV. the remote has "IECR615V" Inside the battery compartment?
  • bow_1948 Nov 15, 2010
    I wish to get an estimate of cost for a remote for a Sylvania television, Model SST4323 Serial V10314287. I do NOT want a universal remote.
    Thanks,
    RMB
  • 8,197 Answers
May I get the model # of the Tv to help you get the right remote control
Posted on Nov 14, 2010
My rRimont Control does not work
Check the remote control for its infrared emission. Check it with fresh batteries inserted. Check the battery contacts inside its battery compartment, for any rust or dust accumulated, which prevents proper contact to battery poles. Clean it well before inserting batteries. For more information http://electrohelponline.blogspot.com/ Pull up older posts. Has details about how to check a remote control.
Dec 11, 2013 | Sylvania SRT2432S TV
Remote doesnt control tv
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the contacts inside the battery compartment. If rust or dust obstruct the proper contact, the remote won't work. Clean these contacts before you replace the batteries. Check this link to know about how to check the remote controls. If the infrared sensor inside the TV has damaged, the TV won't accept any remote control signals, even though the remote control is good.
Jan 16, 2013 | Sansui Televison & Video
Remote control sometimes is working, most of the time is not working, so I have to turn it on and off manually
Tries check the tv remote battery compartment for moisture and rust on the remote battery like + - connections inside of the battery compartment?Yes?Take somethings sharp or a knife scrap all the rust out.Take a rag spray some WD40 and clean the + - battery compartment connections.Change another set of a new battery.If after this the tv remote still have the same problems,than the remote itself rubbers inner layer of the rubbers knobs probally warn out and not anymore make correctly contact to the tv remote PCB board anymore or the CPU chip itself it is slowly dying and shorting out of the tv remote CPU,remote devices are heavy dependent on it CPU chips.Or try website like Remotes.com to buy the tv original remote or very closed clone compatible one.
Sep 05, 2011 | Olevia LT32HVE 32 in. LCD Television
Im trying to reset my code for a sylvania 19 inch tv with my all for one URC-4605B01 remote control. I don't know the code for my tv and even if I did I don't know how to put it in with the remote. hope...
Hi There
The codes for Sylvania TVs for the URC-4605 remote are:
0054, 0030, 0171
To enter these codes manually please follow these instructions:
1. Switch the TV on.
2. Press the "TV" button on the One-for-All remote
3. Press and hold the "SET" button on the remote until the LED flashes twice, then release the "SET" button
4. Enter the first four-digit code listed above - 0 0 5 4 - using the numerical buttons on the remote.
The LED should flash twice to indicate that the code was accepted.
5. Aim the remote control towards the TV and press the "POWER" button once. The TV should switch off. If the TV does not switch off, please repeat steps 2 to 5 above, for the next code in the list.
If the TV switches off, please test the remote to make sure it controls the functions of the TV correctly - or at least as you would expect. If it works, please note the code somewhere easy to find at a later date - inside the battery compartment is a good place to keep this. If it does not work correctly, again repeat steps 2 to 5 above using the next code in the list.
Universal remotes can "forget" the code when the batteries are changed, so it's a good idea to change the batteries before re-programming the code to ensure that they are not a factor in your remote
If you cannot get these codes to work, it may be necessary to use the code search feature, or there may be a fault with your remote. If this is the case, please post back for further assitance.
Regards,
BElectric
Dec 30, 2010 | One For All URC-4605 Remote Control
Need universal remote code for Sylvania TV
Open the battery compartment of the controler and take the batteries out and there should be a phone number there you can call.If it isn't there go on line and find the remote codes you are looking for.
Oct 23, 2009 | Televison & Video
We have 2 Sylvania TV's. The remotes work on one TV but the other TV no longer recognizes the remotes. It gradually seemed to lose reception of the signal from the remote. Any ideas?
The tv has a infared remote eye located at the front panel. It is possible that the remote eye sensor has gone bad. You could try cleaning the remote eye lens. There might be debris that got inside the remote eye housing and is blocking the sensor. You could also try installing fresh batteries in the remote.
Sep 26, 2009 | Sylvania SRT2319 TV
Comcast remote cannot operate Funai/Sylvania LC225SSX tv. Tried all codes, even for all televisions made by Funai. Code search did not work. Comcast tech could not get Comcast remote to work on the Funai...
Currently there are no remotes nor any codes for them that will operate virtually any sylvania tv's. sorry, it's like the only model we have no resource for as of yet. -Comcast Tech
Jul 31, 2009 | Sylvania LC-225SL9 22 in. LCD TV
Factory Remote Control for Sylvania model SRT2319 doesn't work
You can buy an original replacement remote for your TV clicking the link below:
New Original Sylvania SRT2319 Remote Control $39.99
Apr 18, 2009 | Sylvania SRT2319 TV
Lost Instruction Manual Paper for Sony RM-V401 Remote Control
You must press "set" button (with a pen), then press "tv" followed by the code you have and finally "enter". Regards
Jul 13, 2008 | Sony RM-V401 Remote Control
Zenith ZEN450 Remote Control Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
