I have a cnc lathe, fagor controller. The drive unit keeps cutting out with error code .O.E.213. The only identifying no is AXD-1-15-A1-1 on the fagor drive unit.Can you tell me how to find what this error code is.Thanks John.
Benimur
  • 6966 Answers
SOURCE: Fuji Invertor FRN18
Based on your post, the local distributor of the AJAX CNC Lathe can not repair nor replace, then perhaps you should try to go direct to the systems manufacturer.
  • Fuji Electric Co., Ltd.
  • ED & C and Drive Systems Group
  • 12-1 Yurakucho 1-chome, Chiyoda-ku Tokyo, 100-8410 Japan
  • ED & C Phone 3-3211-1424 Fax 3-3211-7983
  • Drive Systems Phone 3-3211-1425 Fax 3-3211-7982
  • Fuji USA;
Alternately, you could try a local Industrial Electronics Tech. who is familiar with these and has access to a service manual or at least a schematic diagram.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 01, 2008
  • 3567 Answers
SOURCE: i am having cnc lathe
I assume this posting was a test. I answer it simply to remove material that does not apply to the motorcycle category...
Posted on Sep 15, 2010
emissionwiz
  • 76848 Answers
SOURCE: i need to purchase a wiring schematics for a mori seli tl3-b cnc lathe
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Posted on Jul 09, 2012
het_magische
SOURCE: LC1 connection to canon A1 motor drive
you will need a Canon Motor Drive MA for that.
On the batterypack is a Remote Controle jack.
http://www.mir.com.my/rb/photography/companies/canon/fdresources/shared/motordrivema/index.htm
Posted on Jul 26, 2012
  • 45659 Answers
SOURCE: How do I change the spindle direction on my fagor control on lathe
I take it that you have tried all the buttons on the panel. As a safety feature it a may require a combination of switches according to the fagor manual item 4 which is he set of 9 buttons bewteen the to turn switches"quote: - keyboard which allows the spindle to be controlled, it is possible to activate it in the desired direction,stop it or vary the programmed turning speed between the percentage values established by means of a spindle machine parameters MINSOVR an MAXORV with incremental steps established by means of the spindle machine parameters SOVRSTEP "
go on line and type in fagorautomation.com/downloads/manuals/en.amn_8055t_opt.pdf for a user manual download.
Posted on Dec 10, 2014
What does error P03 mean?
Hi,I cant be a hundred percent shore,but I think that it means ( fuel voluem regulater control curcuit low )I hope I am not steering you in the wrong direction,I have a code gide and this is it if im reading it write,all the best.
Sep 14, 2015 | Fagor Washing Machines
How to fix Fujitsu a1 error code for 15rls2 heat pump.
Try cutting power to the indoor and outdoor units for a couple of minutes. Restore power and see if the error returns. The A1 error for this line of units indicates high compressor discharge temperature, which translates to overheating outdoor unit.
If this error code remains after a hard power reset, it's time to pick up the phone. Either you have a refrigerant leak which has resulted in a loss of freon, or a blockage in the refrigerant plumbing that is backing up pressure in the system. Both conditions will require a major repair by an authorized service tech to get your heat pump up and running again. 25361378-awph1b3yhxdrnyqdcrsrelkr-4-0.jpg
Please mark my answer as helpful.
Jan 09, 2015 | Fujitsu 15RLS2 Halcyon Wall Heat Pump Air...
Dec 10, 2014 | Cars & Trucks
Cnc g codes
g codes on CNC euipment me go code telling tool to move fast slow,cut radius, or angle. GOO codes mean drive fast. Go1 or other G codes tell machine to go slower with a F code for speed.
Nov 10, 2013 | Mercedes-Benz Cars & Trucks
I need to purchase a wiring schematics for a mori seli tl3-b cnc lathe
Jul 09, 2012 | Cars & Trucks
What is diffrent between lathe machin & cnc machin
A Lathe machine turns a piece to be worked on usually along its longest axis. An operator or machinist manually moves a cutter or other tool against the rotating piece to remove and/or polish the material to a more refined state. Instead of manually, a Lathe can be controlled by computer with the speed of rotation and positioning of the cutter or other tool being done according to a program or set of numeric data in which case the Lathe would then be a CNC machine. A CNC machine can refer to any computer controlled machine which uses a set of numeric data to determine its operation which can be cutting, drilling, milling, etc.
For a more comprehensive description go to Wekipedia for Lathe at http://en.wikipedia.org/wiki/Lathe
and for CNC at http://en.wikipedia.org/wiki/Numerical_control
Jan 31, 2011 | Computers & Internet
I am having cnc lathe with SL pro system, Now we are not having spindle encoder, please tell me how we can run machine with out spindle encoder.
Sep 14, 2010 | Hero Honda Splendor Motorcycles
Fagor, washer dryer , model 2F-3611 flashing code F07 can you tell me what this is please
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 12, 2009 | Washing Machines
Canon printer MP110
ok clink the above link directly
Nov 16, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Fuji Invertor FRN18
  • Fuji USA;
Oct 01, 2008 | Drills
Computers & Internet Logo
David Payne
David Payne
