Question about Casio FR-2650Plus Calculator
When the feed button is pressed a percent sign is printed on tape.
  • 21 Answers
The printer of the unit has a problem... it is either an alignment is needed or the printer is dirty... you have to contact the nearest service center for it is too complex if you try to disassemble the printer.
Posted on Sep 30, 2008
Paper jams in back of machine?
you have an obstruction either a piece of paper between the rolllers or the secondary feed rollers are not turning.... open the machine and follow the feed path ...take a piece of paper and manually feed the paper with the machine in the off position look at the feed rollers then the secondary rollers( usually two small rods with rubber sleeves kissing each other ...if you can look at the sides on the machine( inside the cover) see if the gears ( usually white ) can turn or mesh correctly... if you do not see any obstruction then these rollers are not turning when they are supposed to when you press the print button. 90 percent of these problems are paper jams if no jam something is not activating the feed rollers
Sep 05, 2014 | Brother IntelliFax-2820 Laser Fax
Where is the percentage button?
You can try pressing "alpha" or "2nd" and then pressing the key you saw the percent sign on.
here is a temporary solution in case that doesn't work:to enter a percentage up to write the digits before the tens and ones (if any, and if not, just type a zero), a point, and the last two digits.ex:
  • 56%=0.56
  • 28%=0.28
  • 132%=1.32
  • 4243%=42.43
To write down the answer, take all the digits, take off the point, if the percentage is 99% or less, don't write the zero on the right of the period, and add a percent sign.
Oct 07, 2012 | HP 35s Scientific Calculator
E004 Error INIT/FC
You need to finish the flag clear.
Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL. Wait for print out. Turn back to REG mode (you may need to sign back on)
Feb 28, 2011 | Casio Parts Cash Register PC Desktop
I can't figure out how to get the "-" dash symbol to print. Can you help me with this? It's the symble above the letter Z.
Press the button with the @ sign on it (bottom row on left). Display will say 'Basic'. Press the line feed button (under the Print key). Will show you a list of characters to choose from. Use the forward key (>) to scroll thru these characters (there are 14 'pages'). The dash is on the 2nd set. With your cursor under the dash press the line feed again. You'll be returned to your label entry with the dash added.
Nov 30, 2010 | Brother P-Touch 1180 Label Printer
Need to know how to insert printing tape into Canon P23-DH color printing calculator?
Install paper roll with end coming up from rear. Insert end of paper into slot at back of calculator until it stops. Then press feed button until paper advance thru slop at top.
Jul 17, 2010 | Canon P23-DH Calculator
The feed switch on my Canon Printer MX700 keeps reverting to the rear tray, so I cannot print out anything on standard 8-1/2 x 11 paper.
go print -> properties -> page setup -> print options -> tick Disable the paper source setting of the application software -> hit ok and go back to "main" -> select the paper source that you want and hit ok ok and print
Mar 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
How do i select the percent mode on texas instrutments calculator model ti-30xlls
you press the "2nd " button at the the left top of the calculator then press " ( " button and that gives you the percent sign.....
Jan 09, 2010 | Texas Instruments TI-30 XIIS Calculator
Printer does not print
hold down the feed button until both light flash off and let go. This will reset the printer. This should stop it from feeding multiple labels.
Apr 27, 2009 | Argox OS-203 Thermal Label Printer
Reloading tape roll on a Casio DR-T120
Place the tape between the two posts; then put back portion of cover down followed by the removal front portion - press feed button and it should feed. Remember it will only print on thermal paper ----
Dec 08, 2008 | Casio DR-T120 Calculator
Tape Jam
There may be a small piece of label cutting stuck in the gears. remove the label cartredge, you will see a white gear set between the pinch wheel and the print head. Use a micro drive or something strong and give the gears a little help while pushing the print button. You may have to do this several times. Be careful not to use too much force as this may knock a tooth off. Good luck. My Dymo continues to print prefet labels.
Mar 08, 2008 | Dymo LetraTAG Thermal Label Printer
Casio FR-2650Plus Calculator Logo
101 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
