Question about Canon ZR200 Mini DV Digital Camcorder
Zr 200 no power and cant charge is there an internal fuse or how much will it cost to fix live in ill
    Genius:
  • 1,812 Answers
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Posted on Nov 15, 2010
Fuse for radio 1993 jeep Cherokee
anthony he ask for radio fuse.... fuel dont run radios.
the fuse is marked RAD.
did you check all boxes?
fuse boxes ?
the operators guide lists it.
the full book is here
read page 200 pdf
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
read that yet?
under RAD and wiring?
XJ jeep. 93 is first good year.
radio dead or just back lamps in it dead. why must i guess?????
ill pretend the RAD is dead. totally.
fuse 2 is RAD 15amps.
in the book, 1min to find. it.
4.0L engines???? guess that?
pdf page 200 and 142 (4LITER)
radios have 3 power feeds
illum
radio power
memory
ill guess, rad power is dead. runs Cig lighter too... it dead?
ITS MARKED .
Jul 04, 2014 | 1993 Jeep Grand Cherokee
Zs mg rover fan heater risistor not working just not getting no electric feed to it and the fuse is ok.
A very common fault this one, that is easily fixed. On older cars the heater fan speeds one and two often fail, due to the resistors burning out. This applies to most of the MG Rover cars of the 90's and 2000's so Rover 200, 25, 45, 400, MG ZR, ZS, MGF and MGTF.
Buy three bigger resistors of value 0.68 ohm and wattage 10 watts, from eBay or an electronics store.
Most of the video here is an MG ZR, apart from the MG TF at the start but it is similar for all models. The MG TF took marginally longer due to the slightly more hidden location of the resistor pack. You need to remove a short vent pipe as well as the glovebox cover on that car.
Oct 09, 2011 | Cars & Trucks
No power
Check the small glass fuse soldered to the board inside. If you don't know what you're doing, do NOT open this unit. IF it is a "SWITCHING" supply, (different than a "SWITCHABLE" supply), there could be high voltage capacitors still charged that can give you a nasty zap. If there's a shop you trust and it is just a fuse, it shouldn't cost much to fix. One time I saw a unit that didn't work that turned out to be the 110 / 220 volt switch was slid 1/2 way between the 2 positions.
I'm sure this isn't much but I hope it helps.
Jeff
Feb 02, 2011 | Epson Power Supply 110/200 VAC Switchable...
Had some power surges and now the unit (XL-MC344) wont turn on. Can't seem to locate a fuse, afraid something more on a component level but have no schematics.
There is a fuse in this unit but it will require a soldering iron to change it. Fuses are rarely the problem. This unit uses a switch mode power supply along with a small transformer for the standby voltage. It is possible that the internal fuse for the standby transformer has opened. The fix for this would be to replace the transformer. This is a common problem with lightning strikes and power surges. WIthout seeing the actual unit, I can't say that this is the problem for sure, but it is likely. Please note that JVC service manuals are not usually available outside of Authorized service centers.
If you can update this with your location, perhaps I can direct you to a local service center.
Dan
Aug 20, 2010 | JVC XL-MC334 200-Disc CD Changer
Trying to Get Some Idea at What It's Gonna Cost Me.
When it comes to electrical problems, and that is what I did for living, it is near to impossible to know going in how many hours it will take to fix, most of the cost is labor, here it is $120 per hour, mounts up fast, if you get off with $200 feel lucky.
Jul 31, 2008 | 1997 Chevrolet Lumina
No lights, no response after power outage
The sparks that you specified looks like.. a transformer problem.. And yes they charge 200$ for labor!! The cost of a replacement transformer is around 120$
Apr 24, 2008 | Creative Labs Gigaworks S750 Computer...
Mitsubishi 65909
I bought the mitsubishi black diamond gray 65819 is under warranty and had same problem , turns off like after 2seconds ,it can be fixed people but u need a sears tech, I had one come out and was told they no longer can get the part ,but he had to take it to repair it and yes its was a steal for me ,depending where u live the cost for me would have been $350 for part,$200 labor its the board that the power cord is connected to in tv... I live in s.a. texas , the unit that set up the service is 9905 ,the repair unit is just down the street from them off culebra so if u get tech says cant repair it this one does,it helps if u have the warranty or protection agreement
Jan 27, 2008 | Mitsubishi WS-65909 65" Rear Projection...
No power coming through charger to camera.
there are four little fuses on the mainboard but you wouldnt be able to repair them they would need to be fixed but there also could be a problem with the lens sometimes on that model that could cause the problem you have described sometimes when i repair a power cam problem it will act up again and the mainboard needs to be replaced its a good camera but a problem like that you should send it in if you still have a warranty or upgrade to a zr 830 or 850
Nov 10, 2007 | Canon ZR600 Mini DV Digital Camcorder
Canon ZR200 Mini DV Digital Camcorder Logo
48 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
