Question about Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16
Swingline power ease stapler will not staple and I cannot open the staple section in order to check for a jam in the stapler. What can I do.
3 Suggested Answers
Hugh fulton
  • 62 Answers
SOURCE: Where can I get staples swingline stapler
Asssuming that you are in Australia , you could go to Bunnings and ask them or they might point you in the right direction.
Good Luck
Posted on Sep 13, 2009
  • 224 Answers
SOURCE: My Power Ease stapler is
Try spraying the stapler mechanism with WD40 or a good light oil.
Posted on Dec 23, 2010
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
Jun 13, 2014 | Swingline Optima Electric Stapler 45 Sheet...
900XDN-C SWINGLINE HIGH CAPACITY HEAVY DUTY STAPLER OPERATIONS MANUAL
auto parts store sells a pick with straight on one end and 90 degree on other end.
This should be slender enough to pull staples out.
Mar 27, 2013 | Tools & Hardware - Others
How to open a stapler
Botton or tab on the bottom or by the hinge
Mar 01, 2012 | Swingline 87860 PowerEase ? Full Strip...
Optima Model # 8787x. Appears to be jammed. How do I open up the stapler to remove cause of jam. I think if I could open it up I could fix it. If all fails can this be sent away to be fixed and...
You need to open the stapler from the back. Push the black piece at the back of the stapler in, then pull it up and out. Remove the jammed staples, and reinstall. Make sure you use the correct staple . It appears to be: SWINGLINE 35550 HIGH CAPACITY STAPLES, 3/8"
Apr 13, 2011 | Swingline Heavy Duty Stapler 30 160 Sheet...
Swingline 270 (69270) Staple ends are left mostly open Also, stapler makes a significant popping noise with each use
Swingline, now owned by ACCO, should have a service manual that would tell you how to clear jams - here's the url - http://www.acco.com/contactus.aspx#swingline. If not, you can also send them your question directly so they can help you resolve the issue.
Jan 27, 2011 | Office Equipment & Supplies
My Swingline Optima Power Ease will not staple, nor can I open it to try to find out why. There are staples in there, but it feels like there are no springs
This happened to me as well. I am not sure what causes this but heres what I did to fix it.
Just grab the top part of the stapler ( where it says Swingline) and pull up, like you are trying to seperate the top and bottom. You will hear a click and your stapler should work fine.
Sep 14, 2010 | Staples Swingline® 36115 Staple Guns Tools...
My Swingline model 520e jams every other time I staple.
There were a few staples left in the cartridge when the stapler stopped working. I went thru all the steps on bottom for stapler after changing the cartridge with two different cartridges. It makes the noise and puts marks in the paper, but no staples come out of it.
Mar 18, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16 Logo
192 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
magna buff
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
