How to hook up a three way light switch - Heating & Cooling
  • 674 Answers
Google the question and it will give you step by step instructions along with pictures. Google "hook up a 3 way switch".
Posted on Nov 14, 2010
How to hook up a two wire toggle switch to a 1987 Yamaha virago three wire key switch
you would need two 2 wire switch's as one wire feeds switch , one feeds ignition and one feeds starter to start on momentary
May 16, 2015 | Yamaha XV 535 Virago DX Motorcycles
Hooked this product up flipped all three and only light and heater come on no exhaust fan
there should be a hot wire to the fan just look for the other wire one for fan one light one heat its there, good luck
Aug 16, 2011 | Cooper Wiring Devices Triple Deco Single...
I have tried to install the Utilitech timer but am having trouble. I have a ground, black, and red wire that were previously wired to a switch that controlled my outdoor garage lights. I tried to hook red...
Sounds like this was probably a three-way switch you are replacing as there is no neutral (white) wire in the box. If so, you can splice the white wire to the green wire in other three-way switch box; then hook the green wire in the box you are placing the timer to the white wire of the Utilitech timer.
Apr 17, 2011 | Intermatic & Self-Adjusting Wall Switch...
I have a four way switch that is not working when i hook it up what woul seem to be the problem with it
If you have a four way, it should mean you have two other three ways. lf so, wires are probably crossed. At each three way, you should have one wire on the dark screw. At one end, this wire will be the hot. At the other end, this wire goes to the light. At each three way, you still have two screws. these are the same color screw, and the wires on these are called travelers. They should only run switch to switch. When you have a four way, it is just in the middle of this run. so, two wires coming from one 3 way, and two wires coming from the other 3 way. Look on the box for the new four way, or see if it shows you which screws are in and out. Then hook up accordingly
Feb 18, 2011 | Leviton Decora Gray Rocker 4-Way AC Quiet...
I am trying to wire my 3 way cooper switch and can't get to work can you help?
you need 2- 3way switches to work properly, on the one side of the switch there are 2 screw terminals and your "traveler wire pair" are connected here,then on the same switch with only 1 terminal on that side the hot phase hooks to one switch and the other switch has the light and neutral hook to this switch
Feb 14, 2010 | Cooper Wiring Devices Three Way Grounded...
3 single poll rocker switch alternative wiring
You never hood the neutral to the switch. The neutrals are always tied together and pushed back into the box. You only hook the line (power) & load (light) to the switch. Of course you also hook the ground to the switch.
Jan 09, 2010 | Leviton 003-1755-W Three Rocker Switches
Need a basic diagram to wire a ceiling fan.
Depending on how your place is wired will dictate the solution here.
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Hunter 52" Ceiling Fan With Light And...
WIRING DIAGRAM
Sep 18, 2009 | Panasonic FV-08VQL4 Fan
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
